Old 11-10-2007, 10:20 PM   #51
SactoJim
SactoJim's Avatar
Re: How to: Ruin a perfectly good Blazer...
Takes a brave soul to chop up a cherry blazer like that, but it looks like you are doing a helluva nice job!......nice fab work.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 11-11-2007, 12:36 AM   #52
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by babyblueoval View Post
Gringo,
You wanna take a short 2 1/2 hr drive over here to Little Rock and help me lay out mine?
Nice work.
Originally Posted by jkade View Post
I need some help on mine this weekend also.
Then who would be here to do mine?
I wouldn't even have thought of doing something like this without being corrupted by this forum
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-11-2007, 07:28 PM   #53
gringoloco
A guy with a truck
gringoloco's Avatar
Since the rear seat will be attached directly to the floor, and I have lost some of the rigidity by removing a large portion of it, I decided that I would mount the notch cover directly to the notches. To do this, I drilled a couple of holes in line with the recesses in the floor and welded nuts inside the top plate of the notch. I will use grade 8 hardware and rubber mounting pads from a truck bed for a little NVH isolation. I didn't get far before the shop foreman stepped in and shut me down...
-Chris
Old 11-11-2007, 11:36 PM   #54
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Good idea
Well your "foreman" is a good reason to stop... lol
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 11-12-2007, 03:38 AM   #55
gringoloco
A guy with a truck
gringoloco's Avatar
After the warden went to bed, I made a little more progress. First, I drilled some holes large enough to pass the taillight/fuel sender harness through so they can route inside the notch. These also make good access holes for spraying corrosion preventive goo inside the notches.
You can see in the next pic that I made braces to keep the outer plates from bowing inwards when I did the final pass. Then finished up welding the plates on the inside and fitted the top cap.
Next step- Cut the frame I still need the burn the bottom cap in, then I get to do it all over again on the passenger side...
-Chris
Old 11-12-2007, 05:04 AM   #56
Iron-Butt
454 club
Iron-Butt's Avatar
great progress.
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 11-12-2007, 05:34 PM   #57
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by ironbutt_lcmc View Post
great progress.
Thanks. I'm chuggin' along... Got the bottom cap welded in and slapped on a coat of Rust Encapsulator. Looks like Ill have to trim the panhard bracket a little.
-Chris
Old 11-13-2007, 05:42 PM   #58
babyblueoval
babyblueoval's Avatar
Well by the looks of the progress you're making, you'll be done with yours before I ever get started.
Jim
'71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E
'57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works
'87 BMW 325i - daily driver
babyblueoval is offline   Reply With Quote
Old 11-13-2007, 05:51 PM   #59
jkade
jkade's Avatar
Well I got mine welded in without your help I also figured out that I could still use my rear trailing arms with a 3" block to use all but 1/2" of my notch. I guess I am going ahead with the nascar truck arms instead of the 4 link.
jkade is offline   Reply With Quote
Old 11-13-2007, 06:13 PM   #60
gringoloco
A guy with a truck
gringoloco's Avatar
What's the hold-up?
Sweet. That will make things much easier. Pics?
Lil' more progress- mostly just an excuse to post some needless pics . I used the old captured nut trick to install the 'button' bumpstops. They are slightly forward of the notch centerline 'cause that's where the axle will rest when dumped. I also got the panhard bracket trimmed and installed the other side's bumpstop.
-Chris
Old 11-13-2007, 07:53 PM   #61
babyblueoval
What's the hold-up?
Well, it's mostly scheduling getting with my friend where my truck is about an hour away. I don't have the room or tools to do it and he's done it many times and has the tools.
I'm also having trouble getting my Vette parts. I'm disputing a charge on my cc right now because I've only received a few of the parts.
Once it finally gets started it should go fairly quickly I just need the front suspension so we can get the front together to make it a roller.
THEN the pictures will start flying.
Jim
Old 11-13-2007, 08:01 PM   #62
jkade
jkade's Avatar
[QUOTE=gringoloco;2444238]What's the hold-up?
I will post up tomorrow, I always leave my camera cord @ work. And yes it will be much easier and cheaper. I know it will lay out with a 275/35/20 or I am fairly sure it will.
Old 11-13-2007, 08:18 PM   #63
jlaird
jlaird's Avatar
where did you get the bumpstops?
jlaird is offline   Reply With Quote
Old 11-13-2007, 11:23 PM   #64
gringoloco
A guy with a truck
gringoloco's Avatar
They are a Prothane piece. Part# 19-1316. They are 11/16" thick. I think I will order a set of the 19-1319s- they are 3/8" thick- every little bit counts...
-Chris
Old 11-14-2007, 10:06 AM   #65
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Sweet !!!
I wanna see those after pics bad now !!!!
Sinister
Killer
Old 11-14-2007, 11:57 AM   #66
grnddwn
belly dragger
grnddwn's Avatar
I build a whole new frame for my floor and mounted the seat to it. I found that the floor still flexed a little too much even with notch cover. I didn't think of attaching it to the frame though, and minewas in being bodydropped 2" anyway.
Truck looks sweet.
SAVE THE PLANET DRIVE AN OLD TRUCK
grnddwn is offline   Reply With Quote
Old 11-14-2007, 12:09 PM   #67
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Looking good man! Can't wait to see some more
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 11-14-2007, 04:48 PM   #68
Frizzle Fry
Frizzle Fry's Avatar
I have a suggestion for you:
When you bolt your notch cover to the notch like that the bolt will transfer the noise/vibration even if you have a pad/bushing in between.
I have some of these I am going to try out for the notch cover (form b).
Frizzle Fry is offline   Reply With Quote
Old 11-14-2007, 09:55 PM   #69
gringoloco
A guy with a truck
gringoloco's Avatar
I like the look of those, but don't have the room for them I'll never sit back there anyway...
-Chris
Old 11-15-2007, 10:43 AM   #70
XXL
Seρor Member
XXL's Avatar
Why are you bolting on the notch cover? Seems like a nice zip around it with the welder would be fine. You didn't have access from the top before, so not sure if there's any value to having top access now.
XXL is offline   Reply With Quote
Old 11-15-2007, 11:19 AM   #71
abadsvt
abadsvt's Avatar
Looks good Gingo! About time you get blazer in the weeds!!! Keep up the work.
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 11-15-2007, 12:04 PM   #72
gringoloco
A guy with a truck
gringoloco's Avatar
I don't necessarily need to have access, although it will be accessible if need be in the future(though I can't imagine why I'd need to.) Since the seats I'm using have integrated belts, I'd like to regain some of the stability/rigidity lost when cutting the floor. In short- peace of mind.
Josh
Thanks. Funny- I was just looking back on your build last night- looks good! When you gonna build a frame for my truck?
-Chris
Old 11-15-2007, 03:38 PM   #73
Frizzle Fry
Whatever you do, I think you should avoid a solid mount anywhere between the frame and body. Just my $.02
Old 11-15-2007, 05:08 PM   #74
gringoloco
A guy with a truck
gringoloco's Avatar
The plan goes something like this: The bolt will go through a fender washer, rubber pad, floor, another rubber pad and into the frame. Not as optimal as say, building a body mount off the side of the notch, but metal-to-metal will be isolated. I like those bushings you are using, but I think they would pull through if they ever got yanked on hard enough. What do you think of this design? Thanks for the input. You know I value your opinion.
-Chris
Old 11-15-2007, 07:24 PM   #75
Frizzle Fry
Ya, since you are mounting a seat to it your plan is good. Be sure that bolt hole is big enough that the bolt will never touch the body. Like you said, you could do a body mount off to the side of the notch, but may not be necessary. In blazers and burbs I worry about this more than I would a truck.
