Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech
Old 08-06-2005, 10:41 PM   #51
hilljob26
hilljob26's Avatar
72 1/2 ton 4x4 w/ 35's and 6 inch lift
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline
Old 08-10-2005, 11:22 AM   #52
Pacemaster
New to me 67 custom camper
All stock except for a strong 350
Pacemaster is offline
Old 08-30-2005, 01:52 AM   #53
1sick7
bags and bodydrop with 22x9.5 with 265-35-22
1sick7 is offline
Old 09-18-2005, 10:17 PM   #54
Slammed66
Needs a Big Block
Slammed66's Avatar
First pics is 225/70's front and 275/60's on the back all 8 inch rallys
Sec pic is 245/60's front and my " Red Neck" 295/50's on 15x11 rallys
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline
Old 09-20-2005, 08:35 PM   #55
Vince M
Vince M's Avatar
Here's my combo...... Impala SS factory rims which are 17" x 8.5" with 5.125" backspace. Tires are 265/65/17. I had 31 x 10.5 on 15 x 8 ralleys and the new combo sits higher, rides smoother and absolutly tracks straight with no vibration.
68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements.
Vince M is offline
Old 09-23-2005, 02:16 PM   #56
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Come on guys and gals...where are the stock and original photos? Here is the stock split rim on stock height '68, 3/4 ton with 7.50x16 split rims and the original hub cap.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline
Old 09-30-2005, 10:58 AM   #57
bs25j
bs25j's Avatar
68 chevy
I have a 2/4 drop on my 68 3/4 ton and im trying to figure out what kind of backspacing or offset im gonna need to use to fit 22's on it without rubbing, so if anyone has any info. on it that would be great.
bs25j is offline
Old 10-03-2005, 01:17 AM   #58
Premium72
Premium72's Avatar
what do you guys mean by back spacing?.. that how much the wheel goes in around the hub? thanx. im goin with some chrome smoothies my self and maybe some white walls not sure yet...awesome thread.
Premium72 is offline
Old 10-05-2005, 08:37 PM   #59
Vince M
Vince M's Avatar
Check out the link for how to measure backspace. Hope it helps.
How to measure backspace
Vince M is offline
Old 10-17-2005, 12:54 AM   #60
dseipel
Re: Wheel/Tire Fitment Pictures & Info
Would a '72 chevy long bed look good w/all chrome rally rims 15x8 w/ the derby caps, sporting 275 60 15 bfg t/a?? I cant decide on 20's or stock size.
dseipel is offline
Old 10-17-2005, 11:42 AM   #61
Pacemaster
Installed the 8'6" Cabover last month. Yesterday my friend and i swapped out the 5:12 diff carrier and installed a good 4:10 unit. nice rpm drop at highway speed.
Old 10-18-2005, 03:45 PM   #62
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Originally Posted by Elsie72
Ok, here is my truck, 72 Long bed with 2 1/2" drop spindles, and 1" drop coils in front, and 5" drop coils in the rear. Tires are Good Year Eagle GT II's 235-60/15 front and 275-60/15 rear on 15 x 8 steel rallys with 4" bs, I believe.
After studying and figuring I have decided to go with the same drop (2 1/2 Spindles 1" coil and 5" coil in the back) as you. When I saw the pics of your truck I couldn't figure out why the rear of your truck is still so much higher than the front cause my plan is to get mine almost even front to back. I have figured out why yours is so much higher in the back and its because your rear tires are 1.88 inches higher than the fronts. Did you replace your shocks or use the super track bar with this drop?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
Old 10-18-2005, 08:45 PM   #63
Dual quad
Smell that burnin' rubber
Dual quad's Avatar
Already Gone, I only come up with .88" difference (28 vs 27.1). Also, remember that the only half of that (to the center) will impact the vehicle height.
Dual quad is offline
Old 10-19-2005, 09:11 AM   #64
Already Gone
Hi Dual Quad that truck looks to me like it has way more than 1" diff in height from front to back.
..Here is how I figured it out. Let me know if I missed something.
275mm=10.82in tread width x 60%= 6.49in. Therefore 6.49(ground to rim)+6.49(top of tire down to rim)+15.00rim diameter = 27.98in.Rear tire
235mm=9.25in tread width x 60%= 5.55in. Using same formula as above 5.55 + 5.55 +15.00 = 26.1in front tire............... 27.98-26.1 = 1.88.. I've always figured it like this and I use .03937 x the tread width for my inch measurement.
Old 10-19-2005, 10:15 AM   #65
Dual quad
Dual quad's Avatar
Yep, your right, I used a 16" wheel on my spreadsheet for the smaller tire, thus the 1" error. Nonetheless, a 1.9" overall height difference will equate to only half of that difference (less than 1") in body height. This is because only one sidewall contributes to the distance to center at any one time.
Old 10-25-2005, 11:07 PM   #66
sickred72
72 swb 20x8 front 4"backspacing 20x10 rear 5" backspacing custom made intro's
sickred72 is offline
Old 10-26-2005, 11:24 AM   #67
shelby987
shelby987's Avatar
Does anyone have any pics of a stock 3/4ton 4x4 on 33's. Would like to see if anyone has done this with or without a lift, and how much of a lift.....thinking of 2"
shelby987 is offline
Old 10-31-2005, 06:38 PM   #68
smbrouss70
smbrouss70's Avatar
So, where are the pics?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline
Old 11-02-2005, 08:21 PM   #69
davidh
davidh's Avatar
My Car Craft a month or two ago said they were amazed at how many cars were running 15" wheels again, and that a majority of them were crager s/s wheels!
davidh is offline
Old 11-02-2005, 11:03 PM   #70
67chevemall
67chevemall's Avatar
a%% shot!
Cheers
Two those who run this board
Thanks and God bless you
It is great to be here
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline
Old 11-09-2005, 02:00 PM   #71
davidh
davidh's Avatar
All the 3/4 ton hubcaps for 67-68 I've ever seen were the white ones. Nice chrome.
davidh is offline
Old 11-09-2005, 02:07 PM   #72
truckdude239
truckdude239's Avatar
i got crome vette rally rims 15x10 with disc brake caps
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline
Old 11-09-2005, 03:24 PM   #73
71Subman
71Subman's Avatar
Here's another 4x4 entry. '71 Sub 1/2 ton. 4 inch Skyjacker lift. 15x8 wheels (standard backspace) and 35x12.5 Goodrich All Terrains. No rubbing and rides great. The 35s make the 3.73 gears feel a little inadequate when I tow the race car, but it does it.
Noise Makin', Gas Gusslin', Big Ass Metal Monster!
1983 3/4 4x4 P/U (the Sub is gone)
1967 Firebird (Drag racer)
1967 Firebird (resto in progress)
1999 Camry (Wifey's econo-rail )
1997 VW Jetta (Daughter's cruiser)
1989 Le Mans (just extra for the boys to drive)
71Subman is offline
Old 11-09-2005, 09:50 PM   #74
purple gas
Great freekin idea.. I am trying to decide what size of rubber to put on my truck and have been wondering if there was such an easily accessible way to compare.. You'd almost think tire shops would have something like this for their customers. Probably will,,,,,, some day.
I got a bench seat baby, you don't have to sit over there.
purple gas is offline
Old 11-10-2005, 12:18 AM   #75
SigSauerGuy
Oldrock&roller: any engine pics? what kind of exhaust do you have coming out the side?
Caterpillar rules...
...born with yellow in his veins!
1971 Chevrolet Fleetside 8 ft bed 350 w/TH400
SigSauerGuy is offline
