Old 01-14-2012, 09:26 PM   #526
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Halfbreed - GMC Z71 + IH Extd Cab
I'm not going to even pretend that I wasn't wrong.
My wife doesn't even get to hear this often...
I... was... wrong...
I was a firm believer that your front end redo was going to look like complete ass and ruin all of the hard work you put into the truck.
This sums it up for me as well:
I looks like it was supposed to be that way. Good job!
The proportions look perfect. You nailed it. GREAT job!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-15-2012, 12:20 AM   #527
NONHOG
NONHOG's Avatar
Cool truck w/o the work you've done. Its cooler now!
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 01-15-2012, 08:03 PM   #528
sparkydog
sparkydog's Avatar
Took both front fenders off and prepped all the back sides of the seams I will be welding over the next few weeks. Then I put the fenders back on the truck - I prefer to work on them there especially while doing hammer/dolly work so I can see all the curves in the right context.
Then I switched over to the forward tilt hinge project. This takes priority over the finish welding because I can't use the truck until the hood can stay on.
Pic 1 was my first mod - I wanted the cross bar to stay as wide and as high has possible in order to keep as much clearance in the engine bay as possible. Therefore I took 2" out of each side so that the kinked section was as wide as possible.
Pic 2 is prepping the center cut. I made the hinges 48" across in order to tuck up into the IH hood. This was about 8-9" overall that I took out of the stock Buick hinge assy.
Pic 3 I noticed that it looked like the crossbar was only tack welded in 2 spots on each side and I didn't want to take any chances with the IH hood weighing much more than the Buick Lesabre hood. So I fillet welded around as best I could. A warning to anyone else - I think under the paint the metal is zinc plated and I had to fight a lot of sputter before I could get the weld puddle to wick.
Pic 4 the other mod I made to the Buick system was to cut off the stops that limit the travel when the hood is fully open. This is because on the Buick these brackets are horizontal but on my truck I am going to mount them vertical and I will fab these stops back on later if I want/need them.
Balls and a Sawzall
Project Halfbreed
Porsche 944 L67V6 CARB Legal & Other Stuff
sparkydog is offline   Reply With Quote
Old 01-15-2012, 08:10 PM   #529
sparkydog
sparkydog's Avatar
Here is how the hinge looks after all the initial mods. It will be tucking up in this approx location on the hood. In pic 2 you can see that crappy fillet weld I was mentioning in the previous post. In both pics I have the brackets pointed up (vertical) which is the way I will be using them on my truck instead of horiz like they were in the Lesabre.
Pic 3 & 4 is the approx way it will look in the engine bay. Pic 4 is showing how high it will go so that the crossbar will swing up and over the top of the radiator cap. (Even though I don't need access to the cap I still want to try and clear it.)
Balls and a Sawzall
Project Halfbreed
Old 01-15-2012, 08:32 PM   #530
sparkydog
sparkydog's Avatar
Hah that's funny - my wife has almost never heard those words come out of my mouth either!
But seriously if you ever spot something else on my build that you don't like just chime in - I can always use the detached perspectives!
Balls and a Sawzall
Project Halfbreed
Old 01-15-2012, 11:43 PM   #531
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Originally Posted by sparkydog View Post
The thing I like about the sock monkey is you can never tell when he is talking out of his a**.
Gives a new meaning to the term "red eye"
low'n slow is offline   Reply With Quote
Old 01-16-2012, 03:39 PM   #532
ERASER5
ERASER5's Avatar
That is due to the sock monkey having Ed Zackery syndrome.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 01-22-2012, 11:03 PM   #533
sparkydog
sparkydog's Avatar
Yesterday nothing for the truck but the man-cave and the house got some extra storage using old kitchen cabinets from a guy I work with. There are some base units that may get converted into an island in the kitchen.
OK enough distraction - on with the build!
Balls and a Sawzall
Project Halfbreed
Old 01-22-2012, 11:08 PM   #534
sparkydog
sparkydog's Avatar
1st pic - OFF came those hood ribs that I had so nicely shortened back when I sectioned the hood.
Pic 2 - I reinforced the ribs so they could take the new loading from the front tilt hood.
Pic 3 they are tacked back in and also the flanges for the hinge attach points are in.
Pic 4 I went overboard and made up my own hinge attach bolts. The one on the right is the Buick stock bolt but was metric. The two on the left are my DIY replicas only in US size.
Pic 5 everything assembled and ready to trial fit!
Balls and a Sawzall
Project Halfbreed
Old 01-22-2012, 11:14 PM   #535
sparkydog
sparkydog's Avatar
I decided to ditch part of the Buick hinge and go with bigger, longer bolts to help handle the extra weight of my IH hood. So I chopped off the Buick factory hinge pins and integrated some 3/8 bushings into the hinge area.
Then I fabbed up the stationary portion of the hinges and tacked them into place with the hood shut. I had pilot drilled some mounting holes and will undo the welding and slot these brackets so that they can give me some up/down adjustment with the hood. But for today..... I just wanted to get the freakin' hood on and working!
Balls and a Sawzall
Project Halfbreed
Old 01-22-2012, 11:17 PM   #536
sparkydog
sparkydog's Avatar
Ta Da!!!! (sounds of angels singing)
Time out to sit, sip and study.
Balls and a Sawzall
Project Halfbreed
Old 01-22-2012, 11:23 PM   #537
jb1016
"Oh well, it's a driver."
jb1016's Avatar
^ Great pic!!
Old 01-22-2012, 11:38 PM   #538
sparkydog
sparkydog's Avatar
Next up is figuring out how to get the cowl-side latch brackets from the Buick to integrate (attractively) into the IH/GM cowl area. Then it will be time to finish weld a bunch of stuff on the hood and after that... I... cough... gasp... might be ready to paint the interior of the hood with some POR 15 and actually get something ready for primer!!
Balls and a Sawzall
Project Halfbreed
Old 01-23-2012, 12:18 AM   #539
67ChevyRedneck
It almost looks like you know what you're doing!
Jesse James
Project "On a Dime"
Old 01-23-2012, 01:13 AM   #540
Pop's C-10
Pop's C-10's Avatar
very trick
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 01-27-2012, 12:44 AM   #541
sparkydog
sparkydog's Avatar
Originally Posted by jb1016 View Post
^ Great pic!!
Originally Posted by Pop's C-10 View Post
very trick
Thanks !
Balls and a Sawzall
Project Halfbreed
Old 01-27-2012, 12:46 AM   #542
sparkydog
sparkydog's Avatar
Can't figure out how to edit an older post so I am hybrid posting this pic again - just want to show the two pics side-by-side.
Balls and a Sawzall
Project Halfbreed
Old 01-28-2012, 09:42 PM   #543
sparkydog
sparkydog's Avatar
Getting the rest of the latch mechanism ready.
Balls and a Sawzall
Project Halfbreed
Old 01-29-2012, 10:58 PM   #544
sparkydog
sparkydog's Avatar
Well I got the cowl-side latches mocked up and tacked in so that the hood is fully functional now. But boy do I have a lot of fab work ahead to clean up the cowl and deal with all the loose ends I have created.
Balls and a Sawzall
Project Halfbreed
Old 01-29-2012, 11:02 PM   #545
sparkydog
sparkydog's Avatar
I have been on the lookout for some Chevy 60/40 front bench seats and this week I finally found a set and picked them up Fri evening from a nice guy in El Cajon. These will eventually go into Halfbreed and I am hoping I can adapt the power seat base for the driver that I saved off the 96 GM truck.
Balls and a Sawzall
Project Halfbreed
Old 01-30-2012, 12:05 AM   #546
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Beautiful work, as always!
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 02-03-2012, 11:18 PM   #547
sparkydog
sparkydog's Avatar
it lives again!!!!!
Balls and a Sawzall
Project Halfbreed
Old 02-03-2012, 11:24 PM   #548
tecky11
sweet got a video?
Truck: 1972 International Harvester 1210
Engine: Caterpiller 3116 220 HP 630 tq
Transmission: Eaton Fuller rt 6610
Axles: Merritor I beam front axle
tecky11 is offline   Reply With Quote
Old 02-03-2012, 11:25 PM   #549
sparkydog
sparkydog's Avatar
Over the last couple of evenings I hacked up the GM upper radiator brackets and got them chopped down so they worked on the IH grille. Then I added some tabs onto them so that I could attach the GM fan shroud (after slicing off some of the shroud.) The final pic is showing a lower bracket that I added so that the "new", skinny trans cooler could not flex backward into the AC unit at highway speeds. This little bracket has a stiffening rib because I sliced it out of a section of the now unused GM radiator support.
Balls and a Sawzall
Project Halfbreed
Old 02-03-2012, 11:39 PM   #550
sparkydog
sparkydog's Avatar
I spared you guys the drama of how many times I moved the Buick crossbar. 4th time was a charm. Now I clear everything!
Balls and a Sawzall
Project Halfbreed
