01-01-2019, 06:20 PM | #5876 |
Post Whore
Re: Restoring Rusty
remember those pertruding nipples on the back of the big Tach and Speedo gauges, well I had to build things up around them with some 5/16s washers and then use 3//16s on top of them in order to be able to tighten the nuts nice and flush
01-01-2019, 06:25 PM | #5877 |
Post Whore
Re: Restoring Rusty
decided to use one of the backing brackets as a bus bar for the ground, this way I won't have to run 6 separate ground wires, I'll just run one to one of these posts
genius i tell ha |
01-01-2019, 06:32 PM | #5878 |
Post Whore
Re: Restoring Rusty
we are using the bullet connectors for the individual gauge signals
Green = Tach Blue = Water Temp (water is blue when we draw anyways so I use a blue wire) Yellow = Fuel Gauge Orange = Oil Pressure (O - Orane / O - Oil using a little association there to help me remember) note there is no separate signal wire for the Volt meter, it just uses the black for the ground like the other gauges and the red for the positive key on, and that's it TOP TIP: notice how the Orange bullet is mangled a little, the crimping tool did that, so why aren't the others mangled as well, well The Greg stuck them in the female end before crimping those for extra strength in keeping their shape, SMART! ANOTHER TOP TIP: make the Gauge side Male and the wiring harness side FEMALE, that way when you disconnect a gauge the wire that is left dangling under the dash has lesser of a chance to short itself out, as the female end on it should be Shielded, especially on the positive side of things ie the RED wires |
01-01-2019, 07:01 PM | #5879 |
Moderator
Re: Restoring Rusty
Female hot is always a good wiring practice... I try to do that even with connectors that shroud the male pins like Deutsch, Metripack, and Weatherpak.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
01-01-2019, 08:46 PM | #5880 |
Post Whore
Re: Restoring Rusty
ok let's turn to the business end of this operation, now if you think this is bad this is after I already wire loomed the three windshield wiper switch wires
so the whole time I am working on this thing I hear the Devil on one shoulder whispering delete all the wires going to the cluster plug - you don't need them meanwhile the Angel on the other shoulder is saying: just unplug the four yiou need, electric tape the plug and tuck it away you may need some of those wires for power to other gauges later on |
01-01-2019, 08:49 PM | #5881 |
Post Whore
Re: Restoring Rusty
like I said I already wrapped the wiper switch wires in this old 3/8ths conduit, after I did it I ordered some 1/4" on eBay and someday will redo it proper
01-01-2019, 08:53 PM | #5882 |
Post Whore
Re: Restoring Rusty
I plan on doing the same for this High / Low beam headlight switch, gosh I hate non home runs, ie wires that Y into other wires of different lengths and sometimes even different colors
01-01-2019, 08:58 PM | #5883 |
Post Whore
Re: Restoring Rusty
OK, so we divorced the Light Blue (left blinker) Dark Blue (right blinker) Green (high beam) and Brown with Black Stripe (brake) wires from the cluster plug and snipped off the OE ends off of them and crimped on some Female spade or blade connectors/terminals, these will slide directly on our four warning lights
easy peasy |
01-01-2019, 09:00 PM | #5884 |
Post Whore
Re: Restoring Rusty
and here is the Green (high beam) warning light wire getting decapitated and re terminated
this will be the blue warning light |
01-01-2019, 09:11 PM | #5885 |
Post Whore
Re: Restoring Rusty
the Brown with Black Stripe (brake) wire is a two headed snake, I honestly don't recall where both ends plugged into, maybe somebody can learn me
also this is one of them (RED) warning lights that I think only comes on when you're going off a cliff, I don't think it comes on upon starting of the vehicle every morning (I think I'm thinkin' of the Alternator red light there) again correct me if I'm wrong anywho, I snipped both OE ends off and slapped on a blade female recepticle, this will go to the red warning light |
01-01-2019, 09:19 PM | #5886 |
Post Whore
Re: Restoring Rusty
and here they are from left to right: brake, right turn, high beam, left turn signal
I also isolated this strand |
01-01-2019, 09:27 PM | #5887 |
Post Whore
Re: Restoring Rusty
lastly we have the four new wires for our digital gauges, fuel, oil, water, and Tach, these are the mates of those four males we meet earlier
these also are zipped tied together separately, ha ha |
01-01-2019, 09:28 PM | #5888 |
Post Whore
Re: Restoring Rusty
enuff already can we see the finished product Pah Leaze
high RPM? the choke was on, and it's January! ha ha |
01-04-2019, 09:34 PM | #5889 |
Post Whore
Re: Restoring Rusty
so how are the digital gauges? asked no one, lol
well last night I packaged up the broken brand new speedo and shipped it back to Intellitronix, let me just say that their support is awesome, they said that was unacceptable and wanted to make it right, right away, as soon as I provide them with a tracking number of my package they will ship me a brand new unit and then this morning I was going to drive the truck for the first time since installing them, and this happened to the 4 day's old digital Tach! (if you can't tell the plastic piece slid down behind the front lens and is blocking the digital display) |
01-05-2019, 04:44 PM | #5890 |
Post Whore
Re: Restoring Rusty
just a random update, on the account of doing all this wiring I picked up these GB Garner Bender 8" Crimping Pliers part no. GS-388 for $15 bucks at ACE Hardware. Now I won't have to swap attachments on my blue ratchet crimper, I can use that one for proper un-insulated terminals, and this new one for insulated ones
seem to work great, I like em, here is an example of 22-18 gauge terminals being crimped |
01-05-2019, 04:45 PM | #5891 |
Post Whore
Re: Restoring Rusty
does the 16-14 gauge ones nicely as well
01-05-2019, 04:53 PM | #5892 |
Moderator
Re: Restoring Rusty
Your crimps will open up over time. The tool is good enough to produce serviceable crimps. Your process needs improvement. You want the indent in the tool jaws to bear on the solid portion of the connector opposite the split so that it deforms the solid portion of the terminal up against the wire strands and the split section instead of forcing the split open. The lightweight terminals sold by the Borg aren't as durable as the peices you can get from Panduit etc. The alloy isn't as heavy as the industrial brands and it doesn't hold the crimped shape over time. Voice of experience here. I've always intended to do a writeup on how to properly crimp automotive terminals. Time time time time...
And please let us know if and how your repairs were successful. Last edited by hatzie; 01-05-2019 at 04:58 PM. |
01-05-2019, 05:29 PM | #5893 | |
Post Whore
Re: Restoring Rusty
thank yo for that tip, I will definitely start doing it that way, and yes this forum would benefit from a Cimpin' 101 Writeup, please and thank you G |
01-05-2019, 05:41 PM | #5894 |
Moderator
Re: Restoring Rusty
The non-insulated ring terminals with no split are the ones I really like to use on field repairs.
I can add a piece of adhesive lined (sometimes called Marine) heatshrink that extends over the entire crimp barrel and up the wire jacket about 1" to act as a strain relief. The result is very neat and clean and it lasts a very long time.
And please let us know if and how your repairs were successful. Last edited by hatzie; 01-05-2019 at 05:50 PM. |
01-07-2019, 11:08 AM | #5895 |
Post Whore
Re: Restoring Rusty
Prior to your feedback I bought some non-insulated ring terminals online from MOUSER Electronics in Mansfield, TX. Are you familiar with this vendor?
01-07-2019, 12:46 PM | #5896 |
Moderator
Re: Restoring Rusty
Mouser is one of my goto suppliers along with Digikey and Newark (If I'm desperate enough to pay Newark prices).
Good supplier for discrete through hole and surface mount parts. Mouser has a fairly comprehensive supply of Delphi (now APTIV) connectors and terminals. Metripack, Weatherpak, Packard, GT series, as well as Deutsch (and the AMP knockoffs), Tyco Quadlok, ... They actually stock both halves of the odd Delphi Metripack multi-terminal-size disconnect plug that's stuffed behind the Impala RH kick panel that were melted from the defroster wire overheating on my 09 SS. You can find a fair amount of ring terminals and disconnects and the like at McMaster Carr. Sacramento and the bay area are usually one day ground shipping if you order in the AM because McMaster is only 5 hours away in the LA area. My company is doing a Transit ITS project in Sacramento.
And please let us know if and how your repairs were successful. Last edited by hatzie; 01-07-2019 at 01:01 PM. |
01-07-2019, 10:10 PM | #5897 | |
Post Whore
Re: Restoring Rusty
I will paraphrase it for you. Me: What's the word on the street about terminals Hatzie? Hatzie: I don't know I hear a lot of things about connectors pick a topic. Me: You know anything about the un-insulated terminals at the Mouser facility? Hatzie: Good supplier for discrete through hole and surface mount parts. Mouser has a fairly comprehensive supply of Delphi (now APTIV) connectors and terminals. Metripack, Weatherpak, Packard, GT series, as well as Deutsch (and the AMP knockoffs), Tyco Quadlok, ... They actually stock both halves of the odd Delphi Metripack multi-terminal-size disconnect plug that's stuffed behind the Impala RH kick panel that were melted from the defroster wire overheating on my 09 SS. LOL just had me rollin!!! Shoeshine Johnny |
01-08-2019, 01:55 PM | #5898 | |
Re: Restoring Rusty
Thanks for the insight Hatzie. I too have been doing it wrong for a long time.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
01-11-2019, 01:32 PM | #5899 |
Post Whore
Re: Restoring Rusty
"PCV valves are air tight and never cause massive vacuum leaks!"
~ Said No One Ever |
01-14-2019, 09:32 PM | #5900 |
Post Whore
Re: Restoring Rusty
so my warranty repaired/replaced digital gauges (speedo & tach) arrived today from Intellitronix and I think it is worthy to share because their Customer Support and Tech Support has been amazeballz, they even sent me an Oil Temp gauge for FREE
