01-15-2020, 07:27 AM | #701 |
Re: 67 GMC super custom build
I'm just worried if I double it up and tighten it down it will bind or put too much pressure on the oil pump.
01-15-2020, 11:15 AM | #702 |
Right. Best to find out what the problem is and fix it properly.
Bob 1967 2wd Burb, 350/TH350, 3.73 posi |
01-18-2020, 12:41 PM | #703 |
Got it fixed. Just lightly tapped the oil pump shaft down and it dropped a little. Now the distributor sits nicely. Next to get the driveline on the frame
01-18-2020, 12:54 PM | #704 |
Is the T400 and gear vendor unit the plan for the drivetrain?
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
01-18-2020, 02:36 PM | #705 |
Yes it is
02-20-2020, 01:30 PM | #706 |
Getting it off the stand today! Should be on the chassis next week. Took a break from anything major for a bit but feeling like getting back at it again.
02-20-2020, 10:38 PM | #707 |
Looking good. When do you plan to have it running?
02-21-2020, 10:50 AM | #708 |
It was supposed to be running before Xmas. Guess I missed that ship. I'll probably get it all in the chassis Tuesday. From there It will probably be a month. Need to get my rad done still before I can run it.
03-22-2020, 09:50 PM | #709 |
The suspense of seeing your truck done is killing me and my dad. Your doing some amazing work though. Want to work on my truck. LOL! Have a good day.
03-23-2020, 12:31 AM | #710 |
Thanks for the kind words. I too wish it could happen faster. Happy to have you following along.
03-24-2020, 11:07 AM | #711 |
Not to fast though, you do want to enjoy the moment of things coming together piece by piece. Happy to have you on here too, giving me ideas for truck
03-28-2020, 08:47 PM | #712 |
My next modification. Ez lift tailgate and tailgate lowering damper from the newer Silverados. When completed you will never even know a mod was done with the gate on the truck. Plus I'm going to use the trunions with the delrin bushings to quiet down the gate when in use.
03-28-2020, 10:12 PM | #713 | |
03-29-2020, 12:40 AM | #714 |
If you look at member crossbreed's build in the blazer area at the end of it he gives all the part numbers and shows how it all works. It's sweet.
03-29-2020, 01:47 AM | #715 |
I'll have to check it out for sure. Thanks
03-29-2020, 03:18 AM | #716 |
Agreed. That sounds like a good read. I'll have to check it out.
Project looks great! |
03-29-2020, 09:36 AM | #717 |
Thanks for bringing the crossbreed build to our attention! I'll be wanting this mod too....
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
03-29-2020, 11:53 PM | #718 |
Do you have a link for the thread on this mod??
72 GMC highlander nicknamed by my then 6-year-old brother "stripes" http://67-72chevytrucks.com/vboard/s....php?p=7378180 Check out my Youtube channel @Chad's Fab |
03-30-2020, 12:09 AM | #719 |
https://67-72chevytrucks.com/vboard/...=736217&page=5. Pages 4 and 5. He has a video showing it in action. It is pretty cool
04-06-2020, 01:42 PM | #720 |
Primed my engine yesterday getting it ready to install. While priming it I noticed my new oil pump sure is noisy. I may have to replace it. Not sure if this is normal or not. Had no problem with getting oil to the rocker arms though. Pressure seems good.
Watch "Distributor noise 327" on YouTube https://youtu.be/yxYskCEgSHA |
04-06-2020, 08:56 PM | #721 |
Just here to tinker
I just read through this whole thread. Absolutely amazing work! Boy I wish had anywhere near the patience you have....
Those valve covers are amazing. As is everything else you've done. Great work!
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
04-07-2020, 12:27 AM | #722 |
Thanks. I appreciate it. My engine builder said I should be ok with that oil pump so I can soon get it in the frame. With covid19 out it may take a bit as I can't have anyone over to help so I may find a few other projects to do before the drivetrain gets in.
04-08-2020, 06:18 PM | #723 |
Just here to tinker
So far out of all my truck engine/trans/gear combos, my favorite by far was the T400/Gear venders/3:73 in my 78 SWB. Loved it!
04-08-2020, 09:07 PM | #724 |
Yeah I'm pretty excited about the driveline. I wish I would have done 3:73 or even 4:10 but I hope the 3:55 rear will be ok. My engine builder built my engine for those specs so I'll leave it now.
04-13-2020, 01:16 AM | #725 |
Got the damper side all finished up today. Tomorrow I'll start doing the easy lift side of the gate,
