Old 07-09-2019, 12:22 AM   #676
71gmcC15
71gmcC15's Avatar
Re: What did you do to your truck today.The 3rd chapter
Reading all theses awsome post makes me feel bad. All I did was replace some valve cover gaskets and remover the rest of the trasmission spark control wiring.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 07-09-2019, 12:35 AM   #677
SRU1436
Drove mine to Home Depot, an appointment, and to 7-11 for a soda.
SRU1436 is offline   Reply With Quote
Old 07-09-2019, 08:52 AM   #678
72c20customcamper
72c20customcamper's Avatar
Originally Posted by Super Dude View Post
Sand, sweat, get covered in dust, repeat...
Feel like thats all I have been doing the last two weeks. Painting today.
But then I start on the cab.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 07-09-2019, 02:21 PM   #679
72c20customcamper
Bed is completely painted . Now I need to get the wood installed and put it back on the truck. Never intended to make it a show truck but I need to redo one fender . Got a bug and a run. Also had to settle for a little less gloss so I could get the motling out of the paint . Lots of misting ,only problem with single stage metallic paints.
At least it's on the fender I hope to replace . Put a 67 with spare tire mount on my 68. Hope to find a real nice 68 fender.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-09-2019, 02:35 PM   #680
72c20customcamper
I guess its acceptable.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-09-2019, 04:31 PM   #681
RodnRudy
RodnRudy's Avatar
I'd say more than acceptable, very nice job! A trick I learned a long time ago from an "old timer": When painting a single stage metallic that tends to mottle is after the last coat is sprayed take whats left in the cup and fill the cup with reducer. Then drop the pressure to about 20 lbs. Open the fan pattern wide open and mist over the whole part. The reducer will melt in and the metallic will settle evenly. It worked for me on a 77 step side I sprayed years ago.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 07-09-2019, 05:03 PM   #682
72c20customcamper
Hard to use old school on new paints. I'm a deluxe centari paint guy . The open period was a lot longer then but Its all good for a truck that will be used as as a truck. My Teckna spray gun likes at least 2 bar or it just spits. Should just dust off the old Binks No. 7.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-09-2019, 05:15 PM   #683
72c20customcamper
And its 1000% better the the general painted things . My uncle always commented in the GM MARK OF Excellence stickers on cars and trucks at the body shop . His interprition GM MARK OF CRUDNESS.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-09-2019, 05:28 PM   #684
72c20customcamper
Really didn't think I would like the saddle fawn color . I was contemplating 503 green for the truck but now I really like the color.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-13-2019, 09:09 AM   #685
Grumpy old man
Grumpy old man's Avatar
Blasted /primed and painted under dash pedal assemble . One more bite off the elephant
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 07-13-2019, 09:25 AM   #686
Grumpy old man
Test fitting panels and epoxy prime on this one this weekend .
Old 07-13-2019, 09:29 AM   #687
72c20customcamper
Looks great.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-13-2019, 05:20 PM   #688
Redneck Rydes
Redneck Rydes's Avatar
I sold both of my trucks,1970 C10 original paint,original owner,and my 1985 C10, having some loneliness today,gonna have to build my 1967 soon
Redneck Rydes is offline   Reply With Quote
Old 07-13-2019, 06:09 PM   #689
72c20customcamper
Painted the bed supports and started the install
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-15-2019, 05:26 PM   #690
72c20customcamper
Wood is working out nicely. Drilling all the holes then going to seal it . Need to hit it with some 220 on the da sander first . Decided to leave it raw no stain . Just seems to go better with the paint .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-15-2019, 10:21 PM   #691
projectking
projectking's Avatar
Cleaned everything and hit the lens with micromesh and finished with the buffer
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 07-15-2019, 10:28 PM   #692
Steeveedee
Who Changed This?
Steeveedee's Avatar
Looks nice! I want to eventually do something with my truck's dash. The vacant gauge hole on the right will be for trans temp, and the tach will replace the vacuum gauge as in your location. I'd like to do something with the gas gauge, with a way to tell fuel level in the main and saddle tanks. I know that that option was out there; I just need to research it. It looks goofy to have that huge gauge for the fuel level, to me.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 07-15-2019, 10:44 PM   #693
vitamin_c95
Finally located a new (reman) gearbox. Claims its a 3.5 turn. Almost completely installed. I just have to finish hooking up the steering shaft and linkage. It's a PITA to do by yourself, on your back with the sun blazing on you, after a full day shift at work, and sweat running down into your eyes.
1971 C20 Longhorn 350/350 "Conquistador"
vitamin_c95 is offline   Reply With Quote
Old 07-15-2019, 11:30 PM   #694
projectking
Thanks, I’m pretty satisfied with how it turned out. I’m trying to convince a buddy who does silk screens to make patterns for gauges so I can modify to my liking, he says he needs to figure out a new program...I’ll let you know if it’s a go!
67 Chevy C10 LWB
90 Mustang Gt
Old 07-16-2019, 12:22 AM   #695
3757chevy
3757chevy's Avatar
Beautiful.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 07-16-2019, 02:59 AM   #696
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
Not today, but this past weekend I did use it for it's intended purpose. Took it to my cabin for the weekend and brought back some firewood.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 07-16-2019, 09:05 AM   #697
72c20customcamper
Originally Posted by 3757chevy View Post
Beautiful.
Thanks . I'm waiting on the oil finish to arrive. Had to order it as it's not a stocked item around here . Penofin marine oil . I could have taken a ride to the coast some marinas carry it. Should be here tomorrow
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-16-2019, 07:56 PM   #698
72c20customcamper
Test runs on the offset washers and holes . Came out well in the test piece we shall see on the actual boards
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-16-2019, 09:40 PM   #699
Steeveedee
Who Changed This?
Steeveedee's Avatar
If you make that truck too nice, all you are ever going to haul in it is ass.
~Steven
Simi Valley, CA
Old 07-16-2019, 10:42 PM   #700
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Originally Posted by steeveedee View Post
if you make that truck too nice, all you are ever going to haul in it is ass.
lol. ......
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Ol Blue K20 is online now   Reply With Quote
