03-06-2018, 01:37 AM | #6401 |
Re: What did you do to your truck today? Chapter II
Suddenly I'm hungry.
Not worth posting a picture of my transmission crossmember, just a cleaning idea. I didn't want to remove the rivets, and without doing so they're a bear to clean, baked on transmission fluid and such. Anyway, after some effort I found it was going nowhere. So I soaked both ends in a bucket of boiling water, with a splash of grease remover on occasion. It still required pipe brushes, but came off easily and clean as a whistle.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
03-06-2018, 10:18 AM | #6402 |
03-06-2018, 10:40 AM | #6403 |
hahaha I'm on my way...be there in a little bit
Steven '67 SWB, 250ci, 3OTT.......this is my first build...... I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71" |
03-06-2018, 02:01 PM | #6404 |
mmmmm.... smoked ribs sure sounds better than boiled cross member .
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
03-07-2018, 10:18 AM | #6405 |
tried my hand a wet sanding and buffing my hood. turned out ok i guess. the peel that is still there is not any different than on my daily driver, i guess ill stop before i screw something up.
prolly start on on the pickup tomorrow.
03-07-2018, 10:01 PM | #6406 |
Moved on to the fenders today. Removed all the trim, cleaned up, painted, taped on new woodgrain, installed deluxe side markers(I know they're wrong, but I like them) and reinstalled. Hope to hang them soon.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
03-08-2018, 01:24 AM | #6407 |
I had my seat recovered today. Haven't bolted it back in yet.
03-08-2018, 10:24 PM | #6408 |
wet sanded/buffed and polished the bed, drivers door and drivers front fender (ran out of daylight for the other side).....huge difference.
before after
03-08-2018, 11:31 PM | #6409 |
Looking great man, you've spent more time on the fender than I've ever spent cleaning the outside of my truck. I've actually never washed the outside of my truck, it might remove some patina.
03-08-2018, 11:35 PM | #6410 | |
never thought how much fun this would be.
03-09-2018, 01:03 AM | #6411 |
Started disassembling 2 different NP205s in order to make one functioning tcase that will bolt up to a TH400.
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296 |
03-09-2018, 02:56 AM | #6412 |
4X$ Transfer Case
Be sure to check very closely for hairline cracks in the large opening of the cases....
-Nate Last edited by VWNate1; 03-09-2018 at 01:51 PM. |
03-09-2018, 01:34 PM | #6413 |
Re: 4X$ Transfer Case
Will do, thanks for the tip!
03-09-2018, 01:53 PM | #6414 |
Back on the 1970's when I worked at the Dealer we sold lots and lots of the cases when doing routine transfer case overhauls .
One simple way to find hairline cracks is : wipe it clean of loose oil then pass a propane torch lightly over the surface ~ cracks will *instantly* show up as oil/grease comes out of the crack as the flame heats it .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
03-09-2018, 04:18 PM | #6415 | |
Can you give a quick rundown of your methods and tools/compounds for us who are considering doing this? Thanks, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
03-09-2018, 04:48 PM | #6416 | |
Who Changed This?
03-09-2018, 07:54 PM | #6417 |
I got the engine and trans mated up and reinstalled in the old girl. Lots of stuff still to hook up but it's progress none the less.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
03-09-2018, 08:26 PM | #6418 |
Put my new 8 lug smoothies on from Detroit steel wheel. 20x9 275/40r20 all around.
03-09-2018, 08:40 PM | #6419 |
Polished my interior door handles, and waited for my LMC suspension kit to be delivered.
"I'm rooting for you, and remember, were all in this together." ~ RED GREEN 1970 Chevy Custom. |
03-09-2018, 10:45 PM | #6420 | |
I had orange peel that looks like I sprayed with a texture gun for doing walls inside your home. Honestly, an orange would be offended if I mentioned his name in the the same sentence as my paint job...hahaha I used a very unconventional method than most, but I'm hard headed and cheap And, I like being different first off..... I have a turbine spray rig....( TPtool Showtime 90). I researched a bunch and I was always planning to do everything my self in my garage. The turbine sounded like the best thing for the "low" overspray issue and "garage hobbyist" guy. as far as the sanding goes.... I knocked down the orange peel with 400 ( I know, I know....) please don't shoot me, but the orange peel was, well...look at the pictures. ( don't forget, I'm learning) I used the squeegee technique ( wipe with squeegee after sanding and washing off "milky" clear coat )and watched my peel begin to disappear ( sand, wash off, wipe off, look, get a beer, sand some more.....repeat). Then I went up from there..... 800, 1000, 1500, 2000, 3000 All was done wet and the paper was sitting a in a bucket of soapy water after all that "fun"..... Maguairs swirl remover with a wool pad then Maguairs show car glaze (I think that's what it's called )with a foam pad I am learning all I can from you guys. As you know there are things that are better learned on your own and by trial an error. I am very proud of my little pick up but there are things I will do different on the next one I do. Thank you so much for your compliment and I feel very flattered that you would ask how I went about this. Sorry for the long reply to the other wise short phrased post for this particular thread....hahahaha I just looked up and noticed, you asked for a "quick run down"....hhahahahaha.....I'm a dork
03-10-2018, 06:56 PM | #6421 |
Extremely productive day. Got the new front tires mounted on the rims. Installed 2 in blocks. Finally ride height is where I want it to be after 2 years. 5 7 drop. Installed hidden hitch.
03-10-2018, 08:05 PM | #6422 | |
-klb
03-10-2018, 08:49 PM | #6423 |
03-10-2018, 09:02 PM | #6424 |
My friend came over to help out with a tune up and timing. She’s running fantastic now.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
03-10-2018, 09:02 PM | #6425 |
That hitch looks great. Ride height looks great also. What's up with the gas can near the frame?
