Old 10-18-2011, 08:38 PM   #576
99 to Life
99 to Life's Avatar
Re: Daverods 52
yeah definitely looks like a nice easy install. However, unless you are super against one on the firewall or under the cab this would be the only way I'd run it and it would be my last choice. Once you get your gauges in, wiring harness, possibly electric wipers, duct work etc. It gets cluttered under there really fast. I personally love a good 7.5'' on the firewall over the clean ones, but sometimes clean is nice and is what people want.
also I can maybe see some difference in running the brake line. Especially since you should run coils in your line (to keep them from breaking) it will really bring the lines down into visibility I think.
anyway, I could be wrong, this could be slick and have no qualms but then again, what does. It does look good. others have done it.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 10-18-2011, 09:33 PM   #577
Strodder
Daring to be Different
Strodder's Avatar
Re: Daverods 52
Originally Posted by daverod View Post
Mines in the mail still. Thats just a picture I found. you aready knew that though. What kinda flex plate do I need? How many teeth or does it really matter.
I shuda known that. duh!
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 10-18-2011, 10:23 PM   #578
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
I think I will make a center console to hide the brake lines. I don't think it will block the gages as it seems to be well over to the right side. The wipper motor might be a problem. The handle for the front vent might be a problem. The brace for the dash might have to be relocated. Defrost ducts ? heater ducts? I did'nt want it on the firewall and I was afraid if I mounted it on the frame the exhaust would get in the way. In the pictures it seems that the wiper stuff is more to the left and above the steering col.
daverod is offline   Reply With Quote
Old 10-18-2011, 10:24 PM   #579
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Originally Posted by 72Mountaineer View Post
What are the downsides of that brake setup? I'm trying to decide a setup for my '53. Nice pics !!
I stole the pics.
Old 10-19-2011, 09:10 PM   #580
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
cajundragger did one in his truck. Very cool build. Check it out. Has a nice center console he made out of glass. He's only 19.
Old 10-19-2011, 11:21 PM   #581
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: Daverods 52
Hurry up and get that thing done!
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 10-20-2011, 09:02 AM   #582
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
It's only time.
Old 10-20-2011, 11:11 AM   #583
Purec4
Purec4's Avatar
Re: Daverods 52
New plate for my firewall.
Hey...... do ya want a TN tag??....be glad to send ya one.
looks like the brake mount was a project to do. nice work.
We lust for what we want, weep for what we need...
Purec4 is offline   Reply With Quote
Old 10-20-2011, 02:31 PM   #584
Layedoutsonoma91
Layedoutsonoma91's Avatar
Re: Daverods 52
Daverod, I had a few questions for you if you don't mind. I know you used jeff's design for your body mounts, but Iwas wondering how well they worked for you. The Question I have is do they let you lay the truck out. I want the running boards on my truck to lay flat on the ground. I can make my s10 frame lay out pretty easily, but was wondering if the running boards are at least level with the frame using jeff's mounts, or possibly lower. Build is looking good man!
Layedoutsonoma91 is offline   Reply With Quote
Old 10-20-2011, 03:07 PM   #585
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
My running boards are about 1/2"above the ground when my frame is on the ground. Check the numbers on the pieces when you cut the pieces out one of them was wrong I had to recut it. Back cap should be 4x4.
Old 10-20-2011, 03:10 PM   #586
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
I wish I was done I havn't even started I was just posting pictures of other guys that used that style. Thanks for the offer on the plate. Truth is I buy the plates by the 50 lot. I have plenty. Unless I get another truck that is.
Old 10-20-2011, 03:19 PM   #587
Layedoutsonoma91
Re: Daverods 52
So basically what your saying is, if i were to take about a half inch out of the heigh of the body mounts I could have it lay flat? (in theory)
Old 10-20-2011, 03:52 PM   #588
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
I think your fenders hit before your running boards. The running boards have braces under them so those will hit also.
Old 10-20-2011, 11:52 PM   #589
Layedoutsonoma91
Re: Daverods 52
so i will lay as far out as possible with the mounts the way they are?
Old 10-21-2011, 01:04 AM   #590
57truckguy
Re: Daverods 52
Dave , been watching you build very nice. just a thought you might in the interest of saving space use one of specialy windows wipers wiper motors and control.. totally got rid of all the hardware under the dash and I've had them for 5 years with no failures.. Motor is mounted in the pass side air intake and only a small tube goes up and to both of the wipers.. but you can mount it wherever you want..
57truckguy is offline   Reply With Quote
Old 11-02-2011, 11:43 PM   #591
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Put my brake booster and master in. Was pretty easy. Need to move the handle for my front vent over to the passanger side though. Put some old wood in my bed. Need to go get some bungs welded into my keg. It's going to have a tube on the outside so I can see how much fuel is in it.
Old 11-02-2011, 11:57 PM   #592
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
I think I'll be needing one of those wiper motors. Where did you get it?
Old 11-03-2011, 12:00 AM   #593
99 to Life
99 to Life's Avatar
Re: Daverods 52
love the old wood in the bed. I been thinking of goin a similar route real soon. I have some old barn wood from our barn, had lots of memories skating in the barn. The wood has since been used through most our house and fences so I think I'm gonna keep it goin for my bed.
Glad to see you are keepin the vent. I can't believe people weld them shut. It is such a great feature on these trucks, especially in the summer cause it is basically your ac if you aren't running actual ac.
booster looks good in there.
Old 11-03-2011, 12:07 AM   #594
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Ya, I hear you on the vent thing. It's staying. I tried to find enough 1x wood but I ended up using 2x. When the tailgates shut you'll never know. Still need to get some metal strips to hold it down. I want to get one of those ac coolers that hang on the window but $$$$.
Old 11-22-2011, 12:04 AM   #595
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Anything I need to know about bolting the flex plate on the engine? Good bolts and lock tight? Torque?
Old 11-22-2011, 12:15 AM   #596
bubba327
HOW long until spring??
bubba327's Avatar
Re: Daverods 52
Should be grade 8 bolts if I remember - I remember them as being kind of short threaded. Torque , you may have to check a manual. I do not remember.
I had to shim up starter to get enough clearance between the flex plate teeth and the starter teeth. Starter Shims are cheap at parts house and come in a variety of thickness
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 11-22-2011, 12:28 AM   #597
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Thanks bud. Did'nt think there was much to it. Guess I'll bolt it up and put everything back in. Still messing with the tran mount. So what happens if you don't shim the starter. It just stays engaged? How do you know if you have to shim it?
Old 11-22-2011, 12:31 AM   #598
bubba327
bubba327's Avatar
Re: Daverods 52
I did use some blue locktite on the threads of the flexplate
You may want to check the driveshaft pinion angles just for fun before the tranny gets bolted down permanant
Old 11-22-2011, 12:33 AM   #599
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Took a nice notch out of the block on my 66 by using to long bolts. Not good. Could have been alot worse. I was just turning it over by hand. Fun? I hate that angle stuff. I need to get my drive line cut then I'll shim the mount up or down. I can still move the trans cross member around I've only drilled one hole for now.
Old 11-22-2011, 02:13 AM   #600
57truckguy
Re: Daverods 52
wiper motor kit came from speciality windows. whole kit for 2 wipers..
Had a keg on the back of a bucket T I built several years ago.. Used a float kit from a Jeep to know how much fuel was in it. Back then they were compatable with most fuel guages.. not now they use some different owm reading like 140 to 90 or something. the old chevy ones were 0 to 90 and compatiable with all the aftermaket fuel guages available back then.. 1965..
