#5976 |
Re: What did you do to your truck today? Chapter II
Tryin' to finish up the soundproofing/Dynamat installation. This big fella takes a lot of material! |
#5977 |
Dynamat appreciated the purchase I bet, nice work.
Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
#5978 |
sat on my roller chair and talked to my pickup up this morning and told him i ordered him a vintage air system. he was happy with me.
Steven '67 SWB, 250ci, 3OTT.......this is my first build...... I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71" |
#5979 |
![]() Before... ![]() After.... (*dont know why my phone made the floor look yellow!) Still need to add about 50 hog rings and pull it tighter but the wife wanted me to do other stuff so I had to stop. BTW, I converted the bottom from 'high spring' to full foam. I replaced the springs with a ridged lower but it feels perfect when sitting in the seat. It may be a little stiffer than if it had the lower seat springs but it feels perfect to me. ~JH |
#5980 |
Pretty close colour match on seat too, nice difference.
Mudman.
#5981 |
After pretty much just driving the truck for 20 yrs since I originally built it, a few repairs/upgrades were way past due. Fixing to move to NC, so was time for a new steering box & front sway bar. Also finally got around to making the shock relocation brackets for the rear & modifying the 32 Ford track arm to get a better angle. truck rides much better now & will be ready for the curvier mtn. roads.
I called my stockbroker last week and asked him what I should be buying .......... he said "Canned Goods and Ammunition". ![]() |
#5982 |
Replaced the carpet. Had to be done since my master cylinder was leaking into the cab. Had about a 12" wide strip of carpet and pad that had soaked up the leak over the however many years it was leaking. Had to clean out all the soft paint and brush all the rust and treat it.
I also put down some insulation. I researched a little more than I wanted to on the subject and decided to try an alternative route. I purchased a couple 24"x10' rolls of Reflectix double reflective insulation, for about $11 a roll and spray glued it to the floor, let it dry for a day and then put the carpet in over it. Install was easy and everything seems to be working well and staying where is is supposed to. ![]() ![]() ![]() ![]() |
#5983 |
cut holes for my new A/C (vintage air), taped off everything today to shoot the inside tomorrow
#5984 |
Replaced my spark plug wires, cap and coil. Coil fixed my random cut off issue. Discovered my rear wheel cylinder was leaking. It's always something but enjoying the journey.
#5985 |
Starter, solenoid, and two battery cables today. No problems, started right up.
#5986 |
Installed a new radiator fan shroud, only to find out that the Flex-a-Lite fan that came with the truck is too big! No wonder it didn't have a shroud... And what happened to NAPA? They don't carry red-blooded American Chevy V-8 parts anymore? All I want is a stock regular old clutch fan for my truck. I thought it was mandatory for NAPA to have that stuff on hand and within reach at all times. I was looking forward to shopping at NAPA and chewing the fat with the old timers behind the counter now that I actually own a piece of living historic cast iron blocked truck, but sadly, they have become mainstream sellers of Subaru windshield wipers and discounted hand cleaner... I blame the internet!!!
#5987 |
Wow, surprised Napa is going that route, maybe just your store or certain ones depending on size and location, hope that's all.
Mudman.
#5988 | |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#5989 |
![]() Join Date: Jul 2016
Drove it to breakfast & flirted with the cashier. She just likes me for my ride.
1969 GMC 2500. 250 I6, 4-speed w/ granny low |
#5990 |
I ordered a replacement fuel filter for the one I cannot figure out where I put it and I picked up some more fuel line clamps.
#5991 | |
laying low
![]() Join Date: Mar 2001
While all of us want the best parts we can't stomach the high prices. A flex fan looks a lot more reasonable and they rarely wear out.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#5992 |
Hey @sellersrodshop ! (Love the fact you're flying the Gator flag in TN!)
I'm fixin' to do some steering work myself. Wondering what you settled on for a steering box and sway bar. RedHead? Did you have/replace the damper too? Regards, iriereggaeman |
#5993 |
I did a bunch of non exciting stuff like hunting for rattles,hooking up gauges,oiling the cables to the heater control,changing the valve cover gaskets and aiming the headlights.Oh,and vacuuming the floor again because the dang leaves keep coming out of the vents.
#5994 |
cut the holes for the A/C vents a couple of nights ago
then bought a small amount of paint shot the inside of the cab and the doors today
#5995 |
couple more
#5996 |
That is a nice blue, kind of an ice to it.
Mudman.
#5997 |
![]() Join Date: Feb 2009
Flipped this over yesterday, so we can hit the backside. The body guy is doing a great job. He has in mind a bed-liner coat out of the gun. He says most people spray light or heavy, but he's in-between. Leaves a near semi-gloss finish. We're going to hit the front and rear wells with the same, but I'm going to ask we dull it down some for those. Close to satin anyway. Looking forward to results.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#5998 |
Solved the problem of engine cooling fan. Searched the pick and pull down the street and came up with a 7-bladed fan from a 1990 GM car with a 305 v-belt drive and mated it to a fan clutch from a 77 Chevy pickup. Bolted right on and fits nice within the shroud from LMC. Cools the engine real nice, quieter than the flex-a-lite, and will suck your shirt sleeve through the radiator! Cost: $15.
#5999 |
![]() Join Date: Mar 2013
Progress has been extremely slow. I was able to "dig" out the bed bolts. 3 layers of spray in bed liner. That was fun. I also started on a bed cart for when I remove the bed.
#6000 | |
Flying the Gator flag here is due to me growing up in Sanford. Actually went to Lake Mary HS for 2 yrs...
