05-16-2013, 09:03 AM | #6951 |
Re: What did you do to your truck today!
Looks great! What is the part number of the sway bar bushings?
----------------------------------------------------------- Erik My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626 1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647 RUST!? Thats just mother natures way of telling all of us.....MINE!!!! |
05-16-2013, 09:36 AM | #6952 |
Re : MOOG Parts
Agreed but then so was the OEM suspension stuff (shocks not withstanding) .
The real trick is : no one ever greases the myriad of Zerk fittings of , if they do they don't raise the vehicle so the suspension is unloaded when they do so . It's a simple thing to really clean all the old accumulated grease and road grime _once_ then simply wipe off the new grease every time you grease it . I'm always amazed how many older vehicles have groaning ball joints I can hear from 1/2 block away and they simply ignore it or blame the vehicle . Oil & Grease are the cheapest mechanic's you'll ever use . -Nate |
05-16-2013, 12:49 PM | #6953 |
Finally got truck out for test run! Put 50 miles on it & all is GOOD! This thing is a blast to drive!
05-16-2013, 04:26 PM | #6954 |
^^^ What's the scoop on those big honkin' tires out back.
Posted via Mobile Device |
05-16-2013, 05:44 PM | #6955 |
Hoosier 31.5 x 18.5 x 15 on my home built 15" wide truck rally wheels, bolted on a narrowed dana 60 with my 4 link design. Merlin 540, Dart Pro1 Heads & Holley Dominator MPFI ECU backed by 4L80E. Hotchkis complete front suspension. This truck is a blast to drive! Hope to join Hot Rod Power Tour in Little Rock & then finish tour
05-16-2013, 06:02 PM | #6956 |
We are going to need you to start a build thread on that jewel. And I'll get to see it in person, as I'm doing Memphis on.
05-16-2013, 07:49 PM | #6957 |
Picked it up today from roger Lewis makeover and can't be any more happy with the vintage air he installed... Sure was nice to ride on the freeway with the windows up and cold air Posted via Mobile Device |
05-16-2013, 07:50 PM | #6958 |
Finished the gauge install
05-16-2013, 09:11 PM | #6959 |
Started slopping on some paint remover. Making some progress. More tomorrow
72 GMC super custom. |
05-17-2013, 08:00 PM | #6960 |
put some air horns on the 72!
05-18-2013, 02:15 PM | #6961 |
Junior Member
I have been working on my '67 trying to get the turn signals, tail-lights and brakes lights to work for a while so I can get it inspected and licensed. I wanted to get if fixed so I can take to a local car show the first of June.
I installed a universal turn signal switch on the column thinking it would be a quick fix, as usual not a good idea. I did get the turn signals to work on the back and sometimes on the front after I put in a new flasher. Well today my son took mercy on me and came out to help. In a short amount of time we got everything working ok. It sure helps to have two people working on these old trucks. He has a lot more knowledge than I do about these old trucks because he has been building them for a long time. We ended up running ground wires for the back lights and one of the turn signal lights in the grill. Also the connector on the brake light switch was a little corroded and had to be cleaned up.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
05-18-2013, 06:54 PM | #6962 |
Wiring sure does take some time, most don't like to work on it as usually puzzling.
05-18-2013, 07:39 PM | #6963 |
Pulled it out of the garage with the quad, and gave it a bath. Decided to wax the old paint (was painted 25 years ago) and it cleaned up pretty good. Still a ton more work, but it's getting there.
Mark 71 C10 Cheyenne 12 Aprilia RSV4 |
05-18-2013, 07:48 PM | #6964 |
Finished up my 3" cupped lca's and painted them
"its not a hobby, It's a Lifestyle" . bagged and soon to be bodied 70 longbed http://67-72chevytrucks.com/vboard/s...d.php?t=564028 |
05-18-2013, 08:44 PM | #6965 |
Good day. Firnished cleaning and undercoating bed frame in prep for new bed wood. Dropped right wheel wheel to sand, prep and paint. Power washed passenger side engine and tried to loosen right manifold bolts to replace cracked manifold. 4 loose--2 won't budge.
05-19-2013, 12:43 AM | #6966 |
Went to a car show today.Not judged but got a picture plaque.
05-19-2013, 01:52 AM | #6967 |
05-19-2013, 10:42 AM | #6968 |
Yesterday I got my Intros mounted and balanced and set my frame down for the first time with the new suspension. It is sitting on the tranny pan in this pic. I have a deep pan, going to have to go back to a stock pan.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
05-20-2013, 02:23 AM | #6969 |
just finished a 4 day marathon mini build on my 67LWB. ECE 4.5/6 drop (2in coils and 2.5 spindles up front), 6 lug disc brake conversion, power brake conversion and front sway bar kit. the rear drop kit included the super track bar kit, shock relocation kit, 6 in drop springs, new shocks. when i got my front end apart i decided to do all new ball joints, tie rod ends, as well as all new brakeline plumbing. got everything back together and found that my 15in front wheels wont fit anymore. no big deal, kinda figured it would happen. now i got to get a couple cheap used front wheels and tires to get it to the tire shop for wheels, tires, and a fresh alignment. probaby have to put some wheel spacers on the back to clear fenders. plan on putting 20x8.5 raceline 136 maxim's all the way around. probably gonna stagger the tires a bit to fill the rear fender wells up and to get away from that low profile tire look. probably 40 or 45 series tires.
'67 2wd LWB 350/4speed. |
05-20-2013, 02:30 AM | #6970 |
Better shoot us some pic's of all that work.
05-20-2013, 08:56 AM | #6971 |
finished up the 5 lug swap. Might have to drop the back a little.
05-20-2013, 08:03 PM | #6972 |
Got the carb installed,stainless fuel line bent and installed on the new motor,hooked the clutch linkage back up and filled the rad. Getting closer to firing this thing up soon. Just a couple more things then need to double check my list to make sure.
Attachment 1109751 Posted via Mobile Device Posted via Mobile Device
68 Long stepper My other ride ,,, 07 Streetglide.. |
05-20-2013, 08:07 PM | #6973 |
05-20-2013, 08:41 PM | #6974 |
Bolted in my lca's and love the stance now
But it still needs to go lower Before After Posted via Mobile Device
05-20-2013, 08:57 PM | #6975 |
60 4x4,235,SM420,Rockwell T221,D44/HO33 sold 4/12 67 C-20,292,SM420,HO72 90 Dodge W250 Cummins,NV4500HD,205,D60/D80 93 Dodge W350 Dually Cummins, Getrag, 205,D60/D70 |
