05-06-2017, 11:54 AM | #5276 |
Re: What did you do to your truck today? Chapter II
keep forgetting to do that...sorry
05-06-2017, 02:41 PM | #5277 |
The plan is working out with some assembly required.
05-06-2017, 05:38 PM | #5278 |
Now that's a good tire plan, good one.
Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
05-06-2017, 07:54 PM | #5279 |
laying low
That low bed mount spare tire is a real good idea. I like it. How is it working out underneath? That must be a long bed.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
05-06-2017, 08:22 PM | #5280 |
Thanks it's a long bed. I've done a lot of mods to make it work my bed is custom to start with. All the parts are drying now tomorrow it will be installed.
05-06-2017, 10:11 PM | #5281 |
05-07-2017, 09:40 AM | #5282 |
took Wanda and the corvette to a small car show . Both won 1st in their class.. Thanks Exxon for the invite
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
05-07-2017, 11:10 AM | #5283 |
Yellow Blue and You--SMILES all around! The Vette and Wanda look Happy and Proud to be G.M. Thanks for sharing!
05-07-2017, 01:48 PM | #5284 |
Wheel tub in and it looks great, like it was meant to be there. The bottom of the tub is about an 1 1/2" above the fender side and the tire is an inch below the top.
05-07-2017, 03:11 PM | #5285 |
That is pretty trick. I especially like that you did that with the wood bed and making the custom look almost stock in appearance.
05-07-2017, 05:08 PM | #5286 |
05-07-2017, 06:36 PM | #5287 |
Old member
3 year old water pump failed. Replaced it with a new one from O-Rielly's. New thermistat and hoses.
I also polished under the hood.
05-07-2017, 08:41 PM | #5288 |
At the body shop.
Hooked up 12v to the choke.
Installed rebuilt radiator, radiator shop said it is a continuous fin 4 row industrial type. Will outlast the truck.
" That didnt make it any newer " " Dont antique the equipment " |
05-09-2017, 10:09 PM | #5289 |
Finished up my oil pressure line tonight. A big shout out to members LockDoc (for the line kit and needed adapter) and TBONE1964 (for an excellent working replacement oil pressure gauge). Everything went together easy and fixed a small oil leak in the process. So nice to get the stock gauges working and and being able to pull out the cheap three gauge under dash panel. Pic is oil gauge at idle.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
05-12-2017, 05:10 AM | #5290 |
Finished the hold down for the new spare wheel tub.
05-12-2017, 09:59 AM | #5291 |
I put my frame on a rotisserie and sprayed it.
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod |
05-12-2017, 06:59 PM | #5292 |
Nice Job--I like Your rotisserie!
05-12-2017, 07:01 PM | #5293 |
Installed 2in drop spindles. Now the front is at 5. Gotta put on the c notch to go to 7 on rear. Although I knew the 45 series was too tall I barely got it home lol. Will be looking for some 40 series tires.
05-12-2017, 07:40 PM | #5294 |
I also used Harbor Freight's disposable spray gun. $9.99 and you don't have to waste time trying to maybe get the epoxy out of it. I removed the air fitting and it went straight in the trash.
05-12-2017, 08:06 PM | #5295 | |
05-13-2017, 02:02 AM | #5296 |
Like it came from factory or some crazy idea.
05-13-2017, 07:06 AM | #5297 |
05-13-2017, 05:18 PM | #5298 |
I changed the earl & filter in mine. And I did the same for the other 2 in the fleet as well. That's a lot of lubrication to take back to be recycled.
1969 GMC 2500. 250 I6, 4-speed w/ granny low |
05-13-2017, 07:42 PM | #5299 |
With Boris' help we got the Steering Wheel off and will start to refurbish it.
Hey man 67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603 |
05-13-2017, 09:03 PM | #5300 |
Cleaned and painted rims yesterday. New 31/10.50 TIRES today!
