12-16-2017, 08:09 AM | #6076 | |
Re: What did you do to your truck today? Chapter II
I rebuilt my turn signal switch. |
12-16-2017, 08:58 AM | #6077 |
BlahBlahBlah
I haven't even started my truck up for a week or three. Got a notice that the license tabs are due January 1st. Maybe Ill take it for a spin and get my new tabs (some of you call em tags). One hundred and six bucks to the state.
12-17-2017, 04:25 PM | #6078 | |
Upper Ball Joints: Happy to say all the holes for the upper ball joints were done cleanly with a drill. I drilled through to 9/32", and the top plates to 19/164. Then I used a punch, which probably didn't do much. It was simple to remove the plate off with a pickle fork. Just traces of rivet left and simple to remove. The holes are 3/8". A tight 3/8", but will tap easily. I figure the bolts for replacement ball joints are 3/8-16. Lower ball Joints: I "rented" an Evertough ball joint press. As a disclosure, I don't know what the (*^ I'm doing. At any rate, I don't believe this tool works as intended, at least not for install that I can see, because the ball joint is too tall or the sleeve they provide is too tall, pick one. However, I noticed the "pin" on the threaded rod of the tool pulls off, so I removed it. The ball joint stud then inserts into the threaded rod and will press out. Then I reinstalled the pin, and used a plate on top to remove the outer perimeter of the ball joint. It was very easy.................. Unless I'm missing something, there is no snap retainer ring with the original ball joints.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
12-17-2017, 06:16 PM | #6079 |
I hooked up the battery tender today. I use my K10 as a weekend driver, but winter arrived in New Hampshire last week, the roads are covered with sand and salt, so it will sleep in the garage until April.
12-18-2017, 10:15 PM | #6080 | |
Years ago, I did some that were a little loose in the arm. We tacked them in with the mig and never had an issue.
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod |
12-19-2017, 11:37 AM | #6081 |
New to the forum , figured I introduce myself...with a few truck pics...
I have a 72 GMC truck...original longbed cut short...actually a 78 frame with a 72 3/4 ton cab but the 1/2 ton axles etc...8 inch lift kit and converted from 2x4 to 4x4 So you see, quite a Frankenstein but I love my baby :-) Cheers, Ralph |
12-19-2017, 04:48 PM | #6082 |
Welcome aboard ,good looking truck.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
12-19-2017, 05:12 PM | #6083 |
Well, today i gained a headache.
I figured out that the m/c i just put on may be the wrong one. I also snapped my right rear bleeder valve. All of this, after completely rebuilding my front brake system, and changing all brake lines. Was really hoping to not have to rebuild the rear brakes yet. Oh well, old truck problems. |
12-19-2017, 05:17 PM | #6084 |
Repeat after me! Old trucks are fun! Old trucks are fun! Old trucks are fun!
68' with no bells or whistles unless I add'em. |
12-20-2017, 12:38 AM | #6085 |
I just put snownmobile electric hand warmers on my blower. Canadian living eh. The hulk is ready for more snow.
12-21-2017, 05:19 PM | #6086 |
P01s, going old school! When I get ambitious I'll paint/powder coat the wheels white so they really pop.
72 White Cheyenne, The Ghost |
12-21-2017, 06:50 PM | #6087 |
70+ ( Old Skool Club )
Nothing wrong with P01's..
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
12-21-2017, 07:20 PM | #6088 |
Got the floor shifter installed. These things are finicky abut the end result is worth it!
Oh, and new shoes |
12-22-2017, 12:14 PM | #6089 |
Driving it to Work!
12-22-2017, 02:13 PM | #6090 |
Got the heads off. Ready for the head work and new roller cam install to begin!!!!
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
12-23-2017, 01:43 AM | #6091 |
At the body shop.
Got this done again, wanted to since I bought dad's truck back.
" That didnt make it any newer " " Dont antique the equipment " |
12-23-2017, 03:04 AM | #6092 |
*VERY* nice ! .
? Did you do the painting or have it done ? .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
12-23-2017, 03:23 AM | #6093 |
At the body shop.
No, I wish I had his talent. A local pinstriper did it for me. Aged it a little @pinstriping_dan on ig
12-23-2017, 11:00 AM | #6094 |
A *very* nice job there .
12-23-2017, 03:49 PM | #6095 |
Looks great! .
... Click here to see thousands of 'Abandoned & Neglected' Chevy trucks rotting away... ... |
12-23-2017, 06:19 PM | #6096 |
Old member
Installed the pusher bumper and 4 new rear tires!
12-23-2017, 08:42 PM | #6097 |
Power disc brakes, rebuilt rear drums, all bew brake lines, rebuilt front end, new spindles, ball joints, tie rod ends, etc....
12-23-2017, 10:20 PM | #6098 |
I pat mine on the rear every time I walk by
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
12-23-2017, 10:33 PM | #6099 |
Nice rear .
12-24-2017, 01:03 AM | #6100 |
That rear is an artistic shot, looks like a painting.
Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
