View Poll Results: Exotic wood bed or skinned smooth? | |||
Wood? |
164 | 78.10% |
Metal? |
46 | 21.90% |
Voters: 210. You may not vote on this poll |
#676 | |
Re: Wild C10 project
Looking forward to MSD review.
"I feel the need for speed!"... as soon as I am done with my nap. |
#677 |
Thanks, it was quite some work to get them ready and painted. I first painted them a semi-gloss black and wasnt too impressed. The aluminum castings had too many imperfections that would show up. Then I tried to lightly spray them in bed liner. That turned out looking perfect. And I have high hopes for the MSD setup, I will update.
#678 |
Started getting the MMW control arms in place.
#679 |
#680 |
#681 |
Sure like it. Might try that on the Mrs. 5.0 pulley brackets. Which liner brand?
#682 |
Duplicolor bed liner spray. It is a light smooth texture that looks right in place. I'm thinking of doing the frame rails in it also, and either gloss or semi gloss on all the bolt on accessories to have a more contrast. I haven't decided on painting the control arms, linkages on the rear end, etc red or black...would like some input on that...
Brannon Yazell 67' C10 mated w/ a 01' Silverado, extreme custom 2015 Chevy 2500 Z71 LTZ Crew Cab MSA, Motorsports Authority, Rigid Industries, Magnaflow, Michigan Metal Works, Raceline, BASF, Street Trucks http://67-72chevytrucks.com/vboard/s...d.php?t=624964 |
#683 | |
Yuck. I stripped them down & did more detail grinding, sanding, more DA work, & then I sandblasted them to get consistent texture on everything. After that I had them powder coated gloss black & they turned out very slick. The tough part now was getting the alt, power sterring pump, & A/C comp to closely match. Alt & pwr steering pump turned out good. Haven't attempted the A/C comp yet. My buddy wants a set done for his sons ElCamino. I told him it was a PITA but the texture approach seems like it will make it much easier.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-11-2015 at 01:19 PM. |
#684 | |
#685 |
![]() Join Date: Nov 2008
looks great. There is a lot of work going on there
#686 |
#687 |
Increadible build so far bud and will be a killer truck with alot of story behind it with trouble you have had with it, glad to see everything is working out and cant wait to see it finished
#688 |
Thanks. Yes I've had a few set backs along the way, but it will get there.
#689 |
Here's the templates and layout of the body and bed mounts..
#690 |
#691 |
#692 |
All the pieces cut out with plasma cutter..
#693 |
Positioning the mounts..
#694 |
#695 |
#696 |
#697 |
#698 |
#699 |
#700 |
Front passenger side
Tags |
bagged, c10, ls1, shaved, swap |
