#651 |
Re: Post Your Straight Six Pics!
Here's mine. Waiting for the rest of the truck to catch up.
#652 |
Finally :
The other side , showing the later model OEM HEI I went with this time and the long engine and TH350 tranny oil dipsticks I used , also using OEM GM parts from G - Series vans , I'm too old & beat up to enjoy leaning over the fender to do my daily fluid checks . Another view :
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#653 |
Almost ready to go , the TH350 had some seriously thick goo on it that was *very* difficult to remove .
Unloading it at the Paint Jail : Another unloading view , shows the 3/8" power steering filter with magnet I added to the P.S. return hose , lots of little details on engines , I wish I could do the Show Quality works so many here do but this is O.K. for my daily driver Shop Truck :
#654 |
Just to make you BOW TIE GUYS drool :
This guys paint is fantastic , anyone here like Suburbans ? here's a nice Task Force 'Burb : The res of my truck is still apart , I can't find the 6 cylinder tachometer a Member here kindly sold me .
#655 |
I have a question about the I-6 exhaust manifold bolts. On my 69 C-10, the very front and rear bolt heads are missing. I initially assumed the bolt heads had broken off over time. After looking through multiple pictures in this thread, I've noticed others are like this. Are they supposed to be like this or have the heads just broken off with time.
#656 |
If I remember correctly from other posts that's how they were designed. I had to look it up when I pulled my head and thought the same as you.
1966 C10 250 with 3 on the tree Build Thread Bunch of other cars no one cares about ![]() |
#657 | |
![]() Join Date: Feb 2002
In the stock application the L6 studs work OK. If you're hanging headers, you'll want to back out the studs with a big ViceGrips turning counterclockwise. Then you have some nice bores 3/8-16 x <1" deep. Threaded studs 3/8-16 UNC on one end, and 3/8-24 on the other work real good to hold the header ends down.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 04-06-2015 at 03:45 AM. |
#658 |
This end locating pins are *very* important ~ the reason they're there is : as it goes through normal thermal cycles the exhaust manifold expands and contracts ~ adding bolts on the very ends , often causes the manifold to break .
There's much more engineering in InLine Engines than appears at a glance . That's why they out last V configuration engines .
#659 |
Post Whore
![]() Join Date: Mar 2013
Here's my 292 going into my 66. .040 ross racing pistons, comp cam, 1.94 intake 1.60 exhaust valves, lump port kit, .030 shaved off the head, roller rockers, smith bro's pushrods, aluminum timing gears, fully balanced and 0 decked. Bunch more but I'm too lazy to post it all again. Pictures! This will be mated to a tko600.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#660 |
Thanks for the info, I thought I had some broken bolts to contend with.
#661 | |
![]() Quote:
Looks like fun for you .
#662 |
![]() Join Date: May 2012
here is an update on mine.....
#663 |
Post Whore
Re: Romping , Stomping 292 Engine !
#664 |
Will post some later, not sure the best way to post photos on here
#665 |
Out of the carpool lane.
Not exactly my truck, but this is my very first car I bought when I was 18 and it's what I learned about cars and engines through. I'm almost 46 now so you do the math. I had so many offers to sell this in my late teens and 20's and even had an offer of $15,000 cash just 2 years ago that I laughed at, but I just could not sell her and part with something with such sentimental value. It's so original and I wanted to keep her that way instead of butchering her like every other (yaaaawn) Camaro out there and I always swore I'd never do this. Unfortunately, the PG blew up on the way home from work one night over a year ago and I put it aside until this weekend when I went to pull the trans. Unfortunately, I couldn't get to 2 of the bolts and realized it would be easier to just pull out all the organs at once in order to pull the trans so that's what I did. Now I'm seriously tempted to stuff a 1968 truck 327 in there along with a 2004R or a TH350, all of which I have sitting around unused. At minimum I have some serious cleaning to do and I'll pull apart the PG and fix it. Once it's all done I'll have to decide which direction to go. I've got a bunch of L6 accessories like PS pump/brackets, Offy intake, Crane Cams 260H that I've been saving for years, however I sure love the hp of the V8 that I've had in my 68 C10 for several years. I don't know what I'm ultimately going to do- I'm really torn!
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... Last edited by Brad; 06-01-2015 at 08:40 PM. |
#666 | |
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
#667 |
Post Whore
I agree with CST10. The V8 is very popular. Though I refer mainly to the stinkin 350. I'd take that 6 banger and throw those accessories on it. These 6 bangers can make v8 power if some work is done. Heck, you could throw 8 pounds of boost on that thing stock as it sits and That would make a HUGE difference.
#668 | |
#669 |
I agree with TJ, keep the six and add a little boost down the road. I would go with a more modern tranny tho.
#670 |
I added a poll on my dilemma: http://67-72chevytrucks.com/vboard/s...d.php?t=672568
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
#671 |
There's a reason Camaros are called ' belly buttons ' in the trade .
I'd keep the 6 as they make terrific drivers as you know if you've been driving it all these years . OTOH , a nice 327 would be fun too .
#672 | |
Re: Exhaust Manifold Pins
I am going to strongly disagree with you about the end pins. First off the header manufacturers tell you to replace them with studs. Secondly the metal in a header does not expand enough to cause an alignment issue. The metal is to thin on a header. I don't know anyone who has ever broken a header flange bolting the ends. I know several people that fought with leak after leak and gasket blow out from NOT using bolts in the ends. I have run headers with bolted ends for 22 years and 100+ thousand miles and never had a leak. If you are running headers on a SIX, tap the holes!
1977 K10 6ft Stepside L6 1978 C10 8ft Stepside 400 1980 C10 8ft Widebox with Uncle L6 1986 K35 Not a dually 350; 79 K20 Stripped 1973 and 1976 Chevy Truck Trailers 1995 Impala SS LT1 ![]() |
#673 |
VW Nate was talking about the stock cast iron manifolds.
I agree with you on the end-studs on headers. I'm at about 280,000 miles and 38 years.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 08-03-2015 at 12:32 AM. |
#674 |
Correct ~
Headers are thinner and don't ' crawl ' like cast iron exhaust manifolds do . FWIW , you don't " tap the holes " as they're already threaded ~ just use vise grips or a stud remover to remove the pins then use an appropriate size bolt .
#675 | |
you regularly seem to strive to post OFFENSIVE comments. if there was ANYTHING bellybutton about a 67-8 Camaro nowdays,the world would be an entirely different place its NOT 1976 anymore,, and you perhaps would not roll around in some clanking smoking old 240d Mercedes diesel,( which it would take about 12-13 of to pay for an average 60's Camaro nowdays) and try hawking old VW and motorcycle crap. |
