#526 |
Re: LS1 into a 73 cheyenne
Progress is coming along slowly but surely Passenger side is almost complete. After he welds were grinded down I applied some short strand kitty hair, then some rage gold. Alot of hrs and effort have gone into this but the end result is worth it the gaps and panels are eaven now.
#527 |
looks alot better now still need to finish the passenger side before I mudd the driver side. Still needs feather fill and a qulity block. pics are on 80 grit, i just jumpd the gun and ratle cand sum gray primer for a beter visual effect.
#528 |
trip out before and after
#529 |
Mudd cans, that gold is sum damm good mudd
#530 |
Those gaps looks great , thanks for the lesson !
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237 |
#531 |
after i finish the gap dilema I will start work on the front suspension, and finally block, water sand, and spray. I will eliminate the spring and shock and do top and bottom tubular arms with a coil over, after fab work is complete i will remove the arms and send them out to chrome to match the finish on the rear,should look something like these
#532 |
very nice build!
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
#533 |
Still Learning
I agree with you on the evercoat rage. It is great stuff. Man, I wish I had you work the gaps on my son's square body. You are doing a great job. I like the coil over idea too.....looks like some more major $$$. Keeps the pics coming
#534 |
Still plays with trucks
Great work as usual. The gaps are coming along very nicely.
Too bad the factory couldn't have put a little more effort into making them better to start with.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#535 |
Awesome Build!!
#536 |
Finally finished the passenger side my goal was to make my work look like it was never done, least intrusive and i think i accomplished that. I will start mudding the driver side next.
#537 |
Next challenge awaits patiently.
#538 |
Kvn1011
damn that is some awesome work that you are doing!! looking real good bro!
Posted via Mobile Device |
#539 |
As usual- this thread does not disappoint.
1989 Chevy Crew Cab Dually - 454/400, Trans Am Hauler, Future bagged project. 96 Trans Am: 383/m6 - 11.98@115 on 315 M/T D/R's - 408rwhp 394 rwtq 05 VW Passat TDI - 38mpg @75mph ![]() 07 Bandit 1250S - Two wheeled fun! Click here to see my FQuick Garage! |
#540 |
Started getting parts for the front suspension so far i have the top and bottom arms set for coil overs still brainstorming on how to mount them. Front end will be completly over hauled, i will go with a power rack n pinion and the C6 14'' rotors 6 piston corvette brakes on new spindles not sure wich ones will work but will make it happen. My bad for the crappy iphone pic, i was in a hurry
#541 |
![]() Last edited by N2TRUX; 05-03-2011 at 09:07 AM. |
#542 | |
Happy to be here
![]() Join Date: Mar 2000
Please note that you must be a supporting member to post classified item. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here If you need any further assistance with that please contact any Admin for help.
#543 |
wow very nice build you have here man keep up the good work.....
nOtHiNg LiKe ThE gOoD oLe ChEvYs.... ![]() |
#544 |
WOW this build is INTENSE!~ Good work!
I LIKE TRUCKS 1986 GMC Suburban Build Build link 1982 Chevy SWB 2wd Scottsdale, Build Link Sold ![]() 1987 Jimmy Build, Project Cheap A$$ Build Link |
#545 |
Past due update been busy working out of town staying in Palm Springs for the past 5 weeks. Check out my new K member, am waiting on more parts like spindles, billet hubs 5x4.75, power rack and pinion and the front wheels 18x6. I predict clearance issues from the spokes of the wheels to the face of the caliper, will brain storm a solution.
#546 |
chevy runs deep
Nice
![]() Posted via Mobile Device
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
#547 |
say that again VERY NICE.....
#548 |
Home Built '87
This is going to be the truck with the nicest finish on here!
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
#549 | |
Great looking parts as usual. Keep at it.
#550 |
I got all my items i was waiting for, i did a quick test fit but didnt have enough time to complete the assembly. I still need tie rod ends and hardware to bolt up the rack and hubs.
Tags |
73c10, c10, cheyenne, ls1, swap |
