Old 04-22-2008, 04:14 PM   #51
protrash64
Resistance is Futile
protrash64's Avatar
Re: 1964 Suburban Pics
Joe231....your second response is correct. I arranged it this way due to the tank and the space limitations. The tank feeds the T in the center and the outlet to the bags is inbetween each pair of valves. The valve on the end is the exhaust........after talking w/ Dino yesterday I will be adding a reducing pipe fitting on the exhaust and to slow the release of air from the bags. Ive seen Dinos Panel in action and its scary fast!!!!!! Its ok if you're set up for that type of movement, but I will not be.
The compressors are Viair 400's......very fast recovery time but suck about 60a's.......it will be 150psi system. I will probably need to bump up my electrical system to keep this thing going.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 04-22-2008, 06:01 PM   #52
joe231
joe231's Avatar
cool, thanks for the info. why would you need to slow the decent? easier adjustability, or could you tear something up letting it down too fast? what would need to be "set-up" for the faster lowering? Thanks
CHEVY ONLY
Old 04-22-2008, 08:21 PM   #53
kdrodworks316
KOFFIN DRAGGER
kdrodworks316's Avatar
my 62 is a fast up and down, I hate it. it bounces your head off the roof on the way up and smacks the frame so hard going down, you think you broke your back. the new set up will be slowed down to a reasonable speed. Also, my setup is on a four link. thats way fast and violent sucks joe
kdrodworks316 is offline   Reply With Quote
Old 04-23-2008, 12:58 AM   #54
protrash64
protrash64's Avatar
Joe231..........krod nailed it on his response. You also have it in yours......its more easily controlled and in my case I have exhaust, brake lines,and whatever not up to the task..........no notch in place, etc. This is what i meant by being set-up. My buddy has one bagged w/ 1/4" line and its extremely mellow. Dinos truck is all custom and it hits the ground and sounds like a big garbage dumpster being dropped on the ground. It drops as fast as gravity can do its job.
Old 04-23-2008, 04:29 AM   #55
joe231
joe231's Avatar
thanks guys, makes since to me. I would like a relative fast drop, and slower rise. guess I will have to do some testing. while we are on the subject, are all valves created equal? what are the ones you guys are running? how are the viair 400s as far as price? I think I would like to run a york on the engine, but dunno yet. Thanks for everyones patience and help!
CHEVY ONLY
Old 04-24-2008, 03:51 AM   #56
protrash64
protrash64's Avatar
Joe231.........I pieced this system together using some donated parts from Dinos63(and a bunch of info) and some cheepo parts that my friends had extra from their projects. I am new to this stuff and I am learning it as I go.
I chose the 400's for compressors due to their fast fill time. I think under 3min for a 5gal tank(2.54cfm a piece) and cheaper than the 2 packs I see advertised.........on the suspension section I asked people to tell me about their bag pressures and NOBODY used more than 120psi. I dont see the point of going to 200psi.........the trade-off was the 60a draw. I figured I was going to have to wire the compressors anyway; what difference does it make if I use larger wire?
To update you on the slowdown.......what I chose to do was get 3/8s pipe plugs. I can now drill them small and adjust the speed to my taste. If i bought a reducing fitting I would be stuck....these all cost in the neighborhood of 2 bucks apiece. I used Parker valves because thats what I could get from my friends.
If you want to go slow up, use smaller line than 1/2"........somebody mite know differently.
Old 04-24-2008, 04:08 AM   #57
joe231
joe231's Avatar
cool, thanks!!
CHEVY ONLY
Old 05-02-2008, 02:16 AM   #58
protrash64
protrash64's Avatar
Heres an update..........nothing like making a project out of a project! I picked up a project box from Radio Shack and installed my junction block and relays for the compressors inside. The box has a cover for when its completed. Finished mounting it to the frame and ran my battery cable; its temporary as I will add a second battery when the time is correct; that explains the wire ties and the big loop. I now must wire the switches and feed the pressure switch on the tank.......then on to the bags themselves.
Old 05-02-2008, 02:52 AM   #59
joe231
joe231's Avatar
looks sweet!
CHEVY ONLY
Old 05-02-2008, 03:18 AM   #60
Iron-Butt
454 club
Iron-Butt's Avatar
looks good
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 05-02-2008, 03:33 AM   #61
kdrodworks316
KOFFIN DRAGGER
Hey joe, my setup is exactly what you want. I have 4 1/2 valves and 1/2 inlet bags with 1/2 line. This is huge stuff when your talking an air system. I run a york compressor that works great. I would advise some kind of choke on the dump valves, fast violent is only cool for about 5 minutes when the chicks are looking. after your back is broke from slammin asphalt, its not cool anymore. just my own 2 cents
Old 05-02-2008, 03:50 AM   #62
joe231
joe231's Avatar
thanks kd, do you have any words of wisdom on running the york? did you have to modify the compressor? how big of a tank do you run? I'm figuring on running 1/2 stuff.
CHEVY ONLY
Old 05-02-2008, 04:20 AM   #63
kdrodworks316
KOFFIN DRAGGER
I would suggest some kind of oiling system. mine is just a hand pump type. give a couple of squirts and let her run. only mod I did was an air cleaner and a pressure line to the tank. I run a 5 gallon tank and the york keeps up all day long. 120 psi anytime I need it. put it on a pressure switch to kick out the clutch on the compressor. hit me up if you have anymore questions
Old 05-02-2008, 04:24 AM   #64
joe231
joe231's Avatar
cool! do you have any pics? thanks man!
CHEVY ONLY
Old 05-02-2008, 06:06 AM   #65
kdrodworks316
KOFFIN DRAGGER
all the pics are in drag and destroy rebuild thread.
Old 05-02-2008, 06:16 AM   #66
joe231
joe231's Avatar
ok
CHEVY ONLY
Old 06-07-2008, 07:59 PM   #67
protrash64
protrash64's Avatar
.........Ok, here are some updates as progress is slow.
My slow downs on the valves.......drilled3/16's thru some caps.....can make 'em bigger if I need to do so.
Made a switch panel and wired in battery power for the switches and ignition power for the tank pressure switch. Mounted on dash for easy reach.
Had to decrease the size of the holes in my bag mounts and found some washers that fit exactly........welded those in and mounted the bags. Set it down and called it a day........its sitting on the bumpstops in the last pic.
Old 06-07-2008, 08:01 PM   #68
protrash64
protrash64's Avatar
............rest of the pics................
Old 06-07-2008, 09:03 PM   #69
joe231
joe231's Avatar
cool, where did you get those bag mounts?
CHEVY ONLY
Old 06-23-2008, 12:22 AM   #70
joe231
joe231's Avatar
what's the haps on the 'burb??
has it been side-lined?
CHEVY ONLY
Old 06-23-2008, 09:49 PM   #71
drasticwagon
drasticwagon's Avatar
Cool Man
drasticwagon is offline   Reply With Quote
Old 06-24-2008, 08:39 PM   #72
protrash64
protrash64's Avatar
Hey Joe.........the burb is not sidelined by anything except intense heat........I work outside and its hard to cook for 7 days a week. 115* last Saturday........just need to do the front and run hose.....
Old 06-25-2008, 12:53 AM   #73
joe231
joe231's Avatar
hey Jeff,
cool, err not so cool.
but at least it is "dry heat"
we haven't gotten up that high, mid to upper 90's
still sucks, would be so nice to have a shop with A/C
makes me miss Alaska
i managed to get power steering installed over the weekend,
made good use of a swamp cooler and a couple fans
my bags are on hold for a bit, think A/C will be coming next
[sarcasm] probably get A/C just in time for winter [/sarcasm]
CHEVY ONLY
Old 06-25-2008, 08:45 AM   #74
slammed1966chevy
slammed1966chevy's Avatar
Hey protrash64 , were did you get your kit for your Burban ? I think i might get the same kit
When in doubt drop it !
slammed1966chevy is offline   Reply With Quote
Old 06-25-2008, 09:09 AM   #75
jchav62
1962 C-10
jchav62's Avatar
Looks nice! Good work...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
