05-15-2017, 11:37 PM | #576 |
Re: Vintage 4wd Pictures:Other Makes
Couple of IH's
60 K20, eaton HO52, T221, SM420, Dana 44 closed 78 K20 Burb, 14 bolt, NP205, SM465, Dana 44 open 05 Dodge Ram 2500 5.9 Cummins 4x4 |
05-16-2017, 10:24 PM | #577 |
Post Whore
That early Travelall is sweet!
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-17-2017, 06:09 AM | #578 |
Those are both cool in their own ways. I'm wondering what kind of wheel that is on the Travelall. Probably something custom made. My dad had a set of custom made 10" white spokes (looked like Jackmans) for his '62 Land Rover 109 to run 12-15 tires.
05-17-2017, 01:01 PM | #579 |
I've always been a GM loyalist, but far too many non-GM 4x4's made enough of an impact on me in my youth (I'm currently 44) for me to not try to fill the void with the best condition examples I can afford. After so many years of working on GM vehicles, I enjoy and hate at the same time the challenge "off brands" bring when it comes to figuring out how they work and sourcing original parts. Not my first Ford, but one I won't get rid of any time soon is this SWB '77 F150. I haven't done much to it since purchasing it other than fix odds and ends. It has a swapped in 460 that was executed well.
05-17-2017, 01:13 PM | #580 |
Another Ford, but this one a '74 Bronco. I purchased it out west a couple years back and haven't gotten to it yet. I'm more of a preservation person than a restoration person so the plan is to put a softer riding, more up to date small lift on it, clean up the paint a bit, put a white soft top on it, and drive it.
The Jeep is an '86 CJ7 purchased in Missouri. It was very rust free but the paint was beyond saving so I did a light resto on it a couple years ago. It sees extensive dune duty and the inline 6 is a good match for the light weight Jeep. It needs much less power to climb hills than the heavy Chevys. |
05-17-2017, 02:36 PM | #581 |
Lastly, it seems that most people tend to like IH Scouts. Unfortunately, finding one that you can't see through because of the rust is next to impossible no matter where you're located. I had always looked on CL from time to time in my area to see if there was a remote chance a rust free one would come up and one night as a flight was delayed I found the brown one. From NM and totally rust free. Problems are it is a very early Scout II so it has D30 Drum front, super low gear ratio (numerically high), and it had several bent push rods in the 304 which is a common problem with the IH engines if the motor has sat a while without running. After getting it running almost right (flat cam lobe I'm thinking) I figured I'd cut my losses and look for a good drive train and put the good body on the good frame/drive train.
I found the rusty blue one in OH and it checked all of the boxes. 345 that I was able to get running no problem, and overall an unmolested rig with just a ton of body rust. Frame is perfect though and it has disc brakes in the front on D44's with what I consider desirable ratios for what I use them for (3.08's). I tore it apart and the frame and drivetrain are in my garage now. Plan is a 3" lift with 31's or 32's. I had to order springs from Alcan since there are very limited options and what is out there is said to ride like a tank. Not sure what I'll do with the body...leave it as is or go full on repaint/stripes in the baby blue. |
05-17-2017, 09:32 PM | #582 |
Nice ones. I remember seeing your F150 before. I like it. There is a '75 IH longbed 1/2t (2wd) for sale in by town. Actually, I know the guy. It's original baby blue and all there. It has very little rust. Wouldn't take much to fix w/o a full restoration if it was kept in and occasionally driven in better weather. I've always wanted to put one on a GM chassis/drivetrain, so parts and service would be simple while having something different than the GMs I've driven all my life and you see everywhere. That last body style was a stout sum*****. The same look I love in a '69-'72...boxy yet rounded.
05-17-2017, 09:59 PM | #583 |
Yeah, I get what you're saying about the boxy yet rounded look (does that even make sense?) being appealing. The Scout and the Bronco both have that look going for them in addition to the 67-72's. The top and front of the front fenders and how they tie to the grill surround just works.
05-18-2017, 12:13 AM | #584 |
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
05-18-2017, 12:17 AM | #585 |
05-20-2017, 05:52 AM | #586 |
Cool 'uns. I've been GM-only since '82 when I wrecked the '69 W200 I had. I'm not a bigot, though. Always said "I like XXXs, just don't want to own one". It's just preference mixed with familiarity, and a dose of consistency. All of these rigs you guys have shown are high on my appreciation list. I always liked the first Bronco and used to fantasize about downsizing one of my Blazers to that size. Then came the 78/79s. So cool...first full-size, last solid axle, last boxy truck design, and only 2 years. I knew these would be hot. All the pre-80 4wd Fs held their value like the '87 GMs did a long time into the normal dime a dozen used vehicle phase everything goes through before climbing as a hot classic. That baby blue rallye pack is a sharp looking scheme on the last Scouts and Terra. I really like those Terras, too. IH and GMC have always been a notch above in my truck world as these are the light end of real truck companies. Chevy trucks are like an afterthought that became the prominent figure by no merit other than buyer mentality. People who liked the car wanted that brand truck. That's where I started.
Lemme see what I have to show I haven't already. Hard to keep track at this point in this thread, and no way I'm scouring through to check! "There's no such thing as an ugly truck...unless you're a car guy"
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 05-23-2017 at 07:21 AM. |
05-20-2017, 07:02 AM | #587 |
Those are all cool ,I especially like that yellow one ,an International ?
05-20-2017, 09:02 PM | #588 |
Yes, early-50s
05-22-2017, 05:06 PM | #589 |
Nice rides special-K, I kinda like everything, Gm is so easy to build and parts availability so have been my favorites but anything else with the right eye can be built cool and maybe a bit more special.
Mudman.
05-22-2017, 11:23 PM | #590 |
6>8 Plugless........
I really dig that IH DRW in post 576. I haven't found any setting around here like that ever.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
05-22-2017, 11:46 PM | #591 |
Don't see anything around like in that post, all the cool old stuff with personality are mostly gone now.
Mudman.
05-23-2017, 07:31 AM | #592 |
The N/W US and other northern areas seemed to have the most old 4wds. Farther down the west coast and into the S/W they had a lot, as well. Mostly for recreation. Mountainous regions saw ranchers using them...then the recreational ones. It was fairly rare to have a 4wd for daily use around here in the mid-70s when I first drove them, which was just before the 4wd thing exploded onto the market
A set of 78/79 Broncos
05-23-2017, 09:38 PM | #593 |
Ahh, Big Boy Bronco's nice.
Mudman.
05-27-2017, 12:06 AM | #594 |
Post Whore
Of all the WWII 6x6's the IH's had the best look in my book. Here is one that went to work i the woods after the war and survived. Drive it home today $3000.
https://portland.craigslist.org/clk/cto/6113416260.html
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 05-27-2017 at 05:19 PM. Reason: -2 spelling |
05-27-2017, 08:28 PM | #595 |
So cool. I'd keep it as is
05-27-2017, 08:33 PM | #596 |
Post Whore
Me too, unfortunately for me divorce is more expensive than that truck. And there is no way I can convince her that it would be good to have it in case we suddenly have to start going to the woods to get logs in the dead of winter.
05-28-2017, 06:46 PM | #597 |
There's even a hard hat for both of you!
06-04-2017, 09:40 PM | #598 |
Post Whore
Another favorite of mine. I'm not sure if they have been already posted. A friend of my has a 2wd version for a daily driver and I was very temped to buy his parts panel instead of my Burban.
https://seattle.craigslist.org/oly/cto/6153651812.html
06-04-2017, 11:35 PM | #599 |
I saw about the same year Dodge, 4wd also but was a panel w looked like 35" tires on it at a lodge I was working at servicing their propane appliances, was so cool to see it.
Mudman.
06-05-2017, 12:10 AM | #600 |
Proprietor of Dale's Corner
Those old Dodges are so ugly that they're bad @$$
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
