Old 07-31-2010, 12:53 PM   #526
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: The 6.0 Silverado Build
I'm gonna try to work on mine too....even tho its supposed to be over 100* here today!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 07-31-2010, 09:00 PM   #527
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Well, spent alot of good time hangin' out with my brother and a friend of ours. Got the fuel system wired, engine harness routed into the cab and got the ECM mounted behind the glovebox and on top of the HVAC box. Just have to hook up 4 wires at the cluster and repin the factory cluster harness to match the 91 cluster and I should be a go! Note to self...Need to remember to finally order my trans cooler and get it hooked up. Then just the exhaust is left!!! Almost... By the way the 315/35ZR17s (on the rear) D52 calipers and drilled and slotted rotors (on the front) we put on my brothers Nova look SICK! I WILL be putting these on the truck now for sure.
--Josh
Old 07-31-2010, 10:27 PM   #528
mcbassin
Still Learning
mcbassin's Avatar
Hey, I sure would like to see some pics of how you mounted you pcm. If it's like when I mounted my son's TBI ecm HERE it was pretty tight in there.
mcbassin is offline   Reply With Quote
Old 07-31-2010, 10:58 PM   #529
STOCKISH
STOCKISH's Avatar
Thats where I mounted it for sure. The LS computer is huge though. I wish it would have fit in that bracket. I will try to pst pics in a bit.
--Josh
Old 07-31-2010, 11:26 PM   #530
68 short step
looking good
68 short step is offline   Reply With Quote
Old 08-01-2010, 12:35 AM   #531
menace121978
menace121978's Avatar
right on Josh!! little at a time and your almost there
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 08-01-2010, 10:59 AM   #532
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
Josh looks awesome, I still love the stance and wheels you and Dennis have. Can't decide what to do with my truck. I need tires just don't know how a LWB will look lowered with 20's. I'm torn between the stock look and the lowered aggressive look. Oh, what to do......... Looking great dude, keep it up.
What ever the mind of man can conceive......... he can achieve!
My built thread http://67-72chevytrucks.com/vboard/s...d.php?t=375914
1979 GMC Sierra 6.0 L 4L60E
1995 Mustang GT 347
79gmc5.3 is offline   Reply With Quote
Old 08-01-2010, 11:43 AM   #533
JohnC
JohnC's Avatar
Awesome man! I can't wait to see it on the road again!
JohnC is offline   Reply With Quote
Old 08-01-2010, 02:55 PM   #534
VA72C10
VA72C10
VA72C10's Avatar
sounds like great progress!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 08-01-2010, 03:00 PM   #535
STOCKISH
STOCKISH's Avatar
Thanks for the nice words fellas. mcbassin, heres the ecu mounted behind the dash. I had to cut the fins off of one side and it was a tight fit but it is way up out of the way for sure! I know it's not truck related but heres a pic of the 315s under the Nova! We relocated the rear springs with stuff from Detroit Speed and Engineering and put their widened tubs in the rear to fit them. Turned out great but for some reason the pics of the tubs and the Wilwood D52s on the front didnt turn out? O well.
--Josh
Old 08-01-2010, 03:14 PM   #536
68GMCCustom
I had thought a behind the dash installation was possible and would certainly help clean up under the hood. BUT....having to remove the heat sink fins and mounted as it is...I sure hope your PCM doesn't get too hot in there... and start fritzing out on you.
Kurt -
Old 08-01-2010, 08:21 PM   #537
mcbassin
Still Learning
mcbassin's Avatar
I like the install of the PCM I was wondering how you would be able to fit it in there. With the dash off it makes it a lot easier to access that area back in there. I didn't know these units would generate heat?
Old 08-01-2010, 08:42 PM   #538
STOCKISH
STOCKISH's Avatar
I only removed about half of the depth of the fins. And with only two on each side I didnt think it would be a big deal. Also, I figured it would be cooler in the cab with the A/C on blast than under the hood anyway! If I start having issues I will just do away with the door on the pass. side kick panel and mount it there where it is more open but still not vivible from the drivers or passengers seat.
--Josh
Old 08-01-2010, 10:45 PM   #539
68GMCCustom
I was thinking more of when the heats on. Obviously they're good up into the 200+* range so its probably nothing to worry about.
Kurt -
Old 08-01-2010, 10:46 PM   #540
draggin86
draggin86's Avatar
looks clean man.. i have a question for you how did you end up running the wires into the cab? did you use the factory hole from the old ECM?
draggin86 is offline   Reply With Quote
Old 08-02-2010, 09:20 AM   #541
STOCKISH
STOCKISH's Avatar
There was a gromet for something on the firewall just above the passenger side valve cover. Maybe the th350c trans that used to be in it. I will get a pic tonight.
--Josh
Old 08-07-2010, 02:56 PM   #542
STOCKISH
STOCKISH's Avatar
Well progress was little today but progress none the less. I got the harness from the firewall to the tanks and to the taillights installed with the little stainless clips with the rubber isolator in them so it looks nice against the chassis. Also got the rear bumper installed and got the brakes blead out with the help of my wonderful wife! Will be taking the truck to a local muffler shop called Henry's on the 19th to have them run dual 3 inch exhaust with an
X-Pipe, dual Flowmasters, over the axle and turned down just before the bumper with some nice stainless tips. You will only be able to see about 1/2 inch or so of the tips so it should finish it off nicely! I am using 3 inch so when I do switch to the S&P headers the collectors will be easy to adapt to the existing exhaust. I need to find a cheap set of rear inner bumper brackets for a sport bumper though. Mine only had the outers on it when I bought the truck and just havent taken the time to find any yet.
--Josh
Old 08-08-2010, 03:44 PM   #543
flamingbig10
6.0 powered square
flamingbig10's Avatar
I really like the harness, that's what I plan doing for my truck, did you get it from psi conversion, did they make the harness or was it in stock, and did you have them tune the computer
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 08-08-2010, 09:14 PM   #544
STOCKISH
STOCKISH's Avatar
The harness was from PSI, AKA, lt1swap.com I think. They made the harness to my specs. The ECU was tuned by whoever it was that did my first harness that I was so unhappy with . Dont even remember their name!
--Josh
Old 08-08-2010, 11:13 PM   #545
flamingbig10
6.0 powered square
thanks, that's what I want to hear, because I have high expectations on wiring, and once the motor comes I'll order away
Aaron
Old 08-08-2010, 11:23 PM   #546
mcbassin
Still Learning
mcbassin's Avatar
I didn't know that these truck bumpers had inner brackets? I just bought one today for my son's truck off a suburban. The burb had inner and outer, but when I put it on the truck, I can only use the outer brackets. If you get some I would like to see them. Wonder if I could fab some up?
Sounds like you are making some good progress!
Old 08-09-2010, 08:18 AM   #547
STOCKISH
STOCKISH's Avatar
I'm just assuming on the brackets. My rear bumper has holes in it with no bolts! Looks like there should be two brackets on each side?
--Josh
Old 08-09-2010, 08:45 AM   #548
mcbassin
Still Learning
mcbassin's Avatar
I did a quick search and found this HERE Not cheap either $56 ea.:
Inner right 81-87
Inner left 81-87
I wonder how necessary these are if your just driving, and not attaching a bumper hitch? I plan on putting a regular towing hitch on there eventually.
Old 08-09-2010, 09:16 AM   #549
STOCKISH
STOCKISH's Avatar
Yeah, mine doesnt have those! I dont think they matter too much. Would probably keep from having as much damage to the rear of the truck if rear ended though. My bumper hasnt fallen off yet so I think were good!
--Josh
Old 08-09-2010, 07:27 PM   #550
Stitch
Location: Where I come from, it's cornbread and chicken...
Just put bolts in the holes and nuts on the back. And don't use the bumper as a bumper too much.
Stitch is offline   Reply With Quote
