Old 04-19-2023, 07:17 PM   #576
TKCR
TKCR's Avatar
Re: Restoring OEM Seatbelts
After Pics
Old 04-24-2023, 06:24 PM   #577
TKCR
TKCR's Avatar
NOT FOR SALE
Been working on this set for a little while for someone. Started out with a crappy set and made them pretty much NEW again.
Both the retractor housings were broken, and the chrome hardware was pretty rusty, as were the retractor mounts. The housings were swapped with better housings. Better hardware, NEW BUCKLES and NEW Lap Buckle were used. Rust removed from the mounts, and all the plastics cleaned/prepped and freshened with color.
Then the whole set was sent for NEW Black Webbing. One retractor had to be sent back to be redone, they installed the belt wrong. That delayed getting them done, but they fixed the mistake and I got it back today.
WOW! This set is like night and day! Something that looked like it was ready for the dumpster now looks damn near new again!
Check out the Before & After pics
Old 04-24-2023, 06:26 PM   #578
TKCR
TKCR's Avatar
After Pics
Old 05-22-2023, 10:10 PM   #579
TKCR
TKCR's Avatar
Before and After. 1987 Saddle Tan to Slate Gray
Old 05-25-2023, 12:02 AM   #580
TKCR
TKCR's Avatar
NOT FOR SALE.
These were restored for someone. This is the 1981-1987 Blue. They were throughly cleaned, rust removed and freshened with the correct blue. Then they were sent off for NEW WEBBING.
Check out the Before & After pics.
Old 05-25-2023, 12:04 AM   #581
TKCR
TKCR's Avatar
More pics
Old 05-25-2023, 09:55 PM   #582
TKCR
TKCR's Avatar
NOT FOR SALE
1980 Blue, one year only. These were cleaned, rust removed from the mounts, and freshened up with the correct 80 Blue. Plastic buckles were replaced with NOS GM metal buckles. New upper anchor covers dyed to match.
Then the belts were temporarily reassembled and sent for New Webbing.
Check out the Before & After Pics. Also included the beautiful truck these will be going in.
Old 05-25-2023, 10:00 PM   #583
TKCR
TKCR's Avatar
After pics
Old 05-25-2023, 10:03 PM   #584
TKCR
TKCR's Avatar
The truck that the 80 Blue belts are going in.
Old 05-27-2023, 08:00 PM   #585
TKCR
TKCR's Avatar
Cleaned, restored and received new webbing.
Old 06-13-2023, 11:37 AM   #586
TKCR
TKCR's Avatar
Doing some work on a set of Mystic
Old 06-13-2023, 11:40 AM   #587
TKCR
TKCR's Avatar
Just a few pics just after some rust removal and cleaning. Stay tuned, still have quite a bit of work to do. These will also be sent for NEW Webbing.
Old 06-13-2023, 08:27 PM   #588
kglowacky
is there a way to repair seatbelts to retract at a oem speed. Mine hardly retract like the return spring is broken or wore out. i have 1978 c10
kglowacky is offline   Reply With Quote
Old 06-13-2023, 08:57 PM   #589
TKCR
TKCR's Avatar
Yep, I get them retracting well again. That’s part of the restoration process. If the spring was broken, t wouldn’t retract at all. Actually the belt wouldn’t do anything.
Old 06-14-2023, 04:16 PM   #590
kglowacky
does anyone sell the springs. mine are pretty non retractable
Old 06-14-2023, 04:47 PM   #591
TKCR
TKCR's Avatar
I have spare parts. But they have to be an exact match to the one that may need replaced. It could just be it needs tightened also. But not actually seeing what it is doing, it is hard to say what it needs exactly. But all this is part of the restoration I do on them. It isn’t all about making them pretty again, it’s getting them functioning also.
But each one of those caps that have springs, they are a specific size and tension. And the tabs that set the cap to the side of the retractor, they are spaced according.
Old 06-14-2023, 07:03 PM   #592
TKCR
TKCR's Avatar
Cleaned/restored a set of Burgundy belts for someone.
Throughly cleaned, rust removal and freshened with color. I was able to get the white spot out also.
Replaced the Upper Anchor covers with better ones. Check out the Before & After pics.
Old 06-14-2023, 07:09 PM   #593
TKCR
TKCR's Avatar
After pics
Old 06-14-2023, 10:17 PM   #594
TKCR
TKCR's Avatar
New Webbing, New Buckles
Old 06-18-2023, 10:05 AM   #595
TKCR
TKCR's Avatar
Changing a set of Mahogany to Black. So those get completely disassembled for rust removal, through cleaning. Then the plastics parts are prepped and dyed black.
These will be temporarily reassembled and then sent for new webbing in black.
Old 06-22-2023, 09:09 PM   #596
TKCR
TKCR's Avatar
Here is a set of Burgundy that was restored and received new webbing.
Before pics
Old 06-22-2023, 09:11 PM   #597
TKCR
TKCR's Avatar
After pics
Old 06-25-2023, 11:28 PM   #598
SunSoaked
SunSoaked's Avatar
TKCR,
I talked to you recently about my bench seat issue. I decided to go with the new LMC bucket seats instead of restoring the OEM bench. I love the seats! However, now I can't stand my OEM Saddle Seat Belts. I'm looking for a set of OEM black or charcoal ones. Can you help? I'd rather not dye the webbing. I'm open to rewebbing them. Let me know what my options are. I'm not worried about the $$, I just want a quality solution. Thanks.
SunSoaked is offline   Reply With Quote
Old 06-26-2023, 07:35 AM   #599
TKCR
TKCR's Avatar
Originally Posted by SunSoaked View Post
TKCR,
I’ll send you a text
Old 06-30-2023, 09:49 AM   #600
TKCR
TKCR's Avatar
Cleaned & freshened up.
Before
