09-12-2021, 10:08 PM | #1 | |
Post Whore
Re: Restoring Rusty
honestly I am even considering a trade for a 2010(ish) hatchback and a dirty joke I haven't heard yet |
09-12-2021, 10:06 PM | #2 |
Re: Restoring Rusty
Great work on the seat structure. I've actually shifted to painting with a brush when it's feasible. I feel like the paint will be more durable since it doesn't need to have a high enough percentage of solvent to be propelled airborne. Those tracks came out particularly nice.
I'm probably more an analog guy than digital, so I won't needle you about your gauge choice... I know they said 8 to 10 weeks to get your seat cover but when you look back on it I bet it won't seem like it took much more than a couple of months... |
09-12-2021, 10:06 PM | #3 |
Re: Restoring Rusty
09-12-2021, 10:10 PM | #4 | |
Post Whore
Re: Restoring Rusty
09-13-2021, 08:41 AM | #5 |
Post Whore
Re: Restoring Rusty
honestly having this faded strip above the tinted rear slider didn't bother me one bit
the splatter on the plastic is from another project (ie us painting the bench seat frame earlier on, remember?) |
09-13-2021, 08:43 AM | #6 |
Post Whore
Re: Restoring Rusty
I just got sick and tired of people telling me I should paint it, so I finally gave in, in my driveway none the less, figure I'll give my HOA something to complain about, ha ha
shown with the plastic torn off but the blue tape still on there Fun Challenge: What year, make and model is that thing in the garage? ... and For Extra Credit: What motor/trans combo does it have and what octane gas am I running, ha ha? (you should tell from the smell) |
09-13-2021, 10:50 AM | #7 |
Post Whore
Re: Restoring Rusty
men that's sexy, not to mention it just totally added $12.50 to the value of the truck
09-13-2021, 09:49 PM | #8 |
Post Whore
Re: Restoring Rusty
here we go...
09-13-2021, 09:53 PM | #9 |
Post Whore
Re: Restoring Rusty
and some parting shots of those Intellitronix gauges
I did mention they was cheap didn't I? |
09-13-2021, 09:54 PM | #10 |
Post Whore
Re: Restoring Rusty
Digital Gauges - never been raced!
coming to a Craigslist near you |
09-13-2021, 09:57 PM | #11 |
Post Whore
Re: Restoring Rusty
nothing like a clean canvas
09-13-2021, 09:59 PM | #12 |
Post Whore
Re: Restoring Rusty
Man I waited 2 years to try these, whacha all think?
when I picked the Sports Comp II series I was going for the least offensive, I wanted black bezels but didn't want to pay AutoMeter $30 bucks per gauge to paint them black for me, I should know I spoke to their [ahem] "Customer Service" Last edited by Gregski; 09-13-2021 at 10:06 PM. |
09-13-2021, 10:01 PM | #13 |
Post Whore
Re: Restoring Rusty
oh gawd nooooooo (he's not going to use that is he???)
09-13-2021, 10:04 PM | #14 |
Post Whore
Re: Restoring Rusty
Bruh, wouldn't a Dremel be a wiser choice? Don't you have one?
Why yes, yes I do.... also broken! I swear this stop spinning thing is contagious in my garage |
09-13-2021, 10:21 PM | #15 |
Post Whore
Re: Restoring Rusty
so we just use that metal bit to rough out the edges like so, and then we smooth them out with this sand drum thingie and the pink spinner thingie
09-14-2021, 04:05 AM | #16 |
Post Whore
Re: Restoring Rusty
now I do own and have considered using a hole saw, but the last time I used it, it didn't perform so well
I used this 2 5/8th once to cut a hole in some wood and it got distorted and misshaped, in other words it's no longer perfectly round, but slightly oval and I didn't wanna risk cracking the plastic or having it walk all over it like a bad drill bit, hope that makes sense that and I looked for one with fine teeth but couldn't find one |
09-14-2021, 04:07 AM | #17 |
Post Whore
Re: Restoring Rusty
so there, one is in, 47 to go...
09-14-2021, 04:11 AM | #18 |
Post Whore
Re: Restoring Rusty
ok, so that was the little guy, now let's see how the big one will fit
09-14-2021, 04:13 AM | #19 |
Post Whore
Re: Restoring Rusty
and bowfties... not too shabby - what do you think? post up a comment
09-14-2021, 04:16 AM | #20 |
Post Whore
Re: Restoring Rusty
we now interrupt this Upgrade to bring you another FTS (Fix Dat Shizzle) for sale upgrade
this broken corner has been bugging me for years, it has been lost and found half a dozen times, survived 4 house moves, and a bad encounter with Gorilla glue, ha ha let's see if we can fix it By the way, Crazy Glue (if it's still called that) is/was absolutely amazing and 100% effective each and every time in sticking your fingers together! Am I right or am I right folks? Please share your fun moment with that magical concoction below. Last edited by Gregski; 09-14-2021 at 04:30 AM. |
09-14-2021, 04:24 AM | #21 |
Post Whore
Re: Restoring Rusty
now to the common laymen (or laywomen) this may appear as a run of the mill soldiering iron, but the more daring of you will clearly see it for what it is: Plastic Meltor 3000
I think it turned out ok, and honestly the only reason the crack still appears is because like I mentioned earlier at first I tried using Gorilla glue on it and the residue is still there creating that slight separation (had I not tried that first, you wouldn't even be able to see the crack) Last edited by Gregski; 09-14-2021 at 05:58 AM. |
09-14-2021, 04:27 AM | #22 |
Post Whore
Re: Restoring Rusty
and now for the Strength Test, yup it will do!
add another $12.50 to the value of the truck |
09-14-2021, 04:33 AM | #23 |
Post Whore
Re: Restoring Rusty
Gauge Upgrade Project
Fun Level: |
09-14-2021, 09:47 AM | #24 |
Re: Restoring Rusty
Devils advocate..... It's still a 'cracked bezel'. If I were purchasing a used truck & saw that, my mind would be thinking about the cost of a new bezel which is equal to not adding value 'as-is'. Fill the crack void & get some texture agent + fresh satin black to help your cause.
09-14-2021, 11:05 PM | #25 |
Post Whore
Re: Restoring Rusty
I am lovin' these new gauges, you'll be able to read 'em from the back seat!
