Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 11-09-2011, 12:07 AM   #526
Slick67
Sofa King Crazy!!
Slick67's Avatar
Re: Project 67 DRGNWGN - 67 Burban!!
Have the rims drilled, that way you won't have to worry about adapters. There are a few places, like rim straightening shops, that can do that for ya. might be a little more $, but worth it.
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 11-09-2011, 07:52 AM   #527
kev2809
low n' slo
kev2809's Avatar
i was thinking of that..but the rims are 8" wide and i think the backspace is 5 or 6"...i cant remember. but im not sure they will work if i redrill them....im not a rim guy so i have no clue what fits or doesnt lol. first set of rims ive ever owned
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 11-09-2011, 09:31 AM   #528
Slick67
Sofa King Crazy!!
Slick67's Avatar
My rear 22's are 5.5 BS, I think, so it should be good. I am running a 71 rearend which makes a difference. My 20 inch fronts are 5.5 BS and are 8.5 inches wide so your 22's should be good on the front too. Do you know anyone with a 67-72 truck that is lowered who lives nearby? Only one of the holes will be drilled that actually hits another hole so it looks like an 8. All the other holes would be close but wouldn't run together..........IIRC.
Old 11-09-2011, 10:49 AM   #529
Slick67
Sofa King Crazy!!
Slick67's Avatar
I have to say Kev, it isn't the best way to go (drilling). Adapter plates would make them stick out too far. Ummmmm, what kinda truck did these come off of??
Old 11-09-2011, 12:43 PM   #530
kev2809
low n' slo
kev2809's Avatar
they actually came off of an 07 altima...they are only 8" wide rims
-_--_--_ _________
Old 11-09-2011, 12:52 PM   #531
Slick67
Sofa King Crazy!!
Slick67's Avatar
Easy enough. Find the BS on them now and then add the amount you need to make it approx. 5.5 inches overall total and that would be your spacer/adapter thickness. Discount Tire should be able to tell you the BS on them with a quick lookup.
Old 11-09-2011, 08:30 PM   #532
kev2809
low n' slo
kev2809's Avatar
ok..remeasured just now and from the stick laying across the back of the rim..to the mounting area is 6". and the rims are 22x8.5"
-_--_--_ _________
Old 11-09-2011, 10:18 PM   #533
Mulk
Mulk's Avatar
I'm not sure about the backspacing on mine, but it's right around 6in. When I converted to disc brakes, the mounting surface moved-out 3/4 closer towards the fender, than it was with the drums.
So that being said.... It would be like having a 3/4 inch adapter on there, and I'm clearing with 20x8.5 on front. So you may be in luck
Eric
'68 C20 Suburban, Bagged with Suicide 3rd Door, and Loaded with a 396 - Under Construction
http://67-72chevytrucks.com/vboard/s...d.php?t=403690
Mulk is offline   Reply With Quote
Old 11-09-2011, 11:09 PM   #534
Slick67
Sofa King Crazy!!
Slick67's Avatar
That's alot of space to fill even with a spacer, but it sounds about right. If you take a peice of wood 1 inch thick and put it on your rotor, then push the rim up to it as close as you can it should give you a good idea of how far out it will be with adapters. Here is a website that might help with the backspacing.
https://www.rsracing.com/tech-wheel.html
Old 11-11-2011, 11:02 PM   #535
kev2809
low n' slo
kev2809's Avatar
i finallly found some info on the rims...in the craziest way lol
im leaving work today..getting in my truck and notice the charger parked next to me. well i see this car just about every day, and i finally look down at his 22's. and it hit me, hes got the same damn rims as me lol. so i tell him to roll his window down and ask him about the rims... they are Lucky 6's...made by BZO. every pic i have found shows a Morpheus on the cap...so not sure why they say that. anywho, heres a link to the specs..
http://www.bzowheels.com/wheeldetail...&finish=Chrome
im not sure what the numbers on the side mean....?
-_--_--_ _________
Old 11-11-2011, 11:31 PM   #536
Mulk
Mulk's Avatar
That +15 and +38 refers to the offset, in mm. So they have positive offset of 15 or 38mm. Now as far as that translates, I can't remember.
From what I remember, it's measured from the center of the width of the rim. So in your case, 4 1/4. Sooo, +15 would move the face of the rim 15mm closer to the lip. If that is the case, then +38 would provide the most backspace, and less lip.... I THINK. Somebody else help me out here
Eric
Old 11-17-2011, 11:54 PM   #537
Slick67
Sofa King Crazy!!
Slick67's Avatar
Updates Kev?
Old 11-18-2011, 07:51 AM   #538
kev2809
low n' slo
kev2809's Avatar
nothin yet...cant finish the fenders til i get the rims on so i might go ahead and order them next week. i have been wanting to start the body work but im a little nervous!
-_--_--_ _________
Old 11-18-2011, 09:03 AM   #539
Slick67
Sofa King Crazy!!
Slick67's Avatar
As we have all seen on your build, there is nothing that you can't do! Why be nervous? Make sure you longboard the sides and large surfaces and it'll look fine. We did mine several times and the results are obvious. Everything else you have done came out great!
Old 11-19-2011, 01:18 PM   #540
kev2809
low n' slo
kev2809's Avatar
lol thanks
i was dickin around with the rims this morning to see if they fit. and from what i measured i think the 1.25 or 1.5" adapters should both work. i just laid the wheels up against the lug nut studs (they are 1" long)...and centered them into the middle. the front had probably at least another inch before they would hit. the back had tons of room. the front still needed to be aired out about 2-3 more inches, and the back is actually almost all the way up.
heres a few pics..
-_--_--_ _________
Old 11-19-2011, 01:45 PM   #541
hotrodchevy1999
Hotrodchevy
hotrodchevy1999's Avatar
like the wheels hope they work out for you
2017 1500 CREW CAB GMC
1997 C1500 Chevy
1971 CHEVY CHEVELLE SS 402BB :
1971 CHEVY C10 Stepside Project 71 cluncker http://67-72chevytrucks.com/vboard/s...ferrerid=89816
My Build Second Chance Suburban (SCS)http://67-72chevytrucks.com/vboard/s...d.php?t=424650
hotrodchevy1999 is offline   Reply With Quote
Old 11-20-2011, 01:03 AM   #542
Mulk
Mulk's Avatar
Looks good. Every time I get wheels during a build, I tuck 'em and lay-out the project. Then I take a photo, and use it as a motivator.
Eric
Old 11-20-2011, 01:11 AM   #543
jmedero
jmedero's Avatar
Looks good man keep at it.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 11-24-2011, 11:39 PM   #544
kev2809
low n' slo
kev2809's Avatar
Appreciate it fellas...got the wheel adapters ordered yesterday. Pics coming soon with the wheels mounted!
-_--_--_ _________
Old 12-03-2011, 02:02 PM   #545
kev2809
low n' slo
kev2809's Avatar
the money shot...
will be a few days before i roll it out, i need to move it to the other side because "somebody" wants to start parking in the garage..
the adapters made them fit perfect..i had to trim out the rear tub area more..and also im going to have to gut the fender and go with aftermarket hinges. they rest on the tire just a bit, but i still dont have the motor in so it will drop another inch and a half or so...
so what you guys think?
-_--_--_ _________
Old 12-03-2011, 02:58 PM   #546
VA72C10
VA72C10
VA72C10's Avatar
Very nice!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 12-03-2011, 04:26 PM   #547
jmedero
jmedero's Avatar
Looks good man. Start putting her back together so you can drive her!!!
Old 12-03-2011, 06:19 PM   #548
kev2809
low n' slo
kev2809's Avatar
lol i know...i cant wait to get this thing straight so i can get some paint on it!
still a lot of work ahead of me!
-_--_--_ _________
Old 12-04-2011, 03:05 PM   #549
Slick67
Sofa King Crazy!!
Slick67's Avatar
Kev! That looks killer. Shotgun, when you get her rollin!
Old 12-04-2011, 05:36 PM   #550
Mulk
Mulk's Avatar
Those tuck in there nice. Looks good man
Eric
