Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 02-23-2016, 12:34 AM   #526
whytry85
whytry85's Avatar
Re: D52 Caliper Rear Disc Brake Brackets
Ok thanks! Will do some measuring next time I'm out and I'll let you know. I think the brackets will fit but I'm. Pre worried about the calipers. I guess it all depends on how they will be clocked. I looked at the pics in the thread but it's hard to tell.
whytry85 is offline   Reply With Quote
Old 04-19-2016, 10:45 AM   #527
tucker69
tucker69's Avatar
Got my "CaptainFab" brackets for my 69' stepside the other day. Machine work was excellent. I did not have any issues with fitment, everything lined up and went together perfect. Only issue I had was the pads were a little thick for the new rotors, I sanded the pads a little and caliper dropped in place then. Here is a couple of picks.....I put a coat of "POR" on the brackets....
tucker69 is offline   Reply With Quote
Old 04-19-2016, 10:48 AM   #528
tucker69
tucker69's Avatar
Photobucket!!!!! Don't know what happened. anyway kit was great, Good Job Captain. Also, about the same time we had a 1963 c/10 at my repair shop for boost/mc add-on. We needed the bracket that mounts this set-up to the firewall. "CaptainFab" to the rescue once again. Bracket showed up couple days later and worked perfect......Casey
Old 04-19-2016, 11:41 PM   #529
Captainfab
60-66 Nut
Thanks for posting your pics and the compliments Casey
Old 04-25-2016, 06:07 PM   #530
Luislou13
Hello Captainfab,
I am interested in your bracket kit, please send me instructions on how I may place my order.
Luislou13 is offline   Reply With Quote
Old 04-25-2016, 11:52 PM   #531
Captainfab
60-66 Nut
I will send you a PM.
Originally Posted by Luislou13 View Post
Hello Captainfab,
Old 05-11-2016, 09:47 PM   #532
Nobudget
I would like to purchase a set of your brackets for my 77 c10 12 bolt. Please let me know how to pay and get them sent. Thanks
Nobudget is offline   Reply With Quote
Old 05-12-2016, 12:11 AM   #533
Captainfab
60-66 Nut
I'll send you a PM
Old 05-13-2016, 10:24 AM   #534
ol_skool_chevy
ol_skool_chevy's Avatar
Can you PM me a price for your black powder coated rear kit for my 1966 1/2 ton truck.
I don't have paypal i can mail you a money order or cashiers check. I will send it as soon as i get your PM.
I already have your P.O. address
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 05-13-2016, 11:20 PM   #535
Captainfab
60-66 Nut
The price is exactly the same as in post #1 of this for sale thread. I will send you a PM.
Old 05-18-2016, 01:28 AM   #536
akdg87
akdg87's Avatar
Captainfab: I've got the d52 kit on my 72 c10. My issue is the outer brake pads are dragging the circumference of the rotor on the horizontal surface (hub?? Between the rotor face and the wheel.). Is there a certain set of brake pads you reccomend? Or did I install something wrong?
akdg87 is offline   Reply With Quote
Old 05-18-2016, 11:21 PM   #537
Captainfab
60-66 Nut
How long ago did you purchase the D52 brackets? That issue arose quite some time ago, but I made a change to the caliper bracket to correct that.
Old 05-19-2016, 12:03 AM   #538
akdg87
akdg87's Avatar
Between December 2012 and March 2013.
build thread
1955 cameo turbo lsx
1993 K1500 Blazer 5.3/4L80e
2009 CTSV Sedan
Old 05-19-2016, 12:44 AM   #539
Captainfab
60-66 Nut
I will confirm the date of the latest revision tomorrow, but I believe your brackets were before that. The interference issue is due to manufacturing tolerance differences in the aftermarket replacement rotors. Did you purchase the brackets in bare steel or satin black powder coat?
Old 05-19-2016, 02:02 PM   #540
akdg87
akdg87's Avatar
Bare steel, they were assembled on the truck then painted with the rest of the frame. I am running Napa rotors, is there a preferable brand that doesnt cause the interference?
build thread
2009 CTSV Sedan
Old 05-20-2016, 12:11 AM   #541
Captainfab
60-66 Nut
I do not know of any specific rotors that are any different than others and no customers have let me know of any.
My latest revision of the caliper brackets was in October of 2014. So you do not have the revised brackets. If you will send me your shipping info, I will send you a set of the newest caliper brackets.
Old 05-20-2016, 12:35 AM   #542
akdg87
akdg87's Avatar
I think I solved the problem: popped the calipers off and bent the upper "fingers" on the outer pads downward and it seems to have solved the issue thus far. It pulled the pad up of the rotor hat. And there's about a 1/16th -1/8th inch clearance now. If the issue persists I may take you up on that offer. Thanks again!
build thread
2009 CTSV Sedan
Old 05-20-2016, 12:37 AM   #543
Captainfab
60-66 Nut
OK. Hopefully those pads will stay in place up off of the rotor hat. If not let me know.
Old 05-20-2016, 04:01 PM   #544
steveo3318
steveo3318's Avatar
Payment sent for a set sir.
1967 c10 3OTT with R10 overdrive.
385 Stroker, 373 posi
FITECH EFI, Vintage air, York 210 OBA,
4/6 drop with riddler 20x8 and 20x10
1957 S5T Leslie Supertyfon train horns and EMD bell
"No bolt left unturned"
steveo3318 is offline   Reply With Quote
Old 05-20-2016, 07:22 PM   #545
steveo3318
steveo3318's Avatar
I have made a fatal mistake on my truck and cannot use your rear brake kit. My truck is a standard with a borg warner R10 overdrive which means my truck freewheels even with the truck in reverse and off. In other words I HAVE TO HAVE an e brake or my truck roles away in gear. I highly apologize and understand if you take some of the refund out for your troubles and fees. Please let me know if a refund is an issue. Again this is my fault and a public apology!
Old 05-20-2016, 11:20 PM   #546
Captainfab
60-66 Nut
You apparently did not read page 1 of this for sale thread where the e-brake style of calipers are talked about.
Old 05-20-2016, 11:28 PM   #547
steveo3318
steveo3318's Avatar
Yes I read that but i do not want to use the caddie brakes. I have already purchased the D52's and now have to send the rears back as well. I dont want the mismatched brakes. To be honest it was more about looks than function for me.
Old 05-21-2016, 12:15 AM   #548
crakarjax
crakarjax's Avatar
He sells brackets for Camaro calipers as well which have e-brake.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 06-01-2016, 12:20 AM   #549
ol_skool_chevy
I just received mine . They really look nice. Thank you el capitan
Mark with Chalk
Cut with a torch
Old 07-16-2016, 07:47 PM   #550
Joemomma1
Joemomma1's Avatar
Anything in the works for this same setup on a Ford 9"?
Joemomma1 is offline   Reply With Quote
