07-27-2018, 11:35 PM | #5601 |
Post Whore
Re: Restoring Rusty
after a few head scratches and purging my mind of the 3 speed how to videos, I found the rather large clip that was holding the remainder of the gear assembly in the tail housing
... and she slid right out in the last pic from left to right (or rear most to front most) we got 1st gear then the reverse slider and then the 2nd gear, my buddy Mopar Seth believes the noise problem lies in there, since it is quiet with 1st gear engaged, but as soon as we disengage it we get the rattle chatter Last edited by Gregski; 07-28-2018 at 09:43 AM. |
07-27-2018, 11:40 PM | #5602 |
Post Whore
Re: Restoring Rusty
nest to come off was the brownish orange plastic speedo gear, the metal clip holds it in place
07-27-2018, 11:45 PM | #5603 |
Post Whore
Re: Restoring Rusty
YALR - Yet Another Lock Ring and the rear main shaft bearing comes off, this one took a little flat screw driver (ok crow bar) gentle persuasion to slip off, this reveals the wavy washer which I was told was an afterthought repair/fix of one of the noises these transmissions like to make
07-27-2018, 11:52 PM | #5604 |
Post Whore
Re: Restoring Rusty
so then things will get loose and we will be able to slide off the rear bearing, the wavy washer, another washer, 1st gear, 1st-2nd + reverse slider, and one syncro
07-27-2018, 11:57 PM | #5605 |
Post Whore
Re: Restoring Rusty
hang in there, almost done, another snap ring, a clutch hub, the last synchro, and 2nd gear slide off
07-27-2018, 11:59 PM | #5606 |
Post Whore
Re: Restoring Rusty
and here i am giving you the shaft
07-28-2018, 12:00 AM | #5607 |
Post Whore
Re: Restoring Rusty
and here are all the bits that make up the main shaft from left to right or rear to the front of the vehicle
note the one shinny new synchro, getting lined up in parallel for replacement |
07-28-2018, 12:03 AM | #5608 |
Post Whore
Re: Restoring Rusty
next it was time to clean the old gasket residue off of the case
07-28-2018, 12:04 AM | #5609 |
Post Whore
Re: Restoring Rusty
it's wire wheelin' time
07-28-2018, 12:06 AM | #5610 |
Post Whore
Re: Restoring Rusty
goodness, how many sides does this thing have
07-28-2018, 12:08 AM | #5611 |
Post Whore
Re: Restoring Rusty
the tail housing also got some love
07-28-2018, 12:10 AM | #5612 |
Post Whore
Re: Restoring Rusty
and pretty soon I had transferred all the old gasket material on to my ol' favorite shirt
Clean Up Fun Level = 0 |
07-28-2018, 12:11 AM | #5613 |
Post Whore
Re: Restoring Rusty
just some random pics of all four new syncros, showing they all be the same
07-28-2018, 08:38 AM | #5614 |
Re: Restoring Rusty
Well you sure ain't no quitter.
Romans 10:9 - The Truth |
07-28-2018, 09:48 AM | #5615 |
Re: Restoring Rusty
I'll second that!
Have a friend who just finished going through a cast iron 70s Mopar 4-speed, which is based on a 3-speed. That means 3rd gear is 1:1 and 4th is an overdrive gear where third would normally be on the countershaft and mainshaft. And like you, he had never done one before, but just dug in and got 'er done!
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
07-28-2018, 09:49 AM | #5616 |
Post Whore
Re: Restoring Rusty
thank you it's that small town farm boy tenacity, I remember one time my dad and I were wrenching in a carport of our 2 bedroom apartment, we were having a tough time with something, and I wanted to quit, and he said "and what are we going to do, cry about it?" and that was that, a boy became a man, ha ha
07-28-2018, 09:53 AM | #5617 | |
Post Whore
Re: Restoring Rusty
07-28-2018, 10:04 AM | #5618 | |
Re: Restoring Rusty
07-28-2018, 11:51 AM | #5619 |
Re: Restoring Rusty
Well done. If one thing racing taught me over the years is that just because you haven’t done it or seen it doesn’t mean you can’t do it.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
07-28-2018, 02:41 PM | #5620 | |
Moderator
Re: Restoring Rusty
Ohhh Crap!!! What the heck was that?
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
07-28-2018, 03:25 PM | #5621 |
Post Whore
Re: Restoring Rusty
07-28-2018, 03:28 PM | #5622 | |
Post Whore
Re: Restoring Rusty
07-28-2018, 03:58 PM | #5623 |
Moderator
Re: Restoring Rusty
An old fart I worked for when I was a youngster told me "You can't get a patent on it. Guaranteed someone else already screwed that up the same way you did."
Lucky that little ball bearing didn't get caught somewhere more important. What let it escape?
07-28-2018, 04:41 PM | #5624 |
Post Whore
Re: Restoring Rusty
No idea maybe the previous rebuilder forgot to put it back in cause I did not find it on the inside anywhere, you would think it would be stuck to the magnet.
07-28-2018, 04:45 PM | #5625 |
Post Whore
Re: Restoring Rusty
well before I realized the detent ball was missing I already removed the counter shaft so might as well walk you through it
I gotta be honest I was pretty intimidated about pressing this shaft out, but it turned out to be super easy and all I needed was a hammer the first two pics show a good view of the idler gear and how it slides side to side - this may be the smoking gun Last edited by Gregski; 07-28-2018 at 10:48 PM. |
