04-15-2021, 11:11 PM | #6426 |
Post Whore
Re: Restoring Rusty
ladies and gentlement... The Digital Cambermatic 3000
04-15-2021, 11:18 PM | #6427 |
Post Whore
Re: Restoring Rusty
and here it is in action
Driver side has 1.20° of Negative Camber which is OK(ish) Texter side has 2.10° of Negative Camber which is Too Much however now at least we know in degrees how much out of whack we are Note: I believe back in the day the Manuals for these 60s and 70s vehicles read something like +1° or -1° of camber was acceptable, which is redunculous, you go ahead and set your driver side wheel to -1° and your passenger side to +1° and I'll meet you at the telephone pole |
04-15-2021, 11:22 PM | #6428 |
Post Whore
Re: Restoring Rusty
so it was time to bust out the shims, and when it comes to Camber, don't over think things, first if you struggle with remembering which is Negative camber and which is Positive camber, just remember In and Out as in the top of the wheels lean In or the top of the wheels lean Out
and just use the alphabet trick N in Negative comes before P in Positive just as I in In comes before O in Out You're welcome |
04-15-2021, 11:26 PM | #6429 |
Post Whore
Re: Restoring Rusty
remember we are focusing just on the passenger side, so here is what the current shimming situation looks like
and if all you are doing is addressing the Camber then always add or remove the same amount of shims to both the front and the back of the upper control arm Note: there are more shims in the back of the upper control arm that is to set Positive Caster a topic for another day |
04-15-2021, 11:30 PM | #6430 |
Post Whore
Re: Restoring Rusty
some shims come with a little hole in them mine did not, now they do
this makes it zip tie friendly and keeps the profanity down to a minimum |
04-15-2021, 11:32 PM | #6431 |
Post Whore
Re: Restoring Rusty
mandatory stare and compare of the ol' analog Cambermatic 300 and the new and improved digital Cambermatic 3000 shown with the Pro Plus option second magnetic level attachment used to ensure verticability
04-15-2021, 11:51 PM | #6432 |
Post Whore
Re: Restoring Rusty
so adding two shims to front and back of the upper control arm got me in the OK(ish) ballpark with the same negative camber on both sides, I may revisit both sides after some shake down driving and see if I can get them both slightly under -1°
04-16-2021, 06:44 AM | #6433 |
Re: Restoring Rusty
I like your method .
04-16-2021, 09:40 PM | #6434 |
Post Whore
Re: Restoring Rusty
it's that time of year again...
Annual Seat Sale! Last edited by Gregski; 04-17-2021 at 09:16 AM. |
04-17-2021, 10:16 AM | #6435 |
Re: Restoring Rusty
Oooh!
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
04-17-2021, 01:50 PM | #6436 |
Post Whore
Re: Restoring Rusty
04-19-2021, 10:41 AM | #6437 |
Re: Restoring Rusty
You're right!!
I cant wait for a Gregski install write up on these!!
04-19-2021, 11:33 AM | #6438 | |
Post Whore
Re: Restoring Rusty
http://67-72chevytrucks.com/vboard/s...&postcount=525 |
04-19-2021, 04:13 PM | #6439 |
Re: Restoring Rusty
"you go ahead and set your driver side wheel to -1° and your passenger side to +1° and I'll meet you at the telephone pole"
Hahaha, good call. I like the tool you made and your process. Is Rusty getting some new shoes? I couldn't help but notice some white raised letters - well, blue at the moment. |
04-19-2021, 08:48 PM | #6440 | |
Post Whore
Re: Restoring Rusty
the blue high heels in the pic were from my '54 they came off the front cause they were to wide at 245 micronmeters so I went with 215s |
04-21-2021, 11:10 PM | #6441 |
Re: Restoring Rusty
Someone has been quite busy lately.
04-22-2021, 02:25 AM | #6442 |
Re: Restoring Rusty
1984 C10 with cammed vortec 350 |
05-12-2021, 05:22 PM | #6443 |
Post Whore
Re: Restoring Rusty
Finally it was time to replace them shift solenoids
05-12-2021, 05:26 PM | #6444 |
Re: Restoring Rusty
05-12-2021, 09:32 PM | #6445 |
Moderator
Re: Restoring Rusty
Make sure the internal harness isn't leaking fluid around the pins through the connector.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
05-13-2021, 12:58 AM | #6446 |
Post Whore
Re: Restoring Rusty
05-13-2021, 01:02 AM | #6447 |
Post Whore
Re: Restoring Rusty
so this is where the solenoids live, I know it's upside down, but better than nothing
the one on the left (driver side) is the 1-2 and the one on the right (passenger side) is the 2-3 but they are both identical same part number |
05-13-2021, 01:07 AM | #6448 |
Post Whore
Re: Restoring Rusty
yes this transmission has a drain plug and yes the P.O. (pronounced: "guy who had it before me") tightened it as hard as she could plus a quarter turn, and stripped the head of the bolt so that I had no chance of getting it out
but since this was my first gear box with a drain plug I was determined to have one that works, even if it took me 3.5 hours to get it out Last edited by Gregski; 05-13-2021 at 01:36 AM. |
05-13-2021, 01:10 AM | #6449 |
Post Whore
Re: Restoring Rusty
so the first test I did (right or wrong) was the Click Test, basically you hook up a solenoid to a car battery and listen to see if it clicks
the 1-2 solenoid had a loud(er) click than the 2-3 one so I think that's the one we are trying to replace |
05-13-2021, 01:14 AM | #6450 |
Post Whore
Re: Restoring Rusty
the second test and the more official one was the Horse Shoe Test
this is where we put our Multimeter on the horse shoe icon and check for The Reistance the 1-2 solenoid measured at 23.1 ohmsboth seemed within range, remember if you know nothing but have two of something, compare them then here's how the new ones tested the new 1-2 solenoid measured 25.6 ohms |
