Old 03-07-2023, 11:38 AM   #551
blazer2007
Re: Restoring OEM Seatbelts
What process to you do to change color, cleaning products , what paint do you use.etc., or have you gone over this in a previous post. I,ve had fairly good luck on my blazer painting door panels and seat belt buckles but would be nice to know what a pro uses.
blazer2007 is offline   Reply With Quote
Old 03-07-2023, 05:26 PM   #552
TKCR
TKCR's Avatar
To change colors of the webbing, they have to get new webbing. I will not use dye to change color of the webbing, it looks like crap. Some people may do it that way, but I won’t.
TKCR is online now   Reply With Quote
Old 03-08-2023, 11:18 AM   #553
blazer2007
I have new webbing. Sorry for the misunderstanding, I was inquiring about cleaning and painting buckle.
Old 03-08-2023, 03:45 PM   #554
TKCR
TKCR's Avatar
When I do the belts, I do all that stuff before they are sent for new webbing. It’s certainly a lot easier and less chance of getting something on the new webbing.
Old 03-09-2023, 11:13 PM   #555
TKCR
TKCR's Avatar
Just finished up this set of 77 Red.
These were a bit rough, so I picked out a better set that I had and completely stripped these down for through cleaning & freshening up the color. Received New Emblems. They were also sent off for New Webbing.
Here are all the Before Pics
Old 03-09-2023, 11:15 PM   #556
TKCR
TKCR's Avatar
After Pics
Old 03-09-2023, 11:19 PM   #557
TKCR
TKCR's Avatar
Here is a set of 1987 Mahogany belts. These were throughly cleaned & restored, and freshened with color. The webbing appeared that have bleached spots, so the decision was made to send them for New Webbing. The webbing color is slightly lighter than the OEM color, but this is the closest match. They also received better used Emblems & Buckle covers.
Before Pics
Old 03-09-2023, 11:21 PM   #558
TKCR
TKCR's Avatar
After Pics
Old 03-12-2023, 07:42 PM   #559
TKCR
TKCR's Avatar
Been working on these for awhile. Both are 1977 Blazer belt, front & rear.
1977 Willow Green
1977 Blue
Here are the before and after pics.
Old 03-17-2023, 05:22 PM   #560
TKCR
TKCR's Avatar
Before and After on a set of 81-86 Blue
Old 03-17-2023, 05:26 PM   #561
TKCR
TKCR's Avatar
Before and After on a set of Burgundy Belts.
Here are the before pics
Old 03-17-2023, 05:28 PM   #562
TKCR
TKCR's Avatar
And After
Repaired the crack is the housing the best I could.
Old 03-26-2023, 05:49 PM   #563
TKCR
TKCR's Avatar
NOT FOR SALE
These were cleaned & restored for someone. Color is Mandarin Orange, 1977-1978. Not quite finished yet, but mostly. Just waiting on more supplies to finish them.
These were throughly cleaned, rust removal and freshened with the correct color. One of the retractor housing has a crack that is being repaired. One of the buckle sleeves was replaced with a good tan part, and then dyed to match. Buckles received new emblems.
Check out the Before & After pics.
Old 03-26-2023, 05:51 PM   #564
TKCR
TKCR's Avatar
And the After Pics
Old 03-28-2023, 08:23 PM   #565
TKCR
TKCR's Avatar
NOT FOR SALE
These were cleaned and restored for someone. Mahogany is the color. Throughly cleaned, rust removal and freshened with color.
Here’s the Before & After pics
Old 03-30-2023, 06:36 PM   #566
TKCR
TKCR's Avatar
Here’s a set of 79-80 Camel Tan belts that I cleaned and restored for someone.
Before
Old 03-30-2023, 06:38 PM   #567
TKCR
TKCR's Avatar
And the After Pics. They received New Aftermarket Sleeves and New GM Emblems.
Old 04-03-2023, 08:19 PM   #568
TKCR
TKCR's Avatar
NOT FOR SALE 67-72 Bright Blue
These were in pretty bad shape, so I replaced a lot of the belts. They had the wrong center lap belt, so that was replaced also.
Then everything was cleaned, rust removal and freshened with Color.
New GM Emblems were used also.
Before & After
Old 04-03-2023, 08:28 PM   #569
TKCR
TKCR's Avatar
After
Old 04-13-2023, 09:06 PM   #570
TKCR
TKCR's Avatar
Here’s another set restored, 67-72 Saddle.
Before pics
Old 04-13-2023, 09:12 PM   #571
TKCR
TKCR's Avatar
After Pics
Old 04-14-2023, 08:59 PM   #572
TKCR
TKCR's Avatar
Finally got a couple sets of belts done for people that have been on the waiting list for several months now. Both are the 1973-1975 2pt. Lap Belts.
1st set is the 1973-74 Pearl Gray
Both sets were throughly cleaned, rust removal and freshened with the correct color. Buckles were disassembled for cleaning and received new GM Emblems.
Check out the Before & After Pics.
Old 04-14-2023, 09:02 PM   #573
TKCR
TKCR's Avatar
Here’s the 2nd set, 73-74 Charcoal
Before
Old 04-14-2023, 09:04 PM   #574
TKCR
TKCR's Avatar
After
Old 04-19-2023, 07:16 PM   #575
TKCR
TKCR's Avatar
NOT FOR SALE 67-72 Turquoise
These were cleaned and restored for someone. Still just trying to get these smaller jobs done and back to their trucks. The weather turned crappy here in Ohio. One day it’s 70 and the next day it snows🤦*♀️. So I took some time and worked on this set. They needed a bit more work. Both the buckle covers were broken and needed replace. And both retractors were not even working. Found that they were both broken, so I found some working springs and swapped those out. Now they both extend & retract again! Everything was thoroughly cleaned and freshened with color. All the chrome had rust removal. And New Emblems were installed.
