01-11-2021, 04:10 PM | #526 |
Re: Starting 1966 Factory Short Bed Build, Bagged, 383 Stroker and Muncie M20 4-Speed
Only a small one. I am running a Muncie 4-Speed with a stock Hurtz shifter and a new floor shifter boot. I also just bought a Lokar floor mounted E-Brake. So i will be building a smaller one like for an arm rest.
John 3:16 - Saved me... God Bless |
01-12-2021, 12:08 AM | #527 |
Looking good! Roll Tide!
01-12-2021, 10:43 AM | #528 |
01-17-2021, 07:16 PM | #529 |
updates to the speaker kick panels....
Passenger side starting...
01-17-2021, 07:18 PM | #530 |
more of the passenger side being developed
01-17-2021, 07:19 PM | #531 |
This is the passenger side all cleaned up, after i added the body filler....
01-17-2021, 07:21 PM | #532 |
Got more cleanup on the Passenger side kick panel and the driver side is drying after fiberglass resin was added. After they are both all cleaned up, i will spray paint them with hammered Semi-Gloss black Rust-o-leum paint. I do not want them all shinny or just flat black...
01-17-2021, 07:22 PM | #533 |
Question for you all: Suggestions on how to attach them to the cab?
01-17-2021, 09:33 PM | #534 |
Those snap button things, like you see on home stereo speaker grill cover thingies.
.... or, basically every interior panel in a modern car, I guess, now that I think about it.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
01-18-2021, 10:47 AM | #535 |
Good idea. i will look into it.
01-26-2021, 10:49 AM | #536 |
Update: So i have been cleaning and sanding on the kick panels. They look great. I put on what seems to be a lb of bondo, sanded off 5/8 lb of bondo... lol found the "typical" little pin holes around so now i am using "glaze" filler. That stuff works great... but i am learning to not apply it very thick as it is not needed. LOL anyways, They are about ready to get painted. I looking into the hammered paint.... ya not using that. It just does not look right, so i am going just a Satin black.... Pics to come. Then back to working on the cab.
For the cab i need to get the couple of dash dents fixed, couple screw holes filled and then get the seam sealer installed, then prepare outside of cab, getting all the dents fixed and ready for primer.... FINAALY! lol
01-26-2021, 11:02 AM | #537 | |
I included some images of a repair I did to one of the rear door panels from my dually. This was a SuperGlue repair sanded flush, topped w/the SEM Texture coating, & then SEM interior paint/dye. I don't have any good close-ups of the trim I did w/the actual 'texture' paint but it's much more aggressive.
01-28-2021, 10:27 AM | #538 | |
01-31-2021, 11:43 AM | #539 |
update on the speaker pods. So as much as i hate to say it, i am not a body guy by any stretch of the idea.... so with that said, i decided that i did not want a "Kick Panel" to be super clean and scratch free when i painted just to get "Kicked" LOL so i just went with the same speaker cover i used on the sub-Box.
Now my only issue what to do with the space next to each side of the sub box? suggestions?
01-31-2021, 11:52 AM | #540 |
Kick panels look great! I love that you fabricate tons of stuff!
Not sure what to put on the sides of your sub box...what about a fire extinguisher on one side...and ? on the other? I am going to incorporate a fire extinguisher somewhere in my cab...just not sure where yet. |
01-31-2021, 11:56 AM | #541 | |
Fire Extinguisher is a great idea.... maybe a First Aid kit on the other or ???? Now that you mention that, someone makes corner metal plates if i am not mistaken, i could use them and the set the extinguisher on one and ??? on the other.... First aid kit?
01-31-2021, 02:58 PM | #542 |
I bought these for my speakers...you may be able to get him or you make them without the speaker holes and mount the fire extinguisher on it or make it yourself and recess a place for the extinguisher. I also like the idea of a first aid kit or maybe a small tool kit in case you needed some basic tools on the side of the road.
02-03-2021, 10:57 AM | #543 | |
Fun little note: on Sunday i pick up my new little partner... a seven week old Boston Terrier, name is Zoey. Some of you may remember in the middle of last year i got a little Boston Terrier, named her Zoey and after 4 weeks she got sick, took her into the vet and was told she would not make it, that she had a birth defect and over half her little intestines were dead. Just about did me in honestly. I was amazed at how such a little pup could grab ahold of this big guys heart strings... anyways... Love this breed... so went to the same family for a new puppy, ironically it is from the same parents, has almost the same markings.... and so to honor my first Zoey, i wanted to name this puppy Zoey also. So i may be a bit slower on working on the truck, but i will take a few hours here and there to work on it. Pics will come of little Zoey though... my new shop and cruising partner...
02-06-2021, 11:32 AM | #544 |
So today is brush on seam sealer the cab, then self leveling seam sealer along with working on the cab body, filler and such getting ready for some primer.
02-14-2021, 12:34 PM | #545 |
Little update to the build... well its an update at least.. lol
Here is my newest family member... Zoey 2.0 She is 8 weeks old today, Boston Terrier, my new cruising partner...
02-15-2021, 01:33 AM | #546 |
She’s a beauty!
02-15-2021, 10:51 AM | #547 |
02-17-2021, 06:35 PM | #548 |
Ok back to truck stuff....
Well sort of ... I bought some LED shop lights for the shop and ended up with a couple extra and so i built me a light rack of sorts... easy, cheap... bright!
02-17-2021, 06:41 PM | #549 |
Ok now onto body work....
So i had a dent in the roof that was causing "oil canning" but in reverse sort of.... the oil canning would stay down, not up. So i used some heat form a yellow can of propane gas and water rag to heat and cool the metal to get rid of the oil canning, which worked rather well. then i used a Harbor Freight stud welder for pulling dents and got most of the dent out, not all but good enough for me and then some thin bondo... i will sand that down add more if needed and then final with glase. In the damn middle and rear of the roof are two holes, not sure what for, but they are there... so I will try to correct as much of the dent as possible then weld up the holes. So made why people do this crap.. I am not a body man by any stretch, but I try to get it good enough... if that makes sense. .. Mote pics to come.... By the way, any and i mean ANY suggestions on body work i am all up for!! LOL
02-17-2021, 11:25 PM | #550 |
Hmm, I'm thinking CB antenna or a light of some sort for those two holes
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
