Old 10-14-2017, 03:21 PM   #701
MTCK
MTCK's Avatar
Re: 1991 V3500 Project Heavy Hauler
It’s that time of year where we are scrambling around here to finish work projects, finish home projects, finish truck projects because the white stuff is coming. Grabbed a mini ex and helped my father in law do some rock work around his place. They live up in the hills so getting a loaded equipment trailer then a loaded dump trailer up there wasn’t boring.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Plow Truck
MTCK is offline   Reply With Quote
Old 10-14-2017, 03:25 PM   #702
MTCK
MTCK's Avatar
I had to put the hubs in to get the load of gravel up the driveway and figured what the heck I’ll put it in low to make it easier on the truck. No go. Power to the front axle only. Tcase works as advertised besides this one issue. Do I have a shift rod out of adjustment or something more sinister? I dug a hell of a home in their driveway with my front left tire...
And we did not beat the snow...
-Marcus
Project Plow Truck
Old 10-15-2017, 12:40 PM   #703
jhama78
jhama78's Avatar
definitely sounds like a shift rod misadjustment
-j-rod
'06 3500 LWB CC 4wd, 8.1 Allison
jhama78 is offline   Reply With Quote
Old 10-17-2017, 03:48 AM   #704
MTCK
MTCK's Avatar
I’ll have to pick your brain a little j-rod, when I get to a stopping point. Butts and elbows right now trying to get all the crap put away and plow truck ready for snow. Oh and it’s snowing! Thanks man, talk to you shortly.
-Marcus
Project Plow Truck
Old 10-17-2017, 09:32 AM   #705
jhama78
jhama78's Avatar
Sounds good man, shoot me a text when you get a chance. Have fun with the termination dust.
-j-rod
Old 10-24-2017, 12:53 AM   #706
Indyfab
Indyfab's Avatar
Great truck Marcus, what brand/application are your side steps for? I've been searching for some for mine. I apologize in advance if you already if you already posted this. I'm only to your 454 rebuild section, saw you were online and thought I'd ask.
Indyfab is offline   Reply With Quote
Old 10-24-2017, 12:58 AM   #707
MTCK
MTCK's Avatar
Appreciate it. No worries at all. N-Fab makes the steps. They say for a 2500HD but I forgive them since they actually make some steps for our trucks. Also are available for short and long bed regular cabs and sunurbans I think.
https://www.n-fab.com/products/sfID1...productID/1000
-Marcus
Project Plow Truck
Old 10-24-2017, 01:14 AM   #708
Indyfab
Indyfab's Avatar
Thanks, found them. I tried searching that brand once even. Looks like I can save almost $50 ordering them through summit though.
Old 10-24-2017, 01:36 AM   #709
'63GENIII
'63GENIII's Avatar
Thats a weird issue to have there Marcus. Im fairly certain that my 205 has no adjustment on the shift shafts and unless you are twin sticked, the equalizing bar that is between the two shafts makes it near impossible to get the front axle without the rear. May be part of the equalizer bar (don't know the name for it) missing?
I know that the shafts for a twin stick usually have some of the detents machined or ground out.
Front axle only is a strange one for sure. I would like to hear what you find.
The truck looks awesome as usual and its great to see her putting in the work as intended!
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 10-24-2017, 03:13 AM   #710
MTCK
MTCK's Avatar
Thanks Chris. I’ll keep you posted on the tcase. Honestly it’s pretty far down on the priority list right now. The one car (wife’s) garage is full of truck parts, plow truck has no fuel tanks, crew cab has no topper, camper has no cover and it’s dipping below zero already!
Speaking of cold, here’s a reminder of why I prefer gas: gelled fuel happens to someone I know almost every year.
-Marcus
Project Plow Truck
Old 10-24-2017, 03:15 AM   #711
MTCK
MTCK's Avatar
Kind of a fun mission since this same 9,000 lbs super duty died a few years ago when I had the tired tbi 350, and smaller tires, and I could not get it up the 12% grade on packed snow to the top where it lives.
-Marcus
Project Plow Truck
Old 10-24-2017, 03:18 AM   #712
MTCK
MTCK's Avatar
Challenge accepted. Heavy throttle at first with lots of pedaling when the tires started spinning and we made it. Should have had the go-pro going it was loud and fast and impressive.
-Marcus
Project Plow Truck
Old 10-24-2017, 03:22 AM   #713
'63GENIII
'63GENIII's Avatar
Had that same thing happen in CO one year with a 7.3 CC I had. NOT FUN!
I know that you've hit a new benchmark when you can pull anything on a snow covered road thats upside down . I get what you mean! Now to unscramble my eyes and brain .
Still on of my favorite trucks here! Good luck with the Winter prep.
Chris
'63 k15 long step
Old 10-24-2017, 03:25 AM   #714
MTCK
MTCK's Avatar
Credit goes to the siping done to the ST Maxx tires and additional horses.
-Marcus
Project Plow Truck
Old 10-24-2017, 03:31 AM   #715
MTCK
MTCK's Avatar
Stupid upside down roads! Here is the view from the top. Thanks Chris it would be even more impressive on its lid haha!
-Marcus
Project Plow Truck
Old 10-24-2017, 09:39 PM   #716
cochino12
It followed me home?
cochino12's Avatar
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 10-25-2017, 09:22 AM   #717
68Timber
I know the pieces fit
68Timber's Avatar
Such a great truck.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 11-29-2017, 06:20 PM   #718
kacy
kacy's Avatar
I missed the specs on the cam, I am planning a similar swap into my V10
79 Corvette- 406/7004r Holley EFI
87 V10- 5.7L, Vortec heads, E110026, 410s 35s, 700r4
kacy is offline   Reply With Quote
Old 11-29-2017, 07:19 PM   #719
Matt Man
Matt Man's Avatar
Does your truck have any kind of lockers? I'm worried about my truck behaving in the snow with the detroit in the back.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 11-30-2017, 01:08 AM   #720
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice you're getting more work out of it! Yeah, you have to be pro active when owning a diesel for sure. Luckily we haven't stayed cold here yet. Did you have any time to look into your tcase issue yet? The siping definitely makes a big difference in the snow for sure. We switched over to tires with siping on our fleet at work since they all have the traction control you can't disable. Best thing we've done yet.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-30-2017, 11:16 AM   #721
Ski-me
Ski-me's Avatar
Just found your thread...very nice build! Love the stance and overall truck itself.
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 12-17-2017, 03:02 AM   #722
MTCK
MTCK's Avatar
Thanks guys. Sorry haven’t been around much.
I’ll have to go back and look at my cam specs. Are you going to swap a gen 6 big block in?
Open diffs front and rear. Needs something. I’d like a pair of true-tracs. Maybe I’ll try one out on the plow truck...
Haven’t diagnosed the tcase yet. 4hi works fine so I’m rolling with it for now. We run the same tires siped on all our work trucks and they aren’t half bad in the snow. Way better than not siped!
-Marcus
Project Plow Truck
Old 01-01-2018, 01:55 AM   #723
farmall
farmall's Avatar
See page 4 for shift fork info.
This is the thread I followed to rebuild mine.
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 02-01-2018, 02:15 PM   #724
kacy
kacy's Avatar
Yeah I picked up a complete swap from a 98 with 180k on it for a song, just either have to convert the 2wd 4l80 to 4wd or find another. i already picked up a np208 and adapter/mount from a 3/4 with th400/208
Old 03-16-2018, 12:50 AM   #725
MTCK
MTCK's Avatar
Hey Kacy, I still owe you cam specs.
I finally got tired of taking my crappy radiator in and out to have the shop fix the latest leak it sprung. So I went to Napa and got a part number NR 2071 Napa brand radiator coming. No more spectra Chinese radiator! They only wanted $50 for freight and the price was right.
Imagine my surprise when I picked it up today and it was a spectra CU774. Same freaking part number. This one is made in Japan though and survived the trip over the pond much better with no dings. So I thought Larry had one from Canada, and now I have China and Japan covered.
-Marcus
Project Plow Truck
