#626 |
Re: LS1 into a 73 cheyenne
Got the handles today super nice very high quality finish
Alex - Dirty AL "One Piece at a Time" Follow me on Instagram alex.barr.ios |
#627 |
DO WANT THOSE DOOR HANDLES!
Those look awesome |
#628 |
VA72C10
![]() Join Date: Mar 2008
awesome!!!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#629 |
![]() Join Date: Dec 2010
Definitely a unique mod man! Those look sweet!!!
1977 Chevrolet K30 LWB Crew Cab 497HP Mast Motorsports 6.0L LY6 HO engine GM NV4500 5-speed, Centerforce clutch + NP205 D60 + 14-bolt FF w/ Eaton posi + disc brakes Skyjacker 2.5" full spring lift w/ Nitro shocks Custom paint + interior http://67-72chevytrucks.com/vboard/s...d.php?t=435722 |
#630 |
I got the drivers side door handle sorry about the low res iphone pics. Il try and post some high res pics after I complete both sides
#631 |
Nice handles! It looking good man!
1975 Chevy Cheyenne w/ v8 350 and TH350 Siverado interior Fleetside bed aka "The Beast" aka "Cheyerado" |
#632 |
Those look great and you already got 1 on ! I really like the brushed look,
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237 |
#633 |
handles look good bro....
nOtHiNg LiKe ThE gOoD oLe ChEvYs.... ![]() |
#634 |
Those handles look killer, can't wait to see some base color behind them!
#635 |
Still plays with trucks
Very nice. That is the biggest thing on the square body trucks that bothers me. The door handles just look so cheap and are just plain ugly.
I was considering putting the 67-72 handles on my 78 but the ones you chose are even better. Great job.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#636 |
Home Built '87
Very cool handles!!!
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
#637 |
Thanx evryone, I completed the passenger side mudd and all i also shaved the key hole as it would of been worthless since i have keyless entry.
#638 |
driver side is almost there i got hungry and left the shop
#639 |
I need to finish the mudd work on the hood i had to beat it with a 4 pound beater and bring out the 2x4,trim here and there and build a side and 3 corners to have the 1/8 gap i have all around. This hood was far from a perfect fit and it was from goodmark, guess it depends on how picky you are
#640 |
need to finish mudd work on top of the core support shaved all the folds creases and bolts
#641 |
The handles look killer!
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
#642 |
coil overs are in. went with 750lbs. springs up front taking in consideration the lighter front end.
Alex - Dirty AL "One Piece at a Time" Follow me on Instagram alex.barr.ios Last edited by smokedat; 10-07-2011 at 11:47 PM. |
#643 |
Very nice bro.....
#644 |
i havnt updated the build in a while but progress is coming along. Body work on the hood is complete it took a while but it turned out great, hinges are smooth an gaps and alignment are right on closes and opens effortlessly. It had a 1/2 bow down both sides that i had to bust down with a 2x4 and a 2 pound beater, after doing so i had to bust the torch out because i had to shrink some areas. The technique might be a lil scary for some but when a hammer and dollie wont do it u need the torch to shrink down. For this u need to have a clean surface down to the metal then apply the heat until it turns read to the size of a quarter or so the cool it off with a wet rag. You keep doing so until it minimizes, make sure you give it time to completely cool off after each pass this is critical or you will get false results. For added strength i reinforced the first layer with short strand fiber glass then finished with bondo and glaze. You will be amazed on how much the metal changes from having a belly to applying heat to cool off. But if you feel like its beyond youre ablity dont try it. You will **** **** up warped metal is a biach to fix
#645 |
i also knocked out the lil boxes on the bed, they were a bit of an eye sore
#646 |
all the metal and body work is finally coming to a closure hope to spray this soon my goal is to have it painted by early-mid next yr.
#647 |
some motivating and inspiring pics of the blue devil
#648 |
Home Built '87
Nice corvette!
Your truck is coming along amazingly!!
#649 |
You did a some real work to that hood , I have the same pos goodmark hood , my body guy didnt do much with it and it shows but I can live with it , yours is much nicer I'm sure ,
Nice corvette, we have a guy at the local hotrod shop we do some work for and hes building a blue devil camaro for the ridler award , I've been workin on making all sorts of stuff for the Ls9 ,
#650 | |
Tags |
73c10, c10, cheyenne, ls1, swap |
