Old 05-18-2014, 01:01 AM   #551
lenguini
lenguini's Avatar
Re: Project truck dream 65"
I did my final polish on the trans today, all that work was worth it.It looked good enough to bolt in...,so I did !
The jack me and my bud used was a little less than safe......,but its in !
I had to drill a couple holes for the crossmember,2 lined up at the rear of it which I was not expecting, it should have been a pain in the a.. ! It was nice to have a something go smooth for a change.
I'm going to toss the existing pan and replace it with a high capacity aluminum pan as well as some detailing on the steel components when it comes back out. I will be using polished button heads on the final install as well.
I'm liken the looks of the space down the firewall, that trans shines !
Always a place in my heart for old Chevy trucks:
My build thread-project truck dream 65"
http://67-72chevytrucks.com/vboard/s...d.php?t=510863
lenguini is offline   Reply With Quote
Old 05-18-2014, 10:05 AM   #552
Ta2Don
Ta2Don's Avatar
Very Nice!
… and you have a good eye, that contrast between the white and Shiny…
Well Played Sir!!!
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 05-18-2014, 11:29 AM   #553
lenguini
lenguini's Avatar
Originally Posted by rusty_67 View Post
Looks great, Ed, where did you get those brake line brackets/holders/thingies?
Hey Russ,the brake line clamps are from Earls,then high speed polished by Ed at the wheel !
Old 05-18-2014, 11:35 AM   #554
lenguini
lenguini's Avatar
Originally Posted by Ta2Don View Post
Very Nice!
Well Played Sir!!!
One good eye anyway ! I was wondering if I would be able to see any of the trans after all that work....,yep....,once its on the ground it will be even easier to see.
Old 05-24-2014, 01:47 AM   #555
lenguini
lenguini's Avatar
My first fittings showed up today,as the paychecks roll in so will the braided line and more fittings.
I also in the last few days mounted the wire looms and new engine dip stick.
The cab sail panels are temporarily in place to see if I'm going to run them or not.They are reconditioned mint originals
Old 05-24-2014, 06:46 AM   #556
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
sure is pretty.. Looking nice.. not sure you will be able to drive that thing maybe have to have white gloves to check the oil HA HA
GMR-PERFORMANCE is offline   Reply With Quote
Old 05-24-2014, 10:13 AM   #557
Bomp
Bomp's Avatar
Sat down went through the last 4-5 pages to get all caught up.
Top notch all the way.
Bomp is offline   Reply With Quote
Old 05-24-2014, 10:15 PM   #558
pdxhall
pdxhall's Avatar
Great progress, man. I have to laugh at the stack of wood and the jack. Been there, done that many times.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 05-25-2014, 11:50 AM   #559
Jeff La
Man who'd you get to chrome that trans NICE
Jeff La is offline   Reply With Quote
Old 05-25-2014, 12:40 PM   #560
lenguini
lenguini's Avatar
Well...,I don't have any white gloves but I do have a set I kept as a souvenir from my customs officer at the last border I crossed ! Steve...,Your thoughts ?
Old 05-25-2014, 12:42 PM   #561
lenguini
lenguini's Avatar
Thanks, just hope to drive it in this lifetime !
Old 05-25-2014, 12:43 PM   #562
lenguini
lenguini's Avatar
I'm not sure I want to do it that way again !
Old 05-25-2014, 12:46 PM   #563
lenguini
lenguini's Avatar
Chrome....,that would have been much easier, trust me !
Old 05-25-2014, 12:56 PM   #564
lenguini
lenguini's Avatar
Finally got my motor mounts modified. I spent 4 plus hours making the cut and channel piece to allow for the header clearance,,.I should have taken pics during the process but didn't have the time to spare !
I'm at an approximate 1/2 " plus now between the header pipe and the mount.
Old 05-25-2014, 11:27 PM   #565
lenguini
lenguini's Avatar
I temporarily‎‎ installed the serp system today to get an idea of where the fan will sit in accordance to the shroud/rad.
I still have to get the ac compressor, pretty happy with the ease of the install.
Old 05-25-2014, 11:31 PM   #566
dantimdad
dantimdad's Avatar
Two questions:
1. Where did you get the serp system?
2. Do you have dimensions of the mounts for the tubes in your grill?
Thanks,
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline   Reply With Quote
Old 05-26-2014, 01:41 AM   #567
lenguini
lenguini's Avatar
Originally Posted by dantimdad View Post
Two questions:
Thanks,
Steven
Pm sent.
Old 06-06-2014, 10:10 PM   #568
lenguini
lenguini's Avatar
Well...,its Friday night the lawn is cut and laundry done so that must mean it's time for an update !
There has been some small stuff done lately. I mounted the rad (sort of) and eyeballed where the fan is going to sit along with my new A/C compressor,fuel pump,etc.
I thought about electric but decided to go with a 15" ridged steel racing fan with no-flex aluminum blades. Nothing is going to move air better than this one.
I also got my aluminum trans pan. Its slightly deeper than stock buy about one quart which will definitely help in keeping the temp down. I think my good buddy Chop' figured it was a new food dish.
Oh yah...the engine and trans are permanently mounted in place now. They were in and out a half dozen times, so it feels good to know both are in for good.
Old 06-07-2014, 05:05 AM   #569
pdxhall
pdxhall's Avatar
You're making great progress, man. That's a nick looking trans pan. I've been trying to decide on one. Do you mind me asking what brand it is? The aluminum should cool better than stock steel also and I want to have a drain plug.
Sanity'66
Old 06-07-2014, 11:49 AM   #570
lenguini
lenguini's Avatar
Thank you,its nice to be at this stage....,getting a little easier and finally feeling like Im getting somewhere !
The pan was from CFR Performance.
Old 06-07-2014, 12:11 PM   #571
Bomp
Bomp's Avatar
Must be a great feeling to be putting things on for the last time.
I set all the sheet metal on mine to get a look at it and take some pics the other day to make sure things are going in the right direction on the build and I felt ecstatic.
Your truck is looking Great man!
Old 06-08-2014, 03:02 PM   #572
lenguini
lenguini's Avatar
Last time is a good thing, its been a long stretch to get here and now appreciating that I am !
Thanks for the good words, just checking up on your build and its look'n pretty cool. Keep up the good work !
Cheers,
Ed.
Old 06-08-2014, 03:25 PM   #573
lenguini
lenguini's Avatar
Sunday morn, figured I'd go out to the shop and get a couple things done.
Yesterday I picked up some header bolts and lucky as this style bolt is getting more difficult to find.
Last night I did the final torque down on the trans,bolted the flex plate cover on and shortened up the filler tube for it. The tube stuck out half way across my intake and could not stand the look. I like it a lot better now !
I'm going to get rid of the red plastic lock tab/plug and build a new one when I have more time.
So back to this morn.....,I put one of my wheels on to check for brake line clearance. As I suspected, the tire would have hit it so I moved the line to the front position on the frame for both.
Old 06-25-2014, 11:35 PM   #574
lenguini
lenguini's Avatar
It was a busy last couple weeks. Almost every night in the shop after work atleast until 11:00pm !
More fittings arrived at my door and managed to get my rad support back, so I started putting the rad cover,res tanks,ac bulkhead, etc in place.
Installed the wire loom for the marker/signals at the hood and Bed supports back from the powder coaters which are temporarily bolted into place for the soon to be final bed wood fitment.
I just received my power steering res,rad hose/clamps and fan in the last few days ,so I'm back in the shop later tonight.
Old 07-13-2014, 11:43 PM   #575
lenguini
lenguini's Avatar
Time for more updates...,I installed my rad hose's, Tuff Stuff mini starter, electric choke cover and more fittings and anodized washers.
Also ceramic coated the trans filler tube and installed it in place for the last time, still waiting for the knob and washer that a buddy is machining for its dipstick.
Don't pay any attention to the wax all over the bling !
