02-15-2018, 01:59 PM | #6326 |
Re: What did you do to your truck today? Chapter II
Seven leaves in the springs ? .
Are you planning to work this rig ? or maybe tow with it ? . Good on you if so ! .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
02-16-2018, 09:25 PM | #6327 |
Rear disc, 3/4 ton, nice.
Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
02-17-2018, 08:47 PM | #6328 |
Got the front end all done and back on the ground.
02-18-2018, 06:24 PM | #6329 |
Big step, nice job.
Mudman.
02-18-2018, 10:07 PM | #6330 | |
This truck will be working not just looking pretty She was a field fire truck I took 2 springs out to get to seven Today I started on the front |
02-18-2018, 10:16 PM | #6331 |
Working Rigs
This is very good to hear ~
Having a shiny truck is nice but never actually using it seems silly to this old farm boy . I was at an auction where there was a nice one ton stripper long bed step side for sale ex L.A.F.D., it had low miles and ran great once jumped . Just as it came up for bid SWMBO called and said 'I'm locked out, come home and let me in now please' so I missed it . It was yellow and white, original fleet paint .
02-18-2018, 10:24 PM | #6332 |
Installed my tubs and bed pan pieces I polished with my son today
1970 K20 1967 Blown Stepside 2016 Chevy 2500 Duramax 1989 Jeep Cherokee 1995 S-10 2014 Infinity Q-50 AWD 1970 Chevy K20 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=634164 1967 stepside rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=684913 Shop build http://www.garagejournal.com/forum/s...d.php?t=225559 |
02-18-2018, 10:50 PM | #6333 |
Post Whore
I have reposted this from my "fix it up" thread because I'm pretty happy finding out it is a local truck (fifty miles away) and the dealership is still alive (In a new location.)
"I got lucky last night in the good way. The PO had half dozen or so old truck part catalogs along with a box of receipts he gave me when I got the WMB. I had looked through the box of receipts but hadn't paid any attention to the old catalogs. I was in the process of tossing the catalogs last night when I noticed there was some thing stuck in the middle of one of them. Score baby! I was so close to tossing them away!"
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
02-19-2018, 12:30 AM | #6334 |
Installed a Edelbrock air gap intake and a Holley Sniper kit. Still getting the setup and learn process perfected. [ATTACH][/ATTACH]
02-19-2018, 01:43 AM | #6335 |
I did a trans filter change and upgraded the vacuum modulator from the old can type on my '67 step side . Then went to the car wash, gas station and drive with better half. Should have done that a long time ago . Apparently it needed to be done .
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
02-19-2018, 04:39 PM | #6336 |
Engine is out
02-21-2018, 09:35 PM | #6337 |
Took advantage of the warmer weather to pull the front clip in preparation for removing the engine and transmission. Taking the whole clip off as one piece was pretty simple with a friend helping me lift it off the frame. We'll see how it goes putting it back on...Might need a 3rd or 4th person to help line things up.
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296 |
02-21-2018, 11:08 PM | #6338 |
Power steering added and saddle tanks removed.
02-22-2018, 01:22 AM | #6339 |
Looking good JMD ,well organized I like. what are your plans?
02-22-2018, 09:33 AM | #6340 |
Thank you. I'll be replacing the worn out TH350 transmission with a TH400, rebuilding the transfer case, fixing an engine oil leak, and adding a fan shroud. If time and money permit I'd also like to add a more aggressive cam and possibly heads to that list but we'll see.
02-22-2018, 12:58 PM | #6341 |
Took her out for a drive to Eat some Meat at the local gathering place.
02-22-2018, 01:30 PM | #6342 |
? A meet & greet and you didn't get any pictures ? .
Sad face here .
02-22-2018, 05:24 PM | #6343 |
So I refinished my utility bumper.
1972 C30 Grain Hauler, 350/400 1967 1500 GMC Stepside SWB, In Transformation Process 1967 RS/SS Camaro 350/TKO600 Last edited by 57Suburb; 02-22-2018 at 05:27 PM. Reason: typo |
02-22-2018, 11:20 PM | #6344 |
Simply changed the speedo cable a couple weeks ago created a mess. Ended losing about 2 quarts of fluid in the driveway mostly in a pan at least. I guess the seal tore installing the new cable and I didn't realize it. Bought a new bullet but pulling the old one out most of the trans fluid drained out. Guess I'll just do a fluid change.
02-23-2018, 06:10 PM | #6345 |
Nice truck! Too nice to be a michigan truck.
02-23-2018, 07:39 PM | #6346 |
I had some new shoes put on the truck today.
02-24-2018, 04:48 PM | #6347 |
Nice truck! doesn't look like a typical michigan truck.
02-24-2018, 06:41 PM | #6348 |
Made decent progress on the leaf to coil spring conversion today. It back on the ground temporarily. The conversion is complete! I put it on the ground to check driveshaft clearance on the crossmembers. It's clears no problem. I still need to get the truck on the lift to see what is going on with the trans mount. It is sitting off to the drivers side. I broke it all back down to do touchup on the frame paint. I also decided to remove the stock leaf hangers. I ran out of time today, but should be able to work a few nights this week. Also installed the 1310 to 1330 conversion u-joint.
02-24-2018, 08:32 PM | #6349 |
HEI ignition! Pretty straightforward install
1977 SWB (c20 conversion) SBC350 Springfield Oregon Instagram: @nevernotchevy |
02-24-2018, 09:52 PM | #6350 |
Put pulleys an brackets on today clean and painted
