#551 |
Re: Starting 1966 Factory Short Bed Build, Bagged, 383 Stroker and Muncie M20 4-Speed
I would agree... Just frustrating for me to fix.. lol
John 3:16 - Saved me... God Bless |
#552 |
Big brown truck delivered my Vintage Air kit. Interesting how that much $$ can be in what looks like such small boxes... lol
Going out to do more body work... oh yippiiieee lol
#553 |
Pics of body work... filled in the holes with weld and now just getting straight... lol straighter... lol
Got the final piece for the March Serp. belt system in... the AC Pump. now get belts..
#554 |
Looking good! It's amazing how much I think they look like engines with the belt system in place. I remember when I put mine on...I said to myself...now that looks like an engine!
#555 |
So very true. I have chased many a V-Belt flying off under hard acceleration or just jumping on it... i know you can make them work, but i just prefer a good serp. belt system. This one from March was not bad, under $600.00 well actually with the covers to match, under $800.00. - Sorry about all the dust...
#556 |
I have been looking for a rear corner panel for behind the seats. I remember that Jason Vannatta with Vannatta Fabrication makes the ones I liked, with or without speakers. I have been buying some stuff from him before he really had the business going and not it is going great! He is really a good guy with some great fab. parts, so maybe jump over to his site and take a look at what he has.
Here are the panels.
#557 |
He does make some nice stuff.
#558 |
question:
I am going to be running air bags. with that said, i want to place the tank and pump in the bed. So, i am trying to see if there is a way to temp. air up the bags? Maybe use like a bike tire valve or ? put air in each bag? run lines back to near the bed area and use these valves? I have no idea, any help? Ideas?
#559 | |
#560 | |
Really appreciate your time to respond.
#561 | |
Once you know your good there, it helps keep your scope for leak chasing to the remaining fittings. The 'T' set-up works good for adjusting the suspension during the build. I also have 'stands' built that are used under the frame rails so that if the air is purged from the system, the truck drops to 'ride height' & remains there. Mine are 4" tall @ the front cab mount; 5" @ the rears so just build the stands to the ride height designed for your application.
#562 | |
#563 | |
#564 | |
May 3-7 my "Older Brother" and my very close friend are all going to vegas. Biden 100 day mark is April 30, so hopefully we are mask free!! On the truck front, i am doing the body work on the cab so it can go to primer and final body work then to paint.... finally. I will build a spray booth in my shop with plastic drapes, filters and box fan. Never done this but 1st for everything. I was planning to do plastic on the floor, but any recommendations from anyone on the booth idea(s)?
#565 | |
#566 |
I like to lay down enough paint, that when I finish sanding out all the defects, I still have paint.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
#567 |
![]() ![]() ![]() Join Date: Jan 2018
Finnegan's garage on youtube posted a video earlier this week of how they made a driveway paint booth
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
#568 |
sounds like a great idea... but i am shooting a matte red. might look at matte clear though.
#569 |
some updates of the truck, not much to see, just body work going on. Almost ready for primer....
#570 |
got the block off panels for AC, not sure how i want to to them.
#571 |
Also, so i want to block out as much if not all the water going into the cowl panel, so i bought the no vent panel, not bad honestly.
#572 |
Really nice progress.
As for painting, not done a complete car (or truck) but done firewalls and the odd panel. Only tips I can give you are. Cover everything you don’t want paint on Sweep the floor. Wet it down and sweep it again. Do a “dry run”. Hard to explain but practice how you are going to paint before putting any paint in the gun. Wear the right protective equipment for the paint you are using. Judging by the rest of the truck you will do fine. P. ![]()
Woody's Build - http://67-72chevytrucks.com/vboard/s...d.php?t=658621 If it goes wrong, I blame the Internet... |
#573 |
Update: Just got my bed sides and rest of bed stuff from LMC and Classic Industries. Damn, i have alot of work to do!! lol
#574 |
Did the no vent panel fit well? I have been eyeing that same piece for a while. I haven't checked in for a while...great progress!
#575 |
Thank you sir. I was actually impressed how well it does fit so far, kinda shocked really. I was prepared to do some work to it, but so far it is a good fit. As you can see, i have no fenders or hood on... so that fitment i am unsure about, but overall i was impressed.
