03-13-2018, 10:03 AM | #501 |
Re: What did you do to your truck today part IV
Not today but yesterday. I´m going to test-fit some sheet-metal on my -62 C10 Panel before welding and straighten the side of the truck. 1/4" bondo.
03-16-2018, 09:40 PM | #502 |
hillbilly
We got the rear window opening cut out to match the inside panel. It looks like a whole new truck. I cut out a section of the front panel to start reparing.
-1962 C-10 |
03-18-2018, 10:44 PM | #503 |
I took the gas tank out.
03-19-2018, 10:08 PM | #504 |
Test fit my china repo door. Getting ready to cut out the rust on the inter, outer rockers.
03-20-2018, 10:29 AM | #505 |
Here is the inner basecoted and outer sheetmetal welded, so that is what I have been done today. I hope that I can begin whit the corner tomorrow.
03-20-2018, 11:29 AM | #506 |
I installed the new NOS distributor I got from forum member chevy2inreno on the 250 6-banger on Sunday. Checked initial timing on the old one, was set at about 8 degrees BTDC. Spec is 4 BTDC, but I've heard from old GM mechanics that timing should be advanced to just before pinging starts on regular gas with this motor.
So installed the new distributor and set initial timing at the same 8 BTDC. Drove the truck to work today- HOLY CRAP! what a difference. Way more acceleration, should have done this a long time ago, but I though the old distributor was OK. Think I've got the Rochester B and the spark timing dialed in pretty good now.
Everybody has to believe in something. I believe I'll have another beer. |
03-21-2018, 12:15 AM | #507 |
Welded up the hole.
03-21-2018, 09:42 AM | #508 |
Got the hood back on with new updated hinges. Now lots of wiring to be done.
03-21-2018, 09:29 PM | #509 |
Pulled the engine out of Frankentruck
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
03-22-2018, 09:06 AM | #510 |
03-23-2018, 07:39 PM | #511 |
hillbilly
Fixed the middle windshield area. Cut out my passenger side a piller. Roof had rust so i made a piece and welded it in.
-1962 C-10 |
03-24-2018, 07:58 PM | #512 |
Finished the grille for my 62
03-24-2018, 09:03 PM | #513 |
Took the inter fender off.
03-24-2018, 09:08 PM | #514 |
Took the motor apart so it can get rebuilt.
03-25-2018, 09:20 PM | #515 |
Replaced right side mirror bracket with NOS GM mirror I found on Ebay. Holes were there, somebody must have damaged original and replaced with aftermarket bracket. Mirror was the original GM mirror. Looks better. Cleaned out drip rail and put new seam sealer in.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison Last edited by allchevy58; 03-25-2018 at 10:15 PM. |
03-25-2018, 10:30 PM | #516 |
Finished my Dolphin Gauge insert. Dead on with my GPS once calibrated.
03-25-2018, 10:31 PM | #517 |
Ruh Rho!
03-25-2018, 10:32 PM | #518 |
Oh well, I tried...
03-25-2018, 10:59 PM | #519 | |
03-25-2018, 11:07 PM | #520 |
3M Body Seam Sealer, I used a little over one tube, but I waste some. Could of made it with one if I knew what I was doing.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
03-25-2018, 11:14 PM | #521 |
Got my latches i will install them tomorrow.
03-25-2018, 11:21 PM | #522 |
03-25-2018, 11:23 PM | #523 |
Pulled my gauge cluster to be sent to redlineg.com next week. Going to add vacuum gauge, tachometer and convert the amp gauge to a volt gauge and calibrate the rest.
Also Ordered a rebuilt Saginaw 3-speed overdrive transmission. |
03-25-2018, 11:53 PM | #524 |
Took apart the th400 to beef it up in preparation of 500+ lb ft of torque.
03-26-2018, 12:24 AM | #525 |
You fellas are an inspiration!!
