Old 06-16-2013, 08:12 PM   #551
Atommik
Atommik's Avatar
Re: 51 Chevy 1/2 ton, My S10 swap
LOW AD,
I don't think I'll be ready for Back to the Fifties this weekend. If everything goes perfectly this week I might get it road ready. But how often does that happen!!??
6 months ago I thought I'll never be ready, 6 weeks ago I thought maybe I can be ready, now with 6 days to go...I don't think so. But maybe!
Atommik is offline   Reply With Quote
Old 06-16-2013, 10:04 PM   #552
LOW A D
Hope you make it! The last two builds I did were almost 20 hour days for the last few days to get ready for Back to 50's. The truck I just started I'm hoping to drive to the show next year.
LOW A D is offline   Reply With Quote
Old 06-17-2013, 02:02 AM   #553
51Charlotte
Haha, the cards are awesome!!!
51Charlotte is offline   Reply With Quote
Old 06-22-2013, 05:57 PM   #554
Atommik
Atommik's Avatar
A little more progress this week. I finished installing the e-fan. I bought a Painless install kit with temp switch, relay, and circuit breaker. Pretty simple install. The fan is from a Mercedes Benz. It's a 19" puller and moves a ton of air! Basically covers the entire radiator. However today when I was running the engine looking for leaks, the fan wouldn't turn on. Time to double check all the connections.
After installing the fan, it was "safe" to install the hood latch panel and latch.
I didn't want to have to remove the panel to access anything behind it. The hood fit up great, with no adjustment from where it was when I took it apart 2 years ago.
As far as I can tell, no oil leaks, no trans leaks, brakes are good. I've got a couple coolant leaks to track down though...
It still runs a little rough on first start up. I think I will pull out the fuel sender and pump assembly and check out the inside of the tank. Could be some gunk in there preventing good fuel flow.
Old 06-22-2013, 06:09 PM   #555
99 to Life
99 to Life's Avatar
atommik, great news glad it is coming along. 1st if you have coolant leaks, I'd put money on the heater and ranco valve, as both mine leaked, so I just went with an aftermarket heater, which is so so. 2. make sure you have enough fluid in there for your sending unit, I'v heard they don't kick on the fan if it is dry, don't know how true that is. did you power up the fan and make sure it works on its own? running rough? what carb you running? one last note, is the sending unit I'm seeing in that smaller hose going in your intake just for your temp gauge?
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 06-22-2013, 08:25 PM   #556
Atommik
Atommik's Avatar
99,
Carb is an Edelbrock 1406, it's probably 15 years old. A buddy at work over hauled it but was suspicious of the accelerator pump that came in the kit, he put it in but he said it didn't seem right. It was different than the original. So we're looking into that.
The sender that is mounted on the heater hose is for the fan switch. The engine only has 2 "plugs" for a sender. The driver's side I am using for the temp gauge, the other one I was not able to remove the plug from the block. I had a 1/2 inch drive breaker bar on it and it started to twist the square drive end. So, I thought of putting it in the heater hose. Not sure if it was a good idea or not. Maybe I'll need to buy the "dry" temp sensor that goes thru the rad fins. Or I could switch the gauge and fan senders around and see what happens...
I can power the fan up with a battery charger, so I know it works.
I found out quickly that the valve on the heater leaks, I think the heater core is okay. For now, I've just rerouted the hoses to by-pass the whole thing.
Old 06-24-2013, 11:16 AM   #557
99 to Life
99 to Life's Avatar
yeah them ranco valves always seem to leak, I think its like $50 bucks for one with a core charge maybe, don't quote me on that. As for the temp gauge. I'd def swap out your temp switches, I feel the fan switch in the head is your best bet cause it will be hotter and kick the fan on, and have constant fluid on it. In the hose, the switch could be dry and not kicking on, even with the stat opening and fluid hitting it, its just hard to say. I'd just swap em and I bet that is your problem. As for the carb, Id bet thats your issue with rough idling or whatnot. Aside from your timing, an old carb could have the tiniest dry gunk in it blocking your idle circuit, I'd spray a ton of carb cleaner through your idle screw ports. I bought my carb used in great condition, tore it apart and it had tons of sediment of rust in it. I also run a fuel filter out of my tank and bf the carb and I have a brand new tank just to be safe.
Old 06-24-2013, 06:58 PM   #558
Atommik
Atommik's Avatar
I found the source of the coolant leak, one of the intake manifold bolts at the front was not tight. Also discovered a trans fluid leak from one of the lines to the cooler. Should be an easy fix.
As far as the fan situation, I'll be trying 2 things tomorrow. The "Tee" I made for the sender probably does have a spot where air will collect below the sender. So I will flip the tee over to make sure coolant is flowing over the sender.
Also, I'm thinking that I may not have power to the fan wire under the hood that goes to the relay. If that's the case I think I know the problem. I'm using an EZ wiring 21 circuit harness. In the cab area are a gray wire marked "fan power" and a gray wire marked "fan". The wiring diagram says nothing about these wires, but the printed instructions mention wires for a cooling fan switch in the dash area. Since my fan is switched thru a temp sensor and relay under the hood, if I connect the 2 wires under the dash (instead of a switch), it should power the fan wire to the relay.
I'll be trying these fixes out tomorrow morning!!
One of the guys at work has a newer Holley carb he said I can try and see if it makes a difference. If it works out I'll buy it from him.
Old 06-24-2013, 07:36 PM   #559
mknittle
mknittle's Avatar
All in all not bad for a complete build. Truck looks great
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 06-24-2013, 09:44 PM   #560
Atommik
Atommik's Avatar
Thanks mknittle
Old 06-24-2013, 11:31 PM   #561
99 to Life
99 to Life's Avatar
well, if you had a coolant leak from the intake odds are you have a vacuum leak which would def affect your idle circuit amongst other things, make sure you don't have coolant in your oil and check your plugs, could def be a the source of running rough.
As for the EZ wiring, trying to remember off hand here, but yes, def a grey wire in the cab and one out of the cab, the one in the cab. I see what you are saying about tying them together, I think that is what i had to do, tie em together since your not running manual switch, seems to makes sense, its just been a while. I can look tomorrow if I can remember. I hated EZ's instructions, their tech guy is great but its hard to get him on the phone. I really wanted to make my own diagram and post it in a PDF to make peoples lives EZier!!!
Old 06-25-2013, 10:15 PM   #562
Atommik
Atommik's Avatar
99,
I connected the two gray wires under the dash and now I have power to the fan relay under the hood. Problem solved.
Things are getting crazy at work with hail and storm damage so I may need to take a week off from the truck. Hopefully next week I'll be able to wrap up the few little problems and get this thing on the road!!!
Thanks for your help on all of this!!
Old 06-26-2013, 08:06 AM   #563
99 to Life
99 to Life's Avatar
glad you got that going, yeah I looked under my dash and thats how I have it rigged too, you'd think they would just say that in the instructions in the first place, but they don't.
can't wait to see yah get this on the road.
Old 06-26-2013, 12:11 PM   #564
skymangs
skymangs's Avatar
Looking great Atommik. Those last minute Gremlins can be a real pain. We were still messing with fuel pump issues all the way through power tour (this is the 3rd electric fuel pump we've put on the truck).
skymangs is offline   Reply With Quote
Old 06-26-2013, 02:36 PM   #565
99 to Life
99 to Life's Avatar
ahhhhhh you guys are giving me horror stories on these fuel pumps. I may never go Epump now. But good thing I don't mind the old cheap mechanical ones.
Old 07-03-2013, 10:52 PM   #566
Atommik
Atommik's Avatar
After having some poor running/ rough idle, poor starting "issues", I decided to try a different carb. A guy from work had a Holley 750 cfm double pumper that he was not using. That's more carb than I really need, but hey, you only live once!! Bolted it on and it made a huge difference!! Now it runs smooth and strong!!
The old Edelbrock just was too old and full of gunk even after a rebuild.
I just need to fix the tranny cooler line leak(this weekend), install the windshield (tomorrow) and it should be dependable and legally drivable!! Can't wait!!!
Old 07-03-2013, 11:31 PM   #567
mknittle
mknittle's Avatar
Great news!
Mark
My GMC build.
Old 07-04-2013, 04:50 AM   #568
focusedontheprize
focusedontheprize's Avatar
Congrats!
I think some miles are in order...
focusedontheprize is offline   Reply With Quote
Old 07-04-2013, 10:14 AM   #569
99 to Life
99 to Life's Avatar
yeah congrats, If I were you I'd just buy a new 600 eddy or 650 holley or quickfuel carb, that double pumper is a bit much will work but is gonna suck gas and have you running too rich. Glad everything is coming together for you.
Old 07-04-2013, 11:38 PM   #570
chev3600
chev3600's Avatar
Great looking truck, glad to see it almost complete and ready to rock.
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 07-05-2013, 06:49 PM   #571
Atommik
Atommik's Avatar
Windshield in!!!
Old 07-06-2013, 10:25 AM   #572
Atommik
Atommik's Avatar
Well good news, bad news.
Got the trans leak fixed, just a loose fitting on the cooler line,. Bad news truck wouldn't stay running long enough to really test the leak or the cooling fan operation.
Fuel delivery problems. Just not getting enough gas. I guess I' have to open up the tank and give it a good cleaning and then double check the flow from the fuel pump. Of course I thought this problem was solved a couple of days ago, so I added 5 gallons of gas to the tank that I will now need to drain. At least I didn't fill the tank!
Old 07-07-2013, 01:15 AM   #573
51Charlotte
You'll get it sorted out bud. I have faith in ya!
Windshield looks great
Old 07-07-2013, 10:15 AM   #574
mknittle
mknittle's Avatar
Thanks mknittle
I just caught that. What I meant was the little glitches
Your truck is great. you got me to consider painting mine yellow
The color of the week currently is Ford grabber yellow
I am looking forward to seeing some pictures of yours in the outside light.
Mark
My GMC build.
Old 07-07-2013, 01:17 PM   #575
Atommik
Atommik's Avatar
I am looking forward to seeing some pictures of yours in the outside light.[/QUOTE]
Yeah me too!! I had it outside one day last week but didn't think to take any pics...That orange really "Pops" in the sun! Very happy with my choice!!
Thanks again to all for the compliments!!
