#6001 |
Post Whore
![]() Join Date: Aug 2014
Re: Restoring Rusty
parts starting to show up
other than the obvious things like engine mounts and different exhaust manifolds, the two biggest differences are the fuel system and the wiring system FUEL SYSTEM - unlike the small block Chevy, the LS(ish) engines use fuel injection which means pressure 10 times that of the SBC WIRING - below I show the components needed to roll my own fuse block, I will be following Brandon's instructions found on Fuse Block and OBD2 Port Wiring Information with the exception that I will not be lumping multiple components on the same fuse like he does, so for example in my design the coils will have their own fuse and the PCM will have it's own |
#6002 |
Post Whore
Re: Restoring Rusty
so it shall be written, so it shall be done, the LS Swap commenced at 2100 last night - being a one man circus act I decided to pull my Edelbrock Estreet heads off this Milk Shake Machine whilst still in the truck, and that engine bay was recently cleaned and painted but then I ran old valve covers on brand new aluminum heads and that gyzered oil all over my firewall, before switching to those super awesome tall and cast BRODIX beauties, whah whah whah, we shall clean that up too
#6003 |
Post Whore
Re: Restoring Rusty
my solo hood liftin' days are over, luckily we had 4 teen boys for a sleep over for our son's graduation so they did the heavy liftin' ... and the stage was set
#6004 |
Post Whore
Re: Restoring Rusty
the rest was a solo act, but this wasn't my first Rodeo so it was out in a Jiffy...
a heavy duty floor mat makes for a great core support shield, who knew? just flip it upside down for leakage protection |
#6005 |
Post Whore
Re: Restoring Rusty
getting stuck in this garage floor crack was the worst of it
#6006 |
Post Whore
Re: Restoring Rusty
and then I got to clean up the oily mess left behind from me being cheap and trying to run my old original valve covers on the brand new aluminum Edelbrock E-Street cylinder heads - those two just didn't pair very well
#6007 |
Post Whore
Re: Restoring Rusty - Engine Noise
Of Note: this is where I have something interesting to share, some of you may recall that I spent the last 4 years chasing a clicking clacking noise which I thought was:
1. rockers 2. exhaust leak 3. bearings 4. fuel pump 5. distributor 6. I forget what else I tried to blame it on well, when I went to pull of the passenger side clam shell motor mount to transfer it to the LS engine I realized it was only barely held on with one bold, the other two fell out !!! |
#6008 |
Post Whore
Re: Restoring Rusty
with the engine bay clean enuff for the girls we go out with... it was time to drop the new(ish) LS engine in, and I would be lying to you if I said it was easy or that I am done, the engine likes to sit tucked way back and I need to go around and loosen all the frame mounts to slide them forward as much as possible to get that engine away from the firewall some
to be continued... |
#6009 |
Post Whore
Re: Restoring Rusty
I don't usually do LS Swaps, but when I do I ensure it's 105° F out!
engine is mounted trans is mocked up using one of my four trans cross members (not too fond of this x-member, prefer my double hump ) driveshaft is at least 3" too long so I might get a new one made as this one is out of an 305 ci El Camino it's one oof them 3" tappered down to like 2 1/2 at each end Last edited by Gregski; 06-12-2019 at 03:29 AM. |
#6010 |
Re: Restoring Rusty
Looks like it belongs there..I'm just thrilled that I don't have to read all that carburetor mumbo jumbo stuff anymore. I had no idea what the heck you were talking about half the time. LOL
#6011 |
Post Whore
Re: Restoring Rusty
#6012 |
Moderator
![]() Join Date: Oct 2008
Re: Restoring Rusty
Looks like you did an AC delete.
I assume the 4.8 & 5.3 have a separate drive belt for the AC just like the 6.0L
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#6013 |
Post Whore
Re: Restoring Rusty
#6014 |
Moderator
Re: Restoring Rusty
It's a challenge to use the Gen III AC compressor in stock dress due to frame clearance issues.
#6015 |
![]() Join Date: Jun 2015
Re: Restoring Rusty
Try on the radiator and the fan shroud. I was taught the fan should be 1/2 in and 1/2 out of the shroud for the best results.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
#6016 | |
Re: Restoring Rusty
Consider moving the engine forward enough to use your existing driveshaft. That will likely preclude using the mechanical fan, but electric fans may be cheaper than shortening the driveshaft.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
#6017 |
Re: Restoring Rusty
Using electric fans simplifies the air intake system as well. There is plenty of room to use a stock air intake with the engine slid forward. Also, it gives you the room to use the A/C compressor in the stock location should you change your mind in the future.
My truck with the mechanical fan doesn't even have a shroud and it never gets over 197* |
#6018 | |
Post Whore
Re: Restoring Rusty
1984 C10 Project ---- LS Swap Part 1 (Motor, Mount Adaptor Plates, and More) |
#6019 |
Post Whore
Re: Restoring Rusty
I heard that too, and when it comes down to it, and I am talking 20 years as an adult (not teenager) of fiddling experience as long as your TIMING yes your timing is in order and you have the proper water pump (not over drive not under drive pulley) and you have a proper radiator and of course no air bubbles, the fan shroud is moot, it is more there for safety and protection than cooling, so it's role is to prevent the metal fans of yesteryear from cutting your fingers off and not so much for routing the air, when you are cruising at 75 MPH on the freeway there is a wall of air heading towards the engine, just sayin'
#6020 | |
Post Whore
Re: Restoring Rusty
#6021 |
Post Whore
Re: Restoring Rusty
alright we hit our first snag, the stock 2001 GMC Sierra truck exhaust manifold on the passenger side hits the frame rail, (and no we are not going to cut the structural integral component of this future land speed record holder)
#6022 | |
Post Whore
Re: Restoring Rusty
#6023 |
Re: Restoring Rusty
Trailblazer manifolds fit great.
#6024 |
Post Whore
Re: Restoring Rusty
#6025 |
Post Whore
Re: Restoring Rusty - LS Lesson Learned #3.
some guys can pick up on this just by reading stuff on the InterWebs but I'm too dumb for that, so I didn't realize this until I went to plumb and wire it the 1999-2007 LS truck engines that we use for LS Swaps do not monitor the Oil Pressure with the computer aka the PCM let me say this again, the computer does not care what the Oil Pressure is on these engines, so a lot of guys unscrew the $55 dollar OEM oil pressure sending unit (located in the stock location on the top driver side back of the engine block) and screw in their aftermarket sending unit in it's place (using a metric to standard adapter of course) and just run their aftermarket gauge or their stock oil pressure gauge * I am quickly realizing that the jump from our trusty distributed carbureted second generation SBC engines to these Third Generation LS based engines is not as intimidating as one might think, here are four examples: 1. they only use one computer for both the engine and transmission management not two Last edited by Gregski; 06-13-2019 at 10:49 AM. |
