Old 08-04-2022, 10:39 AM   #576
kev2809
low n' slo
kev2809's Avatar
Re: 67-72 Electric speedo
heres what i got which should be about done...but id like to add a few things to update this. its very time consuming and trial and error but i love the stock finished look. i ran an 80s camaro tach in mine along with the battery gauge guts in the ammeter face...so its a little different.
to get the factory paint off the lens...use Purple Power. it dissolves it VERY easy. be very careful with it and dont let it run to the other printed areas.
the green paint i found was at Hobby Lobby. it comes in a little small spray can and it matches VERY well imo. i did 3 coats and it came out nice.
i found a 2 wire light socket on amazon that fits pretty good. the base is rubber and does have 4 locking tabs but they fit very nice. if you need to add holes...go just UNDER 5/8" on the hole (i used a drill step bit). all the 5/8 will make it a little loose which is why you see the silicone on one of them.
i havent plugged this in to check on the truck yet so cant comment on that yet (truck isnt even running yet)
for the fuel gauge...i cut out the stock red lens for the oil and temp lights. instead, i cut the high beam and service engine plastics off the old s10 gauge. cut to fit, then mask off and paint over the words not being used or that will show..then you can glue them to the fuel gauge. gives you a stock-ish way to get a high beam indicator and SES light without drilling into anything
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 08-04-2022, 10:41 AM   #577
kev2809
low n' slo
kev2809's Avatar
link for the sockets
https://www.amazon.com/dp/B07H8F322J...roduct_details
also the fuel gauge..
-_--_--_ _________
Old 08-05-2022, 04:36 AM   #578
ls1nova71
ls1nova71's Avatar
Looks good! Nice find on the paint, that makes it easier.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 11-15-2022, 01:48 PM   #579
Hotrod1952
Eric I wold like to order a set of decals. Do you still have?
Hotrod1952 is offline   Reply With Quote
Old 12-19-2023, 12:02 AM   #580
D-n-Tyke
Bringing this back up as I am interested in a set of the decals also.
D-n-Tyke is offline   Reply With Quote
Old 01-02-2024, 11:05 AM   #581
kehstr
kehstr's Avatar
How did you change the piece where the warning lights went?
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 01-02-2024, 05:51 PM   #582
kev2809
low n' slo
kev2809's Avatar
like the actual lens? i cut them off the original gauge and glued the ones from the s-10 on. or are you talking how do they light up?
-_--_--_ _________
Old 01-02-2024, 11:55 PM   #583
kehstr
kehstr's Avatar
Sorry for the vague question. I was mainly asking how you glued them down. Also, how did you get the old ones off without ruining the gauge?
@Chad's Fab
Old 01-04-2024, 09:39 AM   #584
kev2809
low n' slo
kev2809's Avatar
if i remember correctly that red film just pulls right off leaving the holes blank. then, you cut the s10 gauges to fit over them and leave enough to cover the holes. i used super glue to fix them back to the gauges. hope this helps!
-_--_--_ _________
Old 02-04-2024, 08:49 AM   #585
jjzepplin
jjzepplin's Avatar
I am having trouble finding 18–20-gauge sheet metal in my area. Would 22-gauge aluminum work ok?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 02-04-2024, 04:04 PM   #586
Captainfab
60-66 Nut
Personally I think .027" thick aluminum is too thin and flimsy.
Old 02-18-2024, 08:02 AM   #587
jjzepplin
jjzepplin's Avatar
So I went cheap and bought a small cooking sheet from Wally World for $7. It felt pretty sturdy so I cut my piece out of that. It's aluminum but I think it should work and is easy to work with so far.
Old 05-01-2024, 12:30 AM   #588
outlaw5067
outlaw5067's Avatar
I'm interested in a couple of sets of the decals/kits.
1950 Chevy 3100 Pontiac 350, TH350, Chevelle subframe...
1969 Chevy C/10 350, TH350 family owned since new
1996 Camaro Z28/SS #884 LT4 top end, M6, T-Tops... the project
2012 Camaro ZL1 #608 Stock LSA, M6 the Beast
2008 Chevy 2500HD LTZ Z71 CC/LB, 6.6L, Tuned w/ EFILive...
outlaw5067 is offline   Reply With Quote
Old 05-10-2024, 02:42 AM   #589
Richard
If wanting a stock type check engine light in the dash cluster for an LS swap. Acquire a gas gauge from a 40 series + truck with a diesel engine. IIRC the light up position on bottom right of gauge says "engine" Have a cluster with an air pressure gauge to use in my truck and it has this gas gauge. Been a long time since I have looked at it. Maybe different but was appropriate, just remember I am going to use this as an SES light on my truck.
Richard
Richard is online now   Reply With Quote
