Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 06-09-2019, 03:48 PM   #601
likaroc13
Rollin' Old Skool
Re: Our "What are we going to do?" 66 Suburban Build
Originally Posted by RockTonka View Post
We completely scraped/cleaned the underside (that was a PITA) and brushed on a heavy coat of black implement paint.
Bet that was a neck & shoulder workout, but it looks good! Started to try something similar on my Tahoe & quickly decided that’s not happening without a lift, lol.
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 06-14-2019, 12:51 AM   #602
RockTonka
RockTonka's Avatar
Smoothed the firewall a bit and then primered and painted it...the original Balboa blue.
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 06-14-2019, 09:51 PM   #603
RockTonka
RockTonka's Avatar
and body back on chassis...
My build thread
Old 06-15-2019, 01:45 PM   #604
piratexpress1369a
piratexpress1369a's Avatar
That looks awesome..how long before you are back driving it
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 06-16-2019, 02:04 AM   #605
RockTonka
RockTonka's Avatar
Thanks PE, hard to say...maybe another month or two or so. We still have lots of little things to work through.
My build thread
Old 06-16-2019, 02:16 AM   #606
RockTonka
RockTonka's Avatar
We have started fitting the front sheet metal back on and are finding a few areas that need massaging.
Right off the bat, the blower belt was against the fans/radiator (first pic). My son worked on the rad support and opened it up to allow the rad to slide forward over an inch...plenty of clearance now.
We'll rework the mounts and should be good to go!
My build thread
Old 06-20-2019, 02:15 AM   #607
RockTonka
RockTonka's Avatar
Got the upper/lower radiator mounts reworked and fit in...locks it in nicely. Also got the fuel regulator mounted and all the lines ran.
My build thread
Old 06-23-2019, 02:05 AM   #608
RockTonka
RockTonka's Avatar
Continuing to fit pieces of the puzzle in...
My build thread
Old 06-23-2019, 11:25 AM   #609
piratexpress1369a
Looking good so far..stay at it
63
Old 06-24-2019, 12:16 AM   #610
RockTonka
RockTonka's Avatar
Thanks PE! We're trying...
Started playing with the hydro boost and lines fit-up...
My build thread
Old 06-28-2019, 01:55 AM   #611
RockTonka
RockTonka's Avatar
Built the PS pump mount...made a upside down cradle that captures the modified PSC pump and allowed us to move the pivot point out to where we could optimize the limited amount of adjustment space we had.
My build thread
Old 06-29-2019, 12:36 AM   #612
RockTonka
RockTonka's Avatar
Added some material to the upper tensioner mount plate tonight and hung the reservoir off of that also...
My build thread
Old 06-29-2019, 03:24 PM   #613
piratexpress1369a
Looking good
63
Old 07-02-2019, 01:11 AM   #614
RockTonka
RockTonka's Avatar
We made some down bars for the engine bay to help stiffen up the chassis...bolts in between the top of the frame up front and the upper corners of the firewall. Tubes come off mating plates on the inner firewall and are welded into the a-pillar/dash bar nodes.
My build thread
Old 07-02-2019, 08:15 PM   #615
piratexpress1369a
Nice work on the tubes
63
Old 07-02-2019, 11:27 PM   #616
RockTonka
RockTonka's Avatar
Thanks PE, we're running out of room up there...getting harder to fit things in!
My build thread
Old 07-06-2019, 12:50 AM   #617
RockTonka
RockTonka's Avatar
Column to box was interesting...4 u-joints, 3 sections of shaft, and 2 stand-offs.
My build thread
Old 07-20-2019, 03:20 AM   #618
RockTonka
RockTonka's Avatar
Working through some more things...hydroboost lines ran and throttle pedal/cable done.
My build thread
Old 07-20-2019, 03:29 AM   #619
RockTonka
RockTonka's Avatar
We've been putting this next step off, but decided to jump into it tonight.
Cutting the hood!
My son picked up a spare hood for a practice cut/fit...we laid out a basic rectangular hole that looked like it should clear...and it did, but not exactly what we wanted.
That allowed us to gain some confidence in our technique and pattern before cutting the original hood.
My build thread
Old 07-20-2019, 03:38 AM   #620
RockTonka
RockTonka's Avatar
We modified the hole layout a bit and started cutting into the original, stock, patina matching hood...no pressure there!
It all worked out though, no problems and we really like the look.
My build thread
Old 07-21-2019, 05:23 AM   #621
RockTonka
RockTonka's Avatar
Started on the center console and shifter mount...
My build thread
Old 07-22-2019, 01:24 AM   #622
RockTonka
RockTonka's Avatar
Finished welding out the center console framework and shifter mount...also got the NOS dual bottle rack mount built.
My build thread
Old 07-22-2019, 11:05 PM   #623
Captainfab
60-66 Nut
You guys are doing some very nice work. Any tin work planned for the console?
Old 07-24-2019, 12:31 AM   #624
RockTonka
RockTonka's Avatar
Thanks Capt., and yes, the console will be enclosed.
My build thread
Old 07-24-2019, 08:54 AM   #625
piratexpress1369a
Dam that is a tight fit ..looks awesome...I didn't think you were going with nos...that is going to put out some big numbers
63
