08-29-2018, 09:59 AM | #7201 |
Re: What did you do to your truck today? Chapter II
Thanks for the tip. I'll get in touch with them and ask a lot of questions. Enough on the computer, get working on the beast.
08-29-2018, 08:55 PM | #7202 |
Got my new wood bed installed.
1968 SWB Step Side, Big Block, 4L80E , Running! |
08-31-2018, 05:18 PM | #7203 |
Replaced my burned up ignition switch and wire connector. My truck would not start anymore. Oreily's had the parts in stock.
http://67-72chevytrucks.com/vboard/s...d.php?t=698292 |
09-01-2018, 02:02 AM | #7204 |
Engine out.....drum brake front end down. Got some clean up accomplished and some rust conversion sprayed. The last cross member bolt......the LAST one.....broke on me....lol. Pry bar and gravity and she dropped. Found the coil to still be original GM as well.
Patch |
09-03-2018, 06:33 PM | #7205 |
Good day today. Installed copper wire to get my oil pressure guage working. Replaced the master cylinder. Installed overflow bottle and new grille.
09-03-2018, 08:31 PM | #7206 |
Scored a stock 2004R 2-3 servo assembly for my trans from Pick a Part to downgrade the super servo that the local trans builder put in and then keep putting me off to fix my issues. I guess he thought i was wanting a 1/4 mile truck as the shifts up were very harsh and the 3-2 downshift was absolutely horrible. The sound of the clunk made it sound like I was going to drop the rear end everything I slowed to a stop.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
09-03-2018, 09:13 PM | #7207 |
Finally got the replacement parts installed from the near accident on Mothers day this year. My u-bolt on the lower control arm snapped when I was turning off a two lane highway and sent me,my wife and my camper into oncoming traffic. Got it stopped and no one was hurt. Truck got a bent upper control arm and inner tie rod.Got the truck home and it has sat till now.Pictures are of the right side but I had already done the left.
68' with no bells or whistles unless I add'em. |
09-04-2018, 09:54 PM | #7208 |
Got the front suspension cleaned and painted and installed this weekend! Very little blood was involved.....
Patch |
09-05-2018, 08:50 AM | #7209 |
drove it to work for the first time in a year
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt. Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD. |
09-05-2018, 10:29 AM | #7210 |
That truck belongs in Ontario. Too nice for the west to appreciate. Nice job! Have a good one eh.
09-05-2018, 10:40 AM | #7211 |
pft, don't be a hoser. West is Best.
09-06-2018, 09:43 PM | #7212 |
I've been ready to install the engine cross-member for weeks pending another hand. Last night I was feeling a little alone, go figure my son shows up out of the blue. We maint. his car, then slapped on the cross-member.
Hurry up and wait is the theme. Can't finish my engine pending the painter for my oil pan. Can't install the rear leafs pending new bolts, and I didn't account for reusing the U-bolt plates, pending powder coat. Can't do the front suspension because new drop spindles come unfinished. Always plenty to do however, methodically adding what I can to the frame, parts org. So many parts. PARTS REDUCTION ........I'm reusing most of the original hardware, no fun chasing them down.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 09-06-2018 at 11:00 PM. |
09-06-2018, 10:12 PM | #7213 |
New wheels and tires today!!!!! Ridler 695s 22x9 5inch backspace. 265/35tires. Now to get the truck sitting a little lower!!!!
09-07-2018, 12:33 AM | #7214 |
...hoser... lol
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
09-07-2018, 12:35 PM | #7215 |
Nice , Welcome aboard.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
09-07-2018, 02:24 PM | #7216 |
Very nice! Nothing like some bling to help the build along.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
09-07-2018, 11:48 PM | #7217 |
Got my engine running after a year of working on it and the rest of the install. Fixed a transmission cooler line leak, and two fuel line leaks. The thing sounds good. On the bad side it looks like I have a seeping leak on the pinion seal, which I put in when I rebuilt the rear. That means taking the rear completely apart again to replace the seal, and I have the new bed wood installed. Bummer.
09-08-2018, 03:00 PM | #7218 |
The GM Dealer training taught us to replace pinion seals in place.....
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
09-08-2018, 03:37 PM | #7219 |
How did you set the pinion preload without pulling it apart?
09-08-2018, 03:47 PM | #7220 |
What you do is : mark the position of the pinion nut relative to the shaft and re torque it to *exactly* the same position it was before you took it apart .
Those who lack experience will claim it's not the same and won't work etc. , those who've done it and never had a comeback, leak or failure over decades and 100,000's of thousands of miles, know better .
09-08-2018, 04:18 PM | #7221 |
Well for my first post ever I thought I’d share, long story short I traded a buddy work for doing a cab swap for a 67 LWB 2wd 4spd. It has a 6lug on front end which I would assume is factory and a full float Dana 60 8lug in the rear with leafs. I left work a little to happy on a Friday and grenaded the rear end. So I got a full rolling 74 chassis with SBC th350 2wd lwb. My plan is to swap the 12bilt into the 67 along with all the front suspension components to make it 5lug all around. Also I will put the th350 in it once I pull it and rebuild it.
So i finally got around to pulling the rear end and pressure washed it. Pressure washed the th350 in the chassis and it will get pulled next. Started measuring leaf spring lenghts and found I can not swap leaf spring due to length and spring width 😟. And I need a new driveling because the 60 had a 1350 ujoint and 12 bolt is 1310 I believe. And if anyone could help me identify which trans this is would be very helpful.
2008 GMC 2500HD 6.6l Duramax Diesel 67 GMC long bed 2wd my "main squeeze" 85 Toyota project, SBC, TH350, D60 front, D70 Rear, 3 linked Front, 4 link Rear. 43 Willys, family heirloom |
09-08-2018, 05:01 PM | #7222 |
I may try that. I think I tried to drive the seal in too far. Brain fart moment. Still have to get the torque on it under the truck though.
09-08-2018, 06:08 PM | #7223 | |
09-08-2018, 06:18 PM | #7224 |
Made a rack to hold a door and fender for paint.
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White 1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White. |
09-08-2018, 06:27 PM | #7225 |
Replaced the motor and transmission mounts to polyurethane mounts. Man what a difference,
1985 C10 shortbed, current project. Member of the Upstate SC GM Truck Club. |
