05-31-2018, 11:47 AM | #576 |
Re: 67 GMC super custom build
Not my 67 but I thought I'd share my latest acquisition. 2001 chevy 2500hd 8.1l and Allison transmission loaded. I drove this home 700 kilometers and I absolutely love it. Can't wait to tow with it!
06-09-2018, 09:08 PM | #577 |
Test fit my wood bed today. Turned out great. Won't tighten it down till its all done.
06-10-2018, 12:31 AM | #578 |
Looks amazing!
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
06-22-2018, 05:19 PM | #579 |
Had some work done to my firewall. This time it won't be full of body filler. I had the the area around the dimmer switch recesses further down so the auto dimming headlight harness can sit low under the rug and I had an area recessed for the radio foot controller and its harness so it looks like it was there stock. I also had a harness connector added above the speedometer hole to make clean work of Connecting the added accessories I am using. Last one is my thermometer with the gm decal on it.
06-26-2018, 07:56 PM | #580 |
Got these 2 pieces today from a 57 cadillac. Going to see how I can get the fog light circles into the truck bumper.
06-26-2018, 08:33 PM | #581 |
70+ ( Old Skool Club )
You aren't going to run 4 Fog Lites are you?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
06-26-2018, 09:37 PM | #582 |
No. Only one on each side. 57 cadillac had 2 fog lights and 2 signal lights. I am only using the fog.
08-12-2018, 11:03 AM | #583 |
I had these parts removed from a 1967 Buick 400 transmission and I am going to add the. To my th400. These are the pieces required to allow your th400 to change the stall speed of your converter with 12 volts. Gm used this in 65 to 67 Buick old and cadillac 400 transmissions and can be adapted to chevy 400s with 8 bolt cases. It's pretty neat. I got my gear vendor unit as well so I can finish the transmission now.
08-12-2018, 04:18 PM | #584 |
And the gear vendors
08-21-2018, 05:42 PM | #585 |
I got member tbone1964 to calibrate my 4k cable driven tach into a 5k tach and added a tach drive distributer to my engine. Wow did tbone1964 do an amazing job. SUPER HAPPY. With the ti ignition from the 60s I wanted my tach to be somewhat accurate and I don't believe that ti ever used an electric tach on Camaros it came in.
08-21-2018, 10:17 PM | #586 |
How did I get this OLD!
That looks so cool!!!! Old school period correct.
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
08-22-2018, 12:01 AM | #587 | |
08-30-2018, 11:52 PM | #588 |
I have been playing around with swaping my Vacuum gauge for a transmission oil temperature gauge. I got this oil temp gauge from a 1980 corvette and I took an extra gauge face I had and painted how I would like it to look. With the switch pitch converter I've been told the transmission will make more heat. Nothing to be worried about but I would rather this gauge than a vacuum gauge I think. Would be more beneficial if I ever tow. I would put the words "TRANS" on the lens.
09-01-2018, 11:36 PM | #589 |
Well I decided I wanted to keep the vacuum gauge and I wanted a transmission temp gauge so I am getting creative. I know on the 73 87 trucks you can get a tack and fuel gauge in the large right gauge so I thought I can do that too. I also didn't want to see the full needle so it would look proper like the smaller lower needles and I didn't want to mess around my printed circuit. So after lots of thought I came up with this. I am going to have my fuel gauge face reprinted so it all looks smooth but I'm pretty sure I can make this look good. Plus I don't have to mess with my brake/temp emergency lights either. I'm sure. I'll keep playing with it on my spare gauge cluster till I decide if I will do it to my main one.
09-11-2018, 07:29 AM | #590 |
Still Learning
Nice work as always Chewy!
09-11-2018, 08:20 AM | #591 | |
09-12-2018, 12:10 AM | #592 |
No I want to install them in my transmission. I do have another set of wiring which includes the carb switch and dash pot but that's all I have available.
09-24-2018, 09:11 PM | #593 |
Getting my gmc script valve covers started! The ones they should have made from the factory
09-25-2018, 01:16 AM | #594 |
Those covers are so rad! Love it
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903 Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
09-25-2018, 12:00 PM | #595 |
What did you get the GMC script from for those valve covers? Looks killer!
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 1972 Chevy SWB Highlander OLIVE Build thread coming |
09-25-2018, 02:39 PM | #596 |
They are from gmc v6 valve covers
09-25-2018, 03:42 PM | #597 |
So you had to sacrifice a pair of v6 valve covers?
09-25-2018, 04:44 PM | #598 |
I did. They sat in my shed for 2 years. I was going to sell them instead but I really thought this would be the finishing touch on my engine. So I cut them out. At least it worked out.
09-26-2018, 03:30 PM | #599 |
Would like to see and hear details of your welding to the valve covers, Thanks!
09-26-2018, 04:22 PM | #600 |
I never welded them. I had a shop do it. I don't have a tig welder or the skills for something this delicate. I'll post pictures when I get them back.
