12-10-2017, 01:42 PM | #6051 | |
Good Point !
[quote=harpo231;8101377]
RE : Rochester leaks-a-lot Carby . I didn't notice if it's a Quadrajet, if so they're *very* good carbys but have some details , TOMCO used to make the jet well plugs and improved inlet fittings along with brass floats . TOMCO is carried by NAPA among others . Be gentle with it ! . more Quadrajets were ruined by ham fisting than anything else . They're good because they're designed to be progressive in use so as long as you don't stomp on the foot feed and open the secondaries they're really economical . Rockaotuo.com sells some Mid West rebuilder's carbys and I'm always impressed with the quality of both the cores used and their work . Not so with most local rebuilders who simply bead blast an old junk core and slap a Chinese kit in them and never bother to do the myriad adjustments..... If your current carby has a thin metal stamped tag on it, it's GOLD ~ never let go of it, they'll B.S. you at the Partshous, don't ever let go of any core until you personally are satisfied with the job .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
12-10-2017, 04:31 PM | #6052 |
Re: What did you do to your truck today? Chapter II
After months of shimming my starter trying to get it to work I broke down and bought a starter for a 1997 GMC C 3500 5.7 truck. Removed about 10lbs. I forgot what it's like to get in my truck and start it right up. It works beautifully. Also replaced a leaking wheel cylinder, now I have to get my wife to help me bleed the system . She's going to love that.
12-10-2017, 04:47 PM | #6053 |
Such a tiny little thing ! .
I hope you replaced both brake cylinders, it is false economy to replace only one side ~ brake parts are to be serviced and replaced in axle sets .
12-10-2017, 04:55 PM | #6054 | |
laying low
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
12-10-2017, 05:13 PM | #6055 |
12-10-2017, 05:24 PM | #6056 |
laying low
Doh!! Good thinking.
12-11-2017, 10:14 AM | #6057 |
Well, it wasn't today.....Saturday actually, but Raymond got a much deserved new set of tires. As close as I could tell, the old Hankooks were put on at least 15, maybe 20 years ago....lots of tread, but drier and harder than a popcorn toot. I took him from 235/75/15 AT to Cooper Cobra 255/70/15s....really like the look & ride. Now if I could get the dash lights consistently working.....
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
12-11-2017, 02:10 PM | #6058 |
Installed one of Boyd's tanks and installed some 5 lug rotors so that we could try on some new/used shoes! Scored the Vintecs on craigslist😎
12-11-2017, 05:43 PM | #6059 | |
70+ ( Old Skool Club )
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
12-12-2017, 02:01 AM | #6060 |
Added a couple of lights.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
12-12-2017, 08:35 AM | #6061 |
12-12-2017, 10:26 AM | #6062 |
It really does...I looked at several trucks with 275/60 15's and several with 255/70s & kept coming back to the 255s. I've had a couple of sets of these on other trucks and really liked 'em.
12-12-2017, 11:41 AM | #6063 |
I built a smoke machine for finding vacuum leaks last night. Works pretty good. Makes a LOT of smoke.
12-12-2017, 04:03 PM | #6064 |
Smoke Machine
It needs a LUCAS sticker.......
12-12-2017, 04:04 PM | #6065 |
Re: Smoke Machine
12-12-2017, 09:58 PM | #6066 |
12-12-2017, 11:31 PM | #6067 |
I'm editing the DIY build video right now!
Edit: Here is a video of how I built it and in action: https://youtu.be/eFI2ovUYFFU Last edited by beaterku; 12-12-2017 at 11:58 PM. |
12-14-2017, 12:23 AM | #6068 |
Added a wreath... probably should have done something more constructive. First post, by the way. Truck is my daily driver (and only 4 wheeled vehicle).
12-14-2017, 12:49 AM | #6069 |
laying low
Welcome aboard Stew. Good looking stepper.
12-14-2017, 01:19 AM | #6070 |
Received a part from Summit, a piece for the fuel line.
12-14-2017, 01:38 AM | #6071 |
Welcome aboard Stewsclues nice truck. Tell us more about it.
12-15-2017, 11:24 PM | #6072 |
Learned how to remove front coil springs today. Like everything else on these trucks, it was easier than expected. This is how I did it.
I read where one of the members secures the spring by running a chain through the spring and bottom control arm. If you ask me, that's exactly how you do it. Doesn't take much effort, and might save your life. Course that chain placement may not bode well for a floor jack placed underneath the spring, but I read in a number of places to jack up the outer end of the control arm, so I removed the zerk fitting and did just that. I only raised it an inch or so, because the only things on the frame are the front suspension, and the engine and transmission. It worked well. Backed the nuts off maybe 3/8" and went at the ball joints with a pickle fork. I had to back off the floor jack some, I believe to release the lower joints. Then I lowered the control arm, and that spring is pretty well loose. I say pretty well loose, because like dummy I was talking to someone, and forgot to re-secure the lower control arm with the floor jack. Then I took off what I believe was the top nut. Yeah, the lower control arm met with the concrete. Really, there was little to no tension on the spring at that point. No harm no foul, there was less force than I'd expect, but don't do that................ I cut the tops of the rivets with a Dremel. It's clean, but I went through 4 wheels. Took a chisel to the cuts and it made for a nice surface to drill. I used oil of course, and kept the bits cool, and didn't waste a single bit. That said, I only drilled a 1/4" diameter. I punched the first one out, but left the rest. I may see if it's better to remove them with the control arm off. Anyone know how large the rivet holes are? I'd guess 3/8". How about replacement bolt size?............... Something tells me I shouldn't have drilled all the way through those rivets, and just punch them out.............. EDIT: Yep. I should have invested in a good air chisel. I'll save it for another day, do it the hard way........Ha!. Don't know how to install cleanly yet, but I may get one of these to avoid scratches. http://www.eastwood.com/fairmount-to...ompressor.html Other ideas for install appreciated. Other than that, I agree with everyone who says so, don't use coil compressors to remove front coil springs. Now to figure out how to remove ball joints.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 12-16-2017 at 01:08 AM. |
12-16-2017, 01:52 AM | #6073 | |
Good on ya, Derek |
12-16-2017, 02:56 AM | #6074 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
12-16-2017, 03:14 AM | #6075 |
When I did my frame, I removed over 60 rivets. I have a Snap-On air hammer and used a new Snap-On chisel bit. It cuts the rivet heads off like butter. After cutting off the heads, I’d swap out the chisel bit for a punch bit and knock out the rivet. Easy peasy. Wear headphones and apologize to the neighbors afterwards.
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod |
