03-12-2021, 10:25 AM | #6376 |
Re: Restoring Rusty
Glad you are fine and Rusty is curable.
I bought Summit hoses for my LS swap 3 years ago. No issues what so ever. Now, if I could get the steering gear box to stop leaking, I would be great!!
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
03-12-2021, 12:56 PM | #6377 |
Re: Restoring Rusty
Good to see a post about Rusty again!
Guess I've been lucky. I have a 69 truck with the same braided fuel line on it for close to 20 years. Not much pressure there, of course. Also had a braided power steering pressure hose on my square for 5 years with a tight bend. Can't remember the hose brands, however I was buying just about everything from Summit back then. You can see how the hose does a 180 loop to connect to a 90 degree hose end.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 03-16-2021 at 04:54 PM. |
03-12-2021, 03:31 PM | #6378 | |
Post Whore
Re: Restoring Rusty
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 https://www.summitracing.com/parts/sum-230620 |
03-12-2021, 04:44 PM | #6379 | |
Post Whore
Re: Restoring Rusty
honestly I found power steering fluid to be the nastiest of all of them, that includes brake fluid and transmission fluid which some people claim to be interchangeable, sometimes the leak could be caused by trying to mate later style O-ringed hoses to older style gear boxes, maybe I got those two backwards but i know ones had rubber orings in them and the others didn't, so using a newer hose on an older box aint always a better option |
03-12-2021, 04:53 PM | #6380 |
Re: Restoring Rusty
Affirmative on the PLS!!
Mine was and o-ring from start so the 85 hose when right into the LS pump with no leaks. Mine is leaking at the steering shaft input. It desperately needs to be rebuilt. Its in the cue: behind the rear end and repaint of drivers door. It never ends....
03-12-2021, 04:57 PM | #6381 | |
Moderator
Re: Restoring Rusty
I wouldn't run Dexron VI in your power steering. Dexron III, if it still existed, would likely be just fine. Since it's no longer available I'll stick with Power Steering juice. Glycol DOT3 or DOT4 Brake fluid has more in common with anti-freeze than oil.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
03-13-2021, 02:33 PM | #6382 |
Post Whore
Re: Restoring Rusty
03-13-2021, 02:38 PM | #6383 |
Post Whore
Re: Restoring Rusty
so the Summit hose arrived the very next day (yesterday) much to my surprise and I want to share a couple observations with you
1. note the crappy factory cuts, these are horrible and a total waste of ends, they should put some tape on there to keep the ends from fraying 2. I swear this seems like the exact same hose I bought from Amazon except Summit is charging more for it ($80 vs $50) the cynic in me has this vision of a random cheap steal braided hose factory in the middle of Manila somewhere where they ship miles of this stuff to different American distributors with the premise of charge what ever the he11 you want for it but first a box in a box Last edited by Gregski; 03-13-2021 at 02:50 PM. |
03-13-2021, 02:40 PM | #6384 |
Post Whore
Re: Restoring Rusty
and here's a close up of one of the factory cut ends
as our friend LT7A pointed out "must have been cut with a hammer" ha ha see the problem with said hose ends is that you cannot just cut an inch off the end to get a nice cut, in my experience you have to lop off at least a foot or so to keep the strands in order, maybe I'm just doing it wrong but I've tried it with many different cutting implements yielding the same results |
03-13-2021, 02:43 PM | #6385 |
Post Whore
Re: Restoring Rusty
although only one hoser was weeping I decided to make two new ones, and I was flying along until I got confused on the second hose and pulled the end off of the good new hose instead of the end off of the old hose, that made me mad and I wasted a hose as I couldn't get the end back on it, it was too fraid
pic of one new one in a handsome heat sleeve |
03-13-2021, 02:48 PM | #6386 |
Post Whore
Re: Restoring Rusty
MANDATORY FAVORITE JOKE TIME
Three young ropes want to buy some beer at a local bar. The first rope goes in and asks for a drink and the bartender asks, "Are you a rope?" To which the rope replies, "yeah I am" "Sorry we don't serve ropes here. You'll have to leave." the bartender replies The second rope goes man why did you have to tell him and heads inside and asks for a drink and the bartender asks, "Are you a rope?" He says, "no" but the bartender asks him for some ID and says "It says here you're a rope, and we don't serve ropes here. You'll have to leave." The third rope ties himself in a knot and undoes his top braid a bit and ruffles it up. He goes in and asks for a drink. The bartender asks, "Say, aren't you a rope?" He replies, "I'm a frayed knot." |
03-13-2021, 06:14 PM | #6387 | |
Moderator
Re: Restoring Rusty
I've had four four of the short ones since about 1995 and one of the long ones. Great cutoff tools for fuel, oil, and water hoses including the hoses with thin braided wire covers. I have two shorties and the one long set in the garage. I use one more set of them to cut network and other signal cables and the other to cut and prep coaxial cables. I can still buy the nylon anvils and steel blades but Stanley stopped production of this damn handy little tool when they took over Craftsman. Some other enterprising soul is making them now. If they're as stout as the real thing get em while you can. https://www.ebay.com/itm/Ronan-2-1-2...t/303670186301 This is the real McCoy...https://www.ebay.com/itm/254876062134
And please let us know if and how your repairs were successful. Last edited by hatzie; 03-14-2021 at 12:20 PM. |
03-14-2021, 10:35 AM | #6388 | |
Re: Restoring Rusty
03-14-2021, 10:37 AM | #6389 |
Re: Restoring Rusty
03-14-2021, 10:38 AM | #6390 | |
Re: Restoring Rusty
03-14-2021, 12:16 PM | #6391 |
Re: Restoring Rusty
Not elegant, but this always works for me.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
03-14-2021, 12:22 PM | #6392 |
Moderator
Re: Restoring Rusty
Nice!!
The painters tape is a good trick to keep the braid from unraveling no matter what you use to cut it.
03-14-2021, 01:09 PM | #6393 |
Post Whore
Re: Restoring Rusty
thanks guys I really appreciate the feedback and I hope this helps others as well, I am with you on the cut off wheel I get the thinnest possible and you won't know what's a thin wheel unless you see two or three kinds side by side at your local Ace or other supply house
also I recommend using a full size cut off wheel so like a new 4" and not a used up one or a mini so that your cut can just go straight through and you don't have to rotate the implement all the way around the hose and finally just a twist on the tips give, I found that for me clear shipping tape holds the braids tightest our of masking tape or painters tape, it is a bit of a PIA to get off after the cut but I just cut it with a razor length wise and off it comes, and lately I just started to bend the end over about 1/8th of an inch to give me a starting point on peeling it back again thank you all for you the tips |
03-15-2021, 06:59 AM | #6394 |
Re: Restoring Rusty
Mike, this is a very clean and detailed engine bay. Something they would have called super-sanitary, back in the day.
03-15-2021, 09:02 AM | #6395 | |
Re: Restoring Rusty
Check my signature. Sold the 82 and just got the 69 back yesterday.
03-16-2021, 03:38 PM | #6396 |
Post Whore
Re: Restoring Rusty
so it appears we successfully transferred two full quarts of the red stuff from the trans belly to the driveway via the busted stainless steel braided pin hole, and she still ranned and shifted, salute to the GM guys
03-16-2021, 05:30 PM | #6397 |
Moderator
Re: Restoring Rusty
As long as you didn't damage the pump you should be just fine.
03-20-2021, 04:12 PM | #6398 |
Post Whore
Re: Restoring Rusty
the beauty of owning old cars or trucks is that they need constant care and feeding, and Rusty is no exception, especially as my daily driver
add to that the premise that if it aint broken and you decided to fix it, and you have a recipe for a fun weekend old cars are funny like that, I still remember the Car Fix episode where Jared and Lou both very competent wrenches drove in and replaced the carpet in a Camaro or Fire Chicken I forget which, and afterwards the car would not start, and would not drive out of the shop bay, lol, I just grinned and nodded to myself, going yup - old cars!!! so what is this latest rant about, well my Lokar automagic transmission shifter, it worked fine before I loosened the tortoise shell to get to the trans fluid lines in order to replace them, and now with the shell back in place and bolted up finger tight the shifter has way too much throw on it for some odd unexplained reason where it wants to go way too far forward and kiss the dash and then lay way too far back and hug the seat we must investigate this mystery Last edited by Gregski; 03-20-2021 at 04:27 PM. |
03-20-2021, 06:43 PM | #6399 |
Post Whore
Re: Restoring Rusty
hmmm, yet another aftermarket part failure, please tell me it aint so!
now I am 106% sure the allan nut that was supposed to be in there was in there as I've kept a zip loc baggie of all the extra bits from this Lokar shifter and it sure wasn't in there, not to mention the other three missing bolts |
03-20-2021, 06:44 PM | #6400 |
Post Whore
Re: Restoring Rusty
now before you blame me the installer let me tell you that the other bolt (the one on the side) that worked itself out is only held in place by like 3 threads and then it is designed to bottom out and can't screw in any further, so there's that
