Old 02-02-2015, 11:49 PM   #501
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by rich weyand View Post
Gregski:
Sorry I'm so slow with this. You're moving fast and I've been busy.
Nice progress. Jeez, I turn around, do a consulting assignment or two, and you are way down the road.
Rich I got to move fast cause word in this household is that dad has a two year burn out period (Motorcycle, drums, Mustang, sail boats, Rusty...) I honestly don't know what they is talkin'a bout... LOL
Gregski is offline   Reply With Quote
Old 02-02-2015, 11:59 PM   #502
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Gregski:
Looks like you have the vacuum advance hooked to timed vacuum, up on the side of the carb. That's pollution nonsense. I remember when it was introduced in 1968 together with AIR pumps and cats and all. The previous 30 years vac advance was always connected to full manifold vacuum. So hook the vac advance to full manifold vacuum. It's down underneath in the front by the PCV port (see Fig 7 on Page 7 of your carb instructions here: http://documents.holley.com/199r10331rev2.pdf). This will give you advance at idle (which you should have), and will allow a leaner mix at idle and keep the carb in the idle circuit at idle. You THINK it idles nice now. Move the advance line and you will see how good it can be.
Rich believe you me, I fully intended to use full manifold vacuum (I may have even remembered an old post of yours) but when I looked at the Holley glossy page color instructions they showed three vacuum sources on the carb:
1. Full Manifold Vacuum source (Pump diverter valve or cruise control)
2. Full Manifold Vacuum Port (Power Brake or PCV)
3. Timed spark vacuum source (To distributor vacuum advance)
~ this be the one they skierd me into using ~
I just went back to look at my instructions again and that don't even look like my carburetor none, take a look at what would be page 3 (had they even numbered their pages)
http://documents.holley.com/199r10416rev.pdf
All in all I totally agree with you and will change my vacuum connection, thank you very much for your time to write down that advice.
Old 02-03-2015, 12:08 AM   #503
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by y5mgisi View Post
Love your thread update style!
Thank you so much! Mom, mom is that you? jk
Old 02-03-2015, 12:37 AM   #504
rich weyand
rich weyand's Avatar
Re: Restoring Rusty
Huh. I thought I had found the correct instruction sheet for yours. Ah, well.
OK, so you have the brake booster hooked to the manifold. That's good.
Looks like the larger diameter connection for the PCV valve comes off the passenger side at the back of the carb, so you can run a 1-1/2" to 2" long line out to a 90, and then go back along the inside of the valve cover to another 90 and out to the PCV valve at the back of the passenger side valve cover. That will be clean and you won't have a big hose across the front of the engine.
The smaller manifold vacuum line comes off the front of the carb, but you can swing that around inside of the valve cover and back to the distributor. Maybe a 90 in that one too to help it around that corner at the front of the carb.
I don't recommend teeing the vac advance off the PCV line, as tempting as that will be. That PCV line will have oil and crap in it, and when you shut the engine off, you don't want that running down into your vac advance canister.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 02-03-2015, 09:29 PM   #505
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
today in the time it took me to enjoy a meatloaf sandwich the boyz at Lock n Key knocked out two door keys plus a spare ignition key for $17 bucks, I call that a Win Win
they fit beautifully and give me that click click sound
Old 02-03-2015, 09:33 PM   #506
Jake Wade
Jake Wade's Avatar
Re: Restoring Rusty
Good deal, That's a bargain!
Jake Wade is offline   Reply With Quote
Old 02-03-2015, 09:41 PM   #507
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I know I said I don't paint in the winter but it was near 70* F today (and as long as Greg doesn't read this) we can get this done
Ever since I saw this Dupli-Color Minute infomercial seventeen minutes and seventeen seconds into episode 3 of the Hot Rod Garage video on them there YouTubes I wanted to try painting my interior door panels, just to see if I can save a buck or two, that and if it works for David Freiburger it's good enuff fer me
https://www.youtube.com/watch?v=5iIleaQjIz0
Old 02-03-2015, 09:54 PM   #508
Super_Dave
Super_Dave's Avatar
Re: Restoring Rusty
One is a left handed version and the other is a right handed version, didn't you notice that?
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair
"Life is tough - wear a cup!"
"Old Enough to Know Better - Too Young to Resist"
"Junk is something you will need three weeks after you throw it away."
Super_Dave is offline   Reply With Quote
Old 02-03-2015, 09:54 PM   #509
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
as with any paint job the prep work is the key, in my case first the door panels had to pass the scratch test whilst still having enuff meat on em to paint
so your door panels may be chalky, that's ok, take a green scotch bright pad and a bucket of lightly soapy water and wash/scrub them as best as you can
give em another finger nail scratch test if they still leave a mark, take some sand paper, I think I used 1000 grit cause that's all I had, you can sand wet or dry but I did it wet to make the paper go further
rinse, lather, repeat, hose off the panels and give em another scratch test, till your finger nails don't leave a mark
then I let them dry over night
the next day I sprayed them with this Dupli-Color Prep-Spray wax n grease remover, you can use Denatured Alcohol (probly cheaper from Home Depot, but I didn't have any and was too lazy to hit two stores) do NOT use Acetone or Mineral Spirits they are greasy and used for different purposes, they penetrate and do not lift plus they can destroy plastic
so the key is good prep and then Light Coats, I went four coats 10 minutes apart, yes it was difficult waiting in between coats, so I used a timer and kept myself distracted with other little tasks on the truck and in the garage
here are the initial photos plus the results after each coat
Old 02-03-2015, 10:00 PM   #510
Jake Wade
Jake Wade's Avatar
Re: Restoring Rusty
Looks Great!
Old 02-03-2015, 10:06 PM   #511
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I know I said I will treat myself to all brand new interior parts for my truck but with stunning results such as these (assuming they hold up and not flake or fade) it's difficult to justify the $170 for a set of new panels plus $28 for Shipping & Handling
If we do the math, forget the cost of new panels, I paid $16 bucks for these two cans of material, that is less than the cost of shipping of the new panels, the shipping
just wanted to let you know that as the paint was getting low in the can I stood the panels up some for the fourth and final coat, I really need to discipline myself to paint things in the vertical and not horizontal position, word to the wise
also I know I should have waited at least 24 hours if not a couple days, but I just had to scratch them there things after painting, and so I did, and did the paint come off, Heck No, this stuff works
Old 02-03-2015, 10:07 PM   #512
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
yes, they have fair prices and do amazing work, well worth the drive cross town
Old 02-03-2015, 10:08 PM   #513
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Ah yes of course, amiba-dextrus!
Old 02-03-2015, 10:10 PM   #514
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Looks Great!
Thanks Jake, I think so too, can't wait to fit them on the doors, wait one must, paint dry shall
Old 02-03-2015, 10:38 PM   #515
Super_Dave
Super_Dave's Avatar
Re: Restoring Rusty
A man of many talents... a giant among men... a.. let me think... no, it will come to me... a... what were we talking about?
Old 02-03-2015, 10:45 PM   #516
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
LMAO I think I need a jump suit!
Old 02-03-2015, 11:31 PM   #517
greg64
greg64's Avatar
Re: Restoring Rusty
Looks great, Greg! What the heck are you doing painting today?
I bought new panels from LMC for my truck, in dark blue. The paint is scratching off them, so I might need to try your trick come summer. As a warning for others, the LMC panels have a base coat paint that seems pretty tough. But on top of that they put a crappy coat of the colour you actually wanted. Doesn't seem to stand up, but then, my truck is a work truck, not a show piece.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 02-03-2015, 11:35 PM   #518
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
good to know, what color is the base coat?
Old 02-03-2015, 11:38 PM   #519
greg64
greg64's Avatar
Re: Restoring Rusty
I'll have to check tomorrow when it's light out and see. Can't remember right now.
Greg
Old 02-03-2015, 11:51 PM   #520
Super_Dave
Super_Dave's Avatar
Re: Restoring Rusty
ELVIS LIVES!
Old 02-04-2015, 01:40 AM   #521
Chaplain
Chaplain's Avatar
Re: Restoring Rusty
Dang G. Thanks for being our tester. Can't wait to get the point where you are.
Chaplain is offline   Reply With Quote
Old 02-04-2015, 06:06 PM   #522
rusty76
rusty76's Avatar
Re: Restoring Rusty
Looks great dude.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 02-04-2015, 06:19 PM   #523
LSX408
Re: Restoring Rusty
Door panels turned out good!
1983 GMC SWB - 350, TH-400
2002 Camaro SS - 408 9sec street car
2000 Trans Am - H/C/I
2014 Chevy Z71
LSX408 is offline   Reply With Quote
Old 02-04-2015, 08:30 PM   #524
portrodder
Re: Restoring Rusty
Door panels turned out great, going to have to try that on mine.
portrodder is offline   Reply With Quote
Old 02-07-2015, 05:50 PM   #525
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
well you all know I'm not the type to sit still so although our local weather forecast called for four days straight of rain, it is nice and sunny and dry as a bone today, just goes to prove that our local meteorologists can tell us with absolutely certainty what the weather was like yesterday
so after dropping 5 gallons of gas in the tank and going for a joy ride, the wrenches were calling to me... so I went after the kick panels
