#676 | |
Re: TA_C10: Stage 1
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
#677 |
Re: TA_C10: Stage 1
Update - Tailgate Fits
![]() This is a re-pop from LMC. Box says Tri-Plus. This thing is STRAIGHT!! I have heard nightmares, twisting and etc. But I got lucky I guess. Metal seems to be same thickness too. I will have very little work to do on the sides lining it up with the tail-light portion of bedsides. Everything else is just mud and prime. I'm happy. ![]() ![]() ![]() .
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". ![]() |
#678 |
Re: TA_C10: Stage 1
Widened tubs. Nope. Wrong.
So I orded widened tubs from Brothers. This was a wish list item. Well they sent me squarebody tubs. So I decided to return them and spend the money elsewhere. SCOTI thanks for talking me into this. I will just fix up my old stockers. ![]() ![]() ![]() .
#679 |
Re: TA_C10: Stage 1
If you change your mind in the future, AMD (available through Summit) has the 67-72 variety in the wider width. They are not quality stampings & would take slicing, dicing, & metal work to be 'nice'. If a guy is just building a beater, they're fine as is.
I guess that's $$ toward a possible wheel alternative?
#680 |
Re: TA_C10: Stage 1
That tailgate looks nice! I was not aware that they are making them with the lettering stamped. I just bought a new 67 hood on CL for cheap and now I know why, Seems the passenger side is way off. UGH! Oh well. Good to know I can get a good tailgate somewhere.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#681 |
Roto Reuter thats the name...
![]() Join Date: Feb 2010
Re: TA_C10: Stage 1
Glad it's working out. I bought a front bed panel from Mar-K. They have good quality parts too.
http://www.mar-k.com/
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
#682 | |
Re: TA_C10: Stage 1
#683 |
Re: TA_C10: Stage 1
8 days with no post.....
#684 |
Almost Satisfied
![]() Join Date: Mar 2002
Re: TA_C10: Stage 1
What he said ^^^
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
#685 |
Almost Satisfied
Re: TA_C10: Stage 1
Hopefully you don't have the Rona! Been quiet here lately!
#686 |
Re: TA_C10: Stage 1
![]() ![]() I have been working on the crib... Building new cedar fence and double gate. Installing a sprinkler system. Leveling yard with new dirt/sand. And burying gutter downspouts into french drains. Labor of love. Sorta. Getting the house ready to sell in a couple years. I'm anxious to get back on the truck soon though. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() .
#687 |
![]() Join Date: Aug 2018
Re: TA_C10: Stage 1
Ahh yes, home projects. I've been neglecting a couple projects of my own.
Looks nice!
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
#688 |
Almost Satisfied
Re: TA_C10: Stage 1
Oh man! That would make me miss the truck for sure! My wife would like several of those done, but I keep spending the extra money on the truck
#689 |
Re: TA_C10: Stage 1
I refuse to let your thread be way back on the third page. We all have other projects to attend to, but enough is enough. Just sneak out to your garage, grab a few pics and post em up!
#690 |
Re: TA_C10: Stage 1
Thanks Cornerstone.
And. Actually. I hit the garage yesterday for the first time in over a month. So much going on around lately. But I have the truck bug bad now. I have decided to try and finish my truck by July. So yesterday the wife and I cleaned out the garage big time to get it ready for truck work again. Organized everything. And I even had about an hour to do something so I ripped off the drivers outer and inner fender to match them up properly. ![]() When I fit all the body panels on the truck a while back, I noticed the inner fenders just weren't fitting right. The top 2 bolts that screw into the outer fender didn't line up at all. Reproduction inners were close but no cigar. I basically just assembled them off the truck and figured it out. Had to reshape the inner fender in places to make it work. And also had to grind out some of the holes to make it all work. I also saw the inner lip in the wheel well was sticking out and would cut the tire if I left it. So I got it all bolted up and took a grinder to the lip that was hanging over the outer fender. Just ground it down until it got close to the outer fender. When I pull them back apart, I will clean up the rest of the edges and call it a day. Probably put drain slots where I built a shelf for the PCM area. Little filler and paint and it's done. Here are the drivers side pics. You can see the mods I did to both fit the PCM from core support and also the stretch the sheet metal over the power steering box area to clear the fittings. ![]() ![]() ![]() ![]() ![]() ![]() .
#691 |
Re: TA_C10: Stage 1
Glad to see you back at it man!
#692 |
Re: TA_C10: Stage 1
I made a cut with a cutting wheel and basically pushed the top portion in, made a piece for the bottom, and welded them back together. Still needs hammer and dolly work to smooth it out... I got the big stainless kit from brothers trucks.
#693 |
Re: TA_C10: Stage 1
#694 |
Re: TA_C10: Stage 1
Sooooooo what's in the boxes?
#695 |
Almost Satisfied
Re: TA_C10: Stage 1
I sure wish we had a Summit Racing close enough to drive to...
#696 | |
Re: TA_C10: Stage 1
![]() And in the box is a new windshield and a new radiator..... .
#697 |
Re: TA_C10: Stage 1
Update - Another Radiator
After my wife takes me to Summit I ended up bringing home another radiator. It's a griffin. I have heard both good and bad things about this radiator. I wanted to go grab one from the local auto parts store like suggested from a couple of members but a couple things steered me away from that approach. First, I don't like the looks of those radiators. Plastic tanks, etc. And while I'm only building a daily driver, it's morphed into a really nice daily driver ![]() Something else I want to mention about my original radiator purchase. I'm pretty sure it was my fault that it started leaking. And if it wasn't my fault, I'm pretty sure I damaged it anyway. I failed to flush the LS I bought before hooking it up. And that engine sat for who knows how long. And it was FULL of rust and corrosion and what not. When I went to flush it after finding the fluid turning brown pretty quick it was already too late and it was clogging everywhere. I pulled it out and dumped it and tried to flush best I could. Then I re-installed and ran 2 different times, 2 different flush agents through it. I was only ever using distilled water, but I would add the flush agent to that and let it run for a while. I would take it around the block. Do this for a few days. Then I would drain everything again. So after doing this twice, I finally got everything flushed. But there was still this milky white stuff stuck to all the internal fins that I could see through the filler port, that stuff wasn't coming out. But by this time, the radiator had seen so much crap go through it I just didn't feel right about getting a replacement. So I called the company back and asked them about all this. This is when the guy told me about the possibility of current in my water and electrolysis. And he didn't hesitate about all the stuff I talked to him about going through my radiator. He just said he wanted to take a look at it and simply replace it. Maybe he didn't care. I dunno. But it still bothers me I did all that. Well I never heard back from him after all this corona mess. Still no radiator returned. Not answering phone calls or emails. He may have went out of business. This griffin was cheap enough and locally available with a good enough warranty I should be able to make it work. If it goes south, it's my own fault going this route and I will accept that, but I refuse to believe that all these radiators are junk. They have been around too long and have too many people using them. Time will tell. Alright, enough. Here is what I did and all the pictures. I needed to bent out a flange to mate to the new radiator. Minimal work to make my fan shroud work with new radiator. I ended up welding a couple flat plates on an old wrench and just went to town. I also used another pair of pliers later and scarred up the aluminum a bit but whatever, I can smooth that out another time. I'm just trying to get this thing done and on the road. I didn't feel comfortable using self tapping screws in this new radiator as they would drive in too far IMO. So I carefully drilled short holes in the outer aluminum flange and used rivets to attach the fan shroud. Worked out pretty good. Before: ![]() ![]() After: ![]() ![]() ![]() ![]() Next came mounting the radiator. And SCOTI(if he hasn't given up on me yet), I know man... is probably shaking his head at this point after reading all that above, but just wait, after reading what's coming next he will probably decide to reply to this post lol, it will be too much. ![]() ![]() In the instructions it has a warning, it tells you to support the middle of the radiator at core support mounts if you have only the 2 saddle mounts(which is exactly what our trucks use). So I had some really nice dense packing foam that worked out perfect for the job. I made the foam a 1/8" taller than saddles to make sure it would support properly. I have a feeling this step was missed by many out there and that is the reason the radiator failed on them. ![]() ![]() ![]() And I had to spend a couple hours on the upper mounts, had to cut and re-shape them to lower them for proper fit. The radiator sat too tall for them. About 1/2" too tall. I only got one done so far. Still have the second one to do tonight. Yeah, I'm gonna have 4-5 hours in fab work for this radiator. Before pic, sitting really high off the core support: ![]() Mods: ![]() ![]() ![]() ![]()
#698 |
Re: TA_C10: Stage 1
It's crazy how many different radiator options there are and how many positive and negative experiences with each of them. If I've learned anything on my truck, it's that you get what you pay for. Griffin seems to be middle of the road price-wise, so I bet it works just fine for you. But let us know!
#699 |
Re: TA_C10: Stage 1
Another small update I did last week. My steering wheel adapter "post cover" was too long and ended up rubbing my steering column. It marred up the paint pretty good so I had to touch that up. No big deal.
I ended up using a belt sander and just took about 1/16" material off. Clears just right now. Looking at HD pictures I can see the color is mismatched, but looking at it in person, you don't really see it that much.... Oh well. Got the button installed now too. Another issue I had was when I installed the first time the truck had never been started before and during the break-in process for power steering pump the steering wheel ended up being way off of alignment so I fixed this too. ![]() ![]() ![]() ![]()
#700 | |
Re: TA_C10: Stage 1
Also.... Small vs. large radiators use different top mounts. So depending on how the manufacturers build their radiator for vehicle 'X' might require you to do extra to make it fit.
