Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 12-27-2011, 03:36 PM   #526
VA72C10
VA72C10
VA72C10's Avatar
Re: My new build thread: Stage 4!
Sounds like you've been REALLY busy!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 01-01-2012, 06:41 PM   #527
swyfor5
swyfor5's Avatar
Almost ready to start the torsion box, rocker panels, floor panels, rear bed panel, etc replacement process. I understand most of the process- leave top installed, install new body mounts, line up all door, tailgate, etc. Have purchased almost all replacement weld in Triplus parts from Wes at Heartbeat.com Has anyone in northern Mi. done this on a 1st. Gen K5? Just sending a message out there to someone near me in Mi that might be willing to help me out with my project. It's now 2012 and I need to move forward, I have a huge stash of parts ready to go on. I just need someone close willing to help with fabrication, anybody?
swyfor5 is offline   Reply With Quote
Old 01-21-2012, 05:00 PM   #528
swyfor5
swyfor5's Avatar
Asking again, anyone here in Michigan done a resto on a 1st. Gen? I am not a welder, and want to find someone that has done this and understands the AtoZ of the 1st. Gen Blazer geometry as far as welding in new parts goes. Trying to save cash for this next step and need to find someone that can help me with this. Got almost all the stuff to weld in, need help!
Old 02-06-2012, 10:38 PM   #529
swyfor5
swyfor5's Avatar
Just scored a new Painless wiring kit #10206 off ebay for less than $300.00! Painless site shows over $600.00-summit about $455.00 Think I did ok, been looking for a while, any thoughts?
Old 02-06-2012, 11:00 PM   #530
VA72C10
VA72C10
VA72C10's Avatar
sounds like a great deal to me!
Old 02-07-2012, 08:08 PM   #531
swyfor5
swyfor5's Avatar
Thank's VA! I'll know more when it gets here. I did buy it off e-bay, ya never know! Have been looking at this upgrade for a while, and the price was way better!
Old 02-07-2012, 08:43 PM   #532
SeventyOne
Were there more at that price...hmmm
SeventyOne is offline   Reply With Quote
Old 02-07-2012, 10:25 PM   #533
swyfor5
swyfor5's Avatar
Keep surfing man! Wish I had more time on the web!
Old 02-11-2012, 10:38 PM   #534
swyfor5
swyfor5's Avatar
Spent some time going through the "pile" of resto parts tonight. Lined up all the new poly body mounts from Jim Carter classic parts, the bolts, shims,washers,and nuts from LMC. Looks like I have what I need to start to replace the body mounts before I start the process of welding in the replacement panels. I think this is the first step in the floor/torsion box weld in process right?
Old 02-11-2012, 11:20 PM   #535
turp mcspray
turp mcspray's Avatar
Yep, install your body mounts, make sure your doors fit the bedsides, and rockers. Start by putting all the factory shims back where they were. Don't be afraid to change them if things aren't fitting quite right.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 02-12-2012, 09:50 PM   #536
swyfor5
swyfor5's Avatar
Just ordered up a set of DIY4X EZ-INCH's for the 14bolt rear. Thinking I might need them when the shackle flip goes in to help center the axle. Looked at ORD's and seemed like DIY4X's was the same setup for less money. Not sure if I would need to run some degree shims also? Thinking not, because going with weld on spring perches anyway. Thought's?
Old 02-13-2012, 10:38 PM   #537
bigbadchev72
People know me
bigbadchev72's Avatar
Are you going to be doing a High angle driveline or CV shaft soon? If so dont bother welding up your perches until you get your shaft. The driveline side has to point right at the t-case
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 02-13-2012, 11:06 PM   #538
swyfor5
swyfor5's Avatar
Yes Sir, I am planning on running HAD shafts frt and rear. Thank you for that tip! Hoped to slap in some sort of stock 1 ton shafts for temporary, and swap in the HAD stuff when funds allow. As soon as spring comes, hope to get the 1 tons in and mocked up.
Old 02-14-2012, 11:37 PM   #539
swyfor5
swyfor5's Avatar
Got the Painless wiring kit I bought off E-bay today! Looks to be perfect, new in the box. All there, and in great condition. Awesome!
Old 02-18-2012, 08:17 PM   #540
swyfor5
swyfor5's Avatar
Got the new DIY4X ez-inch's today. Cleaned them up good and are now ready for paint tommorrow!
Old 02-19-2012, 08:57 PM   #541
swyfor5
swyfor5's Avatar
Anybody got pic's of a 14 bolt with the ez-inch installed? Got the weld on rear springs perches,ez-inches,upper u-bolt plates, all from DIY4X. Also the DIY4X shackle flip, think I have it all figured out. Just looking for some 1st gen pic's before I get started!
Old 02-21-2012, 08:54 PM   #542
swyfor5
swyfor5's Avatar
Still trying to mock up the 14 bolt weld on rear spring perches,the ez-inch's, and the upper u-bolt plates, all from DIY4X. The center bolt that came with the ez-inch kit does not fit right in the holes of the weld on perches, I can make them fit but just wondering why they do not fit right?Also, the two bolts DIY4X sent with are kinda short for the weld on perch. Also, checked the drivers/left side stock spring perch of my used Dana 60 front axle and the center bolt hole is egged out big time. Went and ordered up a new one from Kert at DIY4X. Anybody have any info on this,or pic's to help me out here?
Old 02-23-2012, 03:37 PM   #543
71blazerdetroit
3rd pic down on my thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=430008
Mount the shackle flips, bolt in the leaf springs , tighten everything down and bolt on the axle while keeping the perches "unwelded".
put the weight of the truck on the axle, then rotate up the pinion until it points at the back of the t-case. (make sure your u-bolts are tight for safety sake)
then tear it all apart and weld them on.
71 Blazer, 350/700r4/241 1 tons dana 60 14 bolt 5.13's locked
71blazerdetroit is offline   Reply With Quote
Old 02-23-2012, 04:20 PM   #544
swyfor5
swyfor5's Avatar
Thank's 71! Anybody else got pic's?
Old 02-24-2012, 12:14 PM   #545
niceguy678us
If you give me a few days I'll be updating my thread. I'm working on finishing the front axle this weekend, the rear is in and finished.
Diy4x: 14B disk conversion kit, 14bff guardsman, 14b razorback shock mounts, FGB52 kit, FG axle flip-n-switch kit, greasable bolts throughout
Ballistic Fab: D60/14b diff covers, Double shear crossover high steer arm kit, 3/4 heim DOM steering kit w/misalignment spacers,
High Angle Driveline: 1350 rear driveshaft with 1350 CV, rear np205 flange kit (will buy the emergency np205 brake kit at a later date as well as the front 1350 driveshaft with 1350 CV), 14b 1350 "u-bolt style" pinion
H2 17" rims w/ 07-10 silverado center caps, 35" Hankook Dynapro MT RT03's, 73-87 1/2 ton 2wd 52" leaf springs front and rear
That's off the top of my head, It'll be more detailed in my thread, as usual.
1970 Datsun 240Z
1972 K5 Blazer Highlander
1972 Chevelle
1959 Apache 3100 SWB Fleetside
2006 VTX 1800f
Build thread:
http://67-72chevytrucks.com/vboard/s...ght=highlander
niceguy678us is offline   Reply With Quote
Old 02-24-2012, 06:02 PM   #546
swyfor5
swyfor5's Avatar
Wow niceguy, look forward to it!
Old 02-24-2012, 07:24 PM   #547
swyfor5
swyfor5's Avatar
Wow,Wow, just scrolled through your thread. Really looking forward to your updates! Still trying to figure out the DIY4X shackle flip,weld on 14 blt spring perches, ez-inch setup.
Old 02-25-2012, 08:14 PM   #548
swyfor5
swyfor5's Avatar
Just ordered up 2 more replacement panels from WES at classic heartbeat. Got the front lower quarter patch panels, just behind the ds and ps doors coming. Still trying to figure out why the new center bolts that came with my DIY4X EZ-inches don't fit right into my DIY4X weld on rear spring perches for the 14 bolt 1 ton axle? The center bolt is designed to go through the spring pack and set into the hole in the spring perch right? I guess I just don't get it? I understand the weld on spring mounts have 3 holes in them to help center the axle, but the spring center bolt does not fit right in any of the holes in the weld on mounts? Any ideas?
Old 02-25-2012, 08:17 PM   #549
VA72C10
VA72C10
VA72C10's Avatar
Haven't done any of the 4x stuff like you are or I'd help...sounds like you're going to be ready to jump into this project with both feet this spring with all the parts you've collected!!!
Old 02-25-2012, 08:39 PM   #550
swyfor5
swyfor5's Avatar
Thank's for watching here VA! Yes, I have been doing my research and hope to have everything ready to get it set up this spring/summer. I know how I want it to work, and look, and all the help from this great site makes it that much easier!
