Closed Thread
Old 10-19-2017, 10:19 AM   #5901
weq92f
weq92f's Avatar
Re: What did you do to your truck today? Chapter II
Been daily driving my '67 for the past 10 days or so. Big grin is about t be gone now that the rain's a comin' so I'll have to put her back in the shop and go back to the normal DD.
My 4 year old has been enjoying the ride up front in the big girl seat too ( thanks to the 3 point belts I installed her seat fits safely in there now )!
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline
Old 10-19-2017, 12:05 PM   #5902
ghalperin
ghalperin's Avatar
I was experiencing some intermittent popping on hard acceleration, so I decided to install a Pertronix 1181LS. It has lobe sensing, so no ring to mount below the rotor. It took less than 20 minutes, including R&R the distributor and setting the timing. I did find out that my points mounting screws were loose, but no more popping and now it starts instantly. BTW, I drive it almost daily.
Glenn
1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca
1929 Ford Model A Roadster - traditional pre-war banger hot rod
ghalperin is offline
Old 10-19-2017, 04:51 PM   #5903
VWNate1
VWNate1's Avatar
Exclamation Electronic Ignition Upgrade
Don't forget to open the spark plug gaps to .040" ~ you'll be amazed and pleased by the boost in power .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 10-19-2017, 08:17 PM   #5904
ghalperin
ghalperin's Avatar
Re: Electronic Ignition Upgrade
I Googled the plug gap change before I installed the Pertronix and was on the fence about opening the gap.
Since you mentioned it, I'll give it a try.
Glenn
Old 10-19-2017, 09:17 PM   #5905
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today? Chapter II
It really does work, you'll be well pleased .
Basic 7th grade physics .
_any_ breakerless ignition drives the system to better output, opening the gaps a little bit forces the coil to provide hotter sparks .
I had an old '76 GMC with 292 that burned lots of oil , added '77 Nova HEI dizzy and opened the gaps to .070" (too much !) and it ran great, stopped smoking and flew through the California smog test easily .
Even points ignition systems run better with .035" , an old racer's trick from the 1950's .
.040" is a good balance for the Pertronix .
FWIW, I have a few twenty plus year old Pertronix Ignitor systems that still work perfectly and have never hiccuped nor failed ~ those who'll tell you they're unreliable are lazy and never took the time to ensure the coil was correct for the Ignitor .
-Nate
Geezer
VWNate1 is offline
Old 10-20-2017, 12:48 AM   #5906
In The Ten Ring
Today I brought my new-to-me 1968 fenders to my house and piled those onto my queen-sized bed. I also changed the truck's oil and put on a new filter. I removed the old hoses, cleaned the water necks, and bought all new hoses.
In The Ten Ring is offline
Old 10-20-2017, 07:13 PM   #5907
Jonny Hotnuts
Temp gauge needle fell off in the 70s. Located it in the bottom of the cluster. Squeezed the barrel and was able to press it on the shaft.
Before
Before close.
After close
After...
Its amazing how much difference a little florescent orange can do to freshen up a tired cluster.
~JH
Jonny Hotnuts is offline
Old 10-20-2017, 07:23 PM   #5908
Duck 37
Smile Re: What did you do to your truck today? Chapter II
Took long bed off along with step bumper, getting ready to use the lwb to swb kit, so far so good.
Duck 37 is offline
Old 10-20-2017, 07:26 PM   #5909
In The Ten Ring
What bed you got? Stepside or fleetside?
Old 10-20-2017, 08:23 PM   #5910
Duck 37
fleetside
Duck 37 is offline
Old 10-20-2017, 08:46 PM   #5911
In The Ten Ring
Finding a stepside step bumper isn't getting any easier.
Old 10-20-2017, 08:59 PM   #5912
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Got my console finished. Stared out brown and is now parchment. I used one of PikemUps cup holders.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
Old 10-20-2017, 09:58 PM   #5913
ghalperin
ghalperin's Avatar
Must be, I shipped my 80 pounder to the east coast. The shipping was more than the bumper.
Glenn
Old 10-21-2017, 07:58 AM   #5914
BugzC10
BugzC10's Avatar
Nice work!
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 10-21-2017, 05:59 PM   #5915
paul blair
Found power steering leak at pressure line. Had to cut the line at pump fitting so I could use two box end wrenches at the pump fitting to loosen. Happy that I did not have to remove the pump and no damage done-waiting for new pressure hose-and hope it fits! 69 K/10
paul blair is offline
Old 10-21-2017, 08:11 PM   #5916
57rookie
Added factory body trim and the junk yard rallies that I put new BFG TA's on.
57rookie is offline
Old 10-21-2017, 08:23 PM   #5917
Duck 37
lines,cables,wires and exhaust removed.Templetes on,ready to drill and cut
Duck 37 is offline
Old 10-21-2017, 08:49 PM   #5918
Already Gone
Rallys add to any truck. Now take that front bumper off and run it over to Alberta Plating and get Monty to chrome it and that will make your truck standout. Just kidding but it does make difference.
Old 10-21-2017, 09:18 PM   #5919
57rookie
I had Alberta plating quote. They wanted $600 to chrome it. I can get a repop for a third of the price....This is my dilemma... Too bad they chard so much to dip it in chrome. I will likely have to go with an LMC repop...
57rookie is offline
Old 10-21-2017, 10:09 PM   #5920
Already Gone
He did mine front and back , on the pictured truck, for 400 in January 2015. I gues he is the only one doing chrome in the West so he has bumped his prices. If you get a repop dont tighten the bolts too much or it'll bend the bumper
Old 10-22-2017, 10:13 AM   #5921
TCCGRIZ
I will agree with you on ty he gap , my 67 c50 with original 327 has the pentronix and I gapped them .40 runs and starts like new .
My 68 ,69, 71 and 72 have HEI'S all running .45 on the gap , I was amazed how it woke up the 292 in my 68
TCCGRIZ is offline
Old 10-22-2017, 04:02 PM   #5922
In The Ten Ring
Just got in from working on the truck.
1). Removed thermostat, going to clean it up and test it....it may not be stuck.
2). Cleaned the old gasket from the water neck.
3). Cleaned out the water neck a bit and even vacuumed the area inside.
4). Figured out what fittings are needed to use the water hose to flush out the water jacket.
Old 10-22-2017, 07:30 PM   #5923
Barnfind46
Barnfind46's Avatar
I got some more done on my rear end swap.Had some "Field Repairs" on the trailing arms and one spring mount was a chunk of steel.
Barnfind46 is offline
Old 10-24-2017, 04:47 PM   #5924
jojomiamia
Painting my engine
Tomorrow, rebuild time
jojomiamia is offline
Old 10-24-2017, 07:32 PM   #5925
VWNate1
VWNate1's Avatar
Exclamation P.S. Hose Service
I highly suggest getting a NAPA power steering filter for the return hose ~ they have a magnet in them that collects any old metallic SWARF .
The reason step bumpers are getting hard to find is : the younger guys all throw them away .
-Nate
Geezer
VWNate1 is offline
Closed Thread
