07-11-2019, 11:16 PM | #576 |
Proprietor of Dale's Corner
Re: Columbus..the 1957 IH 4x4..
They did a great job!! Maybe customer service isn't dead....
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
07-12-2019, 12:05 AM | #577 |
Post Whore
thanks Dale..!!...im really pleased with how it turned out...the guy I talked to seemed really honest and sincere over the phone...but for what it cost I wouldn't have expected anything less....
07-12-2019, 09:33 AM | #578 |
Yeah, I guess they want you to talk nice about them. It's the best advertisement they can have.
07-12-2019, 02:51 PM | #579 |
Post Whore
Yep ,probably so...but I doubt I'll ever do another dash like this and I doubt my opinion, good or bad, will affect their business....haha
07-18-2019, 02:40 PM | #580 |
Post Whore
Fabbed some new rear cab mounts out of 6x6 angle....to replace the old shackle style mounts that had sagged from age...I'll use rubber pads for cushion and also be able to adjust rear cab height...once the cab is set in place I'll drill the cab side bolt holes and add a gusset...more overkill...but that's me...
07-18-2019, 06:11 PM | #581 |
Do you get tired of praise? I suggest you get used to it if you haven't. Great job as always and the gauges look awesome. Can't wait to see them in the dash.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
07-18-2019, 06:26 PM | #582 |
I cant wait to see the cab on those mounts....
07-18-2019, 09:01 PM | #583 |
Post Whore
Thanks JJ and Dale..!!...I cant wait either...they still working me 12hr shifts nearly everyday...bout ready for some time off...
07-18-2019, 10:20 PM | #584 |
I miss working but I don't miss the 12 hour days
07-18-2019, 10:40 PM | #585 |
07-19-2019, 02:31 AM | #586 |
Post Whore
Stuck the new cab mounts on ...before this ,a 2x4 laying on the frame rail had the cab sitting level with the frame...the new mounts and 2 pieces of 5/16 thick 90 durometer rubber have it sitting about 1/8-3/16 lower than the 2x4...so it should work just fine...I can shim it up as needed...
07-19-2019, 02:48 AM | #587 |
Post Whore
I was also getting ready to put the sealer in the gas tank and found a mess...there was a good amount of rust in the tank so I researched tank cleaner/sealer...Bill Hirsch products came highly recommended...I bought the kit that has the tank flush,etching fluid, and sealer...I went thru the flush and etch process but when I got ready to use the sealer I got to looking in the tank and it looks a mess in there...all kinds of charcoal looking crap along with varnish and oxidization....I've sent off a email and waiting on a responce before I proceed...heres the best pics I can get of what it looks like..
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 07-20-2019 at 02:09 AM. |
07-19-2019, 07:54 AM | #588 |
Cab mounts look good. The tank, I'm not sure, does the black stuff flake off?
07-19-2019, 08:06 AM | #589 |
Post Whore
Thanks Dale...
Yep..I stuck a long screwdriver in there and can scrape all the different colors and it flakes...I'm gonna wait and see what the man says but I may try pressure washing and I think itll make it turn loose...
07-19-2019, 07:06 PM | #590 |
Maybe take it to a Radiator shop to be boiled out .
07-19-2019, 07:51 PM | #591 |
Post Whore
Yep...I talked to Hirsch today and he says it must have been varnished up bad...he also recommended a boil at radiator shop...I called our local shop and he wont do gas tanks...so im gonna have to call around next week and see what I can find...
07-20-2019, 09:37 AM | #592 |
If you can't find someone close to boil it out, when I was a kid, a LONG time ago, the older guys told me to clean out my gas tank with a 3-4' piece of chain and then roll it around in the tank, shaking it around. I did and checked the progress with a flash light and it did clean it up pretty well.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
07-20-2019, 10:55 AM | #593 | |
I know the pieces fit
07-20-2019, 11:00 AM | #594 |
That or phosphoric acid? There’s a thread on rust in the General Discussion section about cleaning metal chemically. I think it was phosphoric but might be misremembering.
07-20-2019, 02:51 PM | #595 |
Post Whore
Yep Robert...I already did the chain thing when I did the initial flush....I'm gonna give the chain thang another shot and see what itll knock loose...
Yeah John...I've read thru that thread several times...it starts out with him using evaporust...then everybody else's rust removal trick...but I think the rust neutralizer I used took care of the rust...at least what I can see...
07-20-2019, 04:09 PM | #596 |
Post Whore
So I dumped a half gallon of purple power in the tank,,,added the chain back and several gallons of water...sloshed it around for about 20 min...I got alot of crap out of it...this isnt 1/10 of the crap I got out...just what I caught with a rag..
I gonna take it to work where we have a steam hose...more purple power and chain...well see what extra hot water will do...
07-20-2019, 05:22 PM | #597 |
Dang, that's a lot of crap in a tank. Good luck with it.
07-21-2019, 01:18 AM | #598 |
Post Whore
well shucks......that didn't work....
I poured in purple power and stuck a straight steam line in the tank and let it run for 30 minutes..let it cool some ...then threw in about a dozen 1" nuts...rolled it around for awhile, dumped it and still got crap all in it...so I filled it about half full of water, added more purple power ,stuck the steam back in and let it boil for about a hour...dumped it all out ,flushed it good ..... and it looks like crap..!!! got some batteries in my bore scope so I can see all around inside... and it looks even worse now that I can see the whole inside.... maybe I can find a radiator shop... if that don't work I don't know what ill do...
07-21-2019, 07:30 AM | #599 |
I'm guessing you need a rad shop to clean it. It's got a lot of stuff left in it? (Notice I said stuff).
07-21-2019, 07:36 AM | #600 |
Post Whore
Yeah...its got all kinds of black scale still in it....even the direct steam wouldnt knock it loose....
Definitely dont want that crap going thru filters,pumps and injectors ..
