09-21-2018, 06:53 PM | #7276 |
Re: What did you do to your truck today? Chapter II
got new tires and wheels.
09-22-2018, 04:43 PM | #7277 |
Test fitted my new door and kick panels. Finally covered the dreaded speaker hole.
09-23-2018, 10:54 AM | #7278 |
Actually yesterday but...
Installed the water pump, intake, throttle body, accessories and belt system, valve covers, headers, and fan relays and harness.
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
09-23-2018, 04:25 PM | #7279 |
At the body shop.
Drivers training days.
My daughter has claimed old blue and wants to get her license in it. Except she's getting the Sonoma 1st.
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 09-24-2018 at 01:13 AM. Reason: Forgot the pic |
09-23-2018, 06:29 PM | #7280 |
Fired it up after top end refresh and retrofit roller cam completion... open headers, no O2 sensor to get it to run right -EFI on top-
https://youtu.be/7W148nXt60A -klb
09-23-2018, 08:20 PM | #7281 | |
09-24-2018, 12:16 AM | #7282 | |
I live not too far from Fort Worth. |
09-25-2018, 12:08 AM | #7283 |
Who Changed This?
Got the new Cold Case radiator delivered today. I was at the care facility where my MiL is for rehab after falling last Tuesday, so one of my sons brought it into the house. He'll be the one putting it in with "parental supervision", because I still have "candy hands" after carpal tunnel surgery, over a year ago.
09-25-2018, 01:54 PM | #7284 |
Put in a new axle in the 67 GMC over the weekend. Took out the old 12 bolt with a bad pinion bearing and replaced it with a 14 bolt, 6 lug, 3/4 ton axle from a 91 chevy. No more grinding noise! yay! New headlights with led halos from Octane lighting just showed up the other day that will be installed shortly. So then I can actually see at night.
09-26-2018, 08:39 PM | #7285 |
My truck "Gene" got new shoes!
68' with no bells or whistles unless I add'em. |
09-26-2018, 09:14 PM | #7286 |
Hi, I chased a nasty miss on the “new” crate motor, now with 7k miles. I replaced the hei cap and rotor, pulled the carb, completely dissassembled it and cleaned it. I didnt find the issue until I pulled the plugs and found #6 fouled terribly. Yikes. The wire had been rubbing on the dipstick tube and sure enough there was gray “tracks” on the tube.
I replaced the wires and 8 fresh R45TS plugs and that wire. Now she runs on all 8 and goes like the wind.... Day well spent! Tom
1972 GMC C1500 350/350 1965 Mustang 2+2 289 4spd, show-car 1965 Mustang Coupe 289 4spd, stoplight racer 1/2 dozen Wheelhorse Tractors |
09-26-2018, 11:10 PM | #7287 |
Thanks! I'm going to try to make the Good guys event this coming weekend at Texas Motor Speedway if the rain stays away! Come by and say hello!
-klb
09-27-2018, 08:01 PM | #7288 |
Got my new license plates
09-28-2018, 09:15 AM | #7289 |
Replaced the trans cooler lines. Po used gas line to fix rusted areas. Needless to say it turned to a mushy black piece of penne pasta like consistancy. All new steel with the proper oil cooler hose.
09-28-2018, 11:16 PM | #7290 |
09-28-2018, 11:54 PM | #7291 |
It's not so much what I did as what She did...
09-29-2018, 07:43 AM | #7292 |
Proprietor of Dale's Corner
I hope everyone is ok.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
09-29-2018, 09:17 AM | #7293 |
I live in DFW. This is not an unusual occurrence.So sorry about your truck!
09-29-2018, 09:08 PM | #7294 |
got the new headlights installed. Wired the LED Halos up for daytime running lights.
09-30-2018, 01:41 PM | #7295 |
Temp sender for gauge quit working. Since I had to drain the cooling system, I decided to change out the intake manifold gasket as who ever installed it used the rubber end pieces and of course leaking. Last oil leak fixed. Had an issue with an air pocket causing the gauge to peg, but got it sorted out. Next up is the headlight relay update since its getting dark earlier now.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
09-30-2018, 04:48 PM | #7296 |
Old member
Nothing big but I fixed my exhaust leak at the flange. The flange had cracked so I welded it up. I stuck a small bolt in the crack to fill it up .
No more leak are loudness!
09-30-2018, 08:44 PM | #7297 |
Wet sand and some wax. Cleaned up nicely.
09-30-2018, 08:58 PM | #7298 |
It's also lower and with darker wheels/trim pieces.... looks real good!
-klb
09-30-2018, 11:03 PM | #7299 |
Bled the brakes and installed the motor in the truck. Making progress!
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
09-30-2018, 11:53 PM | #7300 |
Lowered the mirror on the door also.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
