Old 09-05-2008, 08:13 PM   #51
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
Re: Prepping for a BBC conversion
Originally Posted by SSC's76 View Post
Looks killer!
Originally Posted by COMP View Post
looking great Kenny
New page - Thanks guys!
87Lowrider is offline   Reply With Quote
Old 09-06-2008, 11:19 AM   #52
454HO
Originally Posted by 87Lowrider View Post
Is it necessary to put some type of additive in it or the normal antifreeze / water combo ok? Be cool recommended some type of snake oil with the purchase but I'm a sceptic.
The 'silent killer' for aluminum radiators is electrolysis. If there is a voltage difference of 100mV or more between the battery negative post and the coolant in the radiator, and your coolant's ph balance is on the acidic side, that aluminum radiator will disolve itself in a matter of months.
To prevent electrolysis, make sure all the grounding straps for the engine are in good shape. Would not hurt to add one at the radiator too. DO NOT USE DEXCOOL. Use the old standby Prestone, and change it once a year. And as far as an additive goes, the best one is RMI-25. It has the corrosion inhibitors and ph balancer plus it contains lubricants for the water pump seals. No snake oil... it works. I have been using it with excellent results (ImpalaSS, Grand National, Truck, Fiero) for nearly 10 years.
- Greg
454HO is offline   Reply With Quote
Old 09-06-2008, 11:27 AM   #53
COMP
good link
COMP is offline   Reply With Quote
Old 09-06-2008, 11:38 AM   #54
87Lowrider
87Lowrider's Avatar
Greg,
Thanks for the info.. I'll pick some RMI-25 up today before I fill the rad up initially, I assume it's on the shelf somewhere.... I'm waiting on Fedex on Monday for my fans to finish the install. The only antifreeze I use is Prestone.
That dude is too expensive to have to replace every six months.
My wife doesn't like the black rubber hoses for the rad and heater hoses. I stopped at a local custom shop here in the area and they have those cut-to-fit flexable hoses that look like billet on the outside. Pretty expensive though.. She keeps making me spend money on this truck, I wish she'd quit!
Kenny
Old 09-06-2008, 11:54 AM   #55
COMP
Greg,
Kenny
Riiiiiiiiiiiiiiiiiiiiiiiiiight ,,,,,don't forget distilled water to mix with
Old 09-06-2008, 12:06 PM   #56
454HO
I'll pick some RMI-25 up today before I fill the rad up initially, I assume it's on the shelf somewhere.... .
I've never found it in the regular auto parts stores. I know a guy in the Houston Buick club that buys several cases at a time. I just get what I needed from him at cost.
If you can't find it locally, just order some and add it in to the coolant when it comes in. No big deal running without it for a week or two.
- Greg
Old 09-06-2008, 12:17 PM   #57
454HO
good link
Did you look at the pics?
The radiator in my '96 ImpalaSS was aluminum. Chevy put Dexcool in the radiator from the factory, plus thay added these mysterious brown tablets that were supposed to stop leaks. End result after a few years is the radiator and heater core were all blocked up with sludge. Looked sorta like this
A lot of guys Impala guys know successfully cleaned out all that crap with the RMI, so I tried it. I did one bottle RMI with distilled water for about 5000 miles. Then I flushed and refilled with 50/50 Prestone and another bottle of RMI. My heater magically started working again, and the engine was running cooler. The next year I flushed it again, and it looked nice and clean on the inside.
- Greg
Old 09-06-2008, 12:34 PM   #58
COMP
Dexcool is TRASH
Old 09-06-2008, 08:52 PM   #59
biggreenhutch
well i've got an78 swb it has dropped spindles and springs i got it it was all apart i put in a 71 454 and oh boy do's she sit low but its easy to work on,..lol oh yeah anyone know where to get replacement rear fenders for a stepside
biggreenhutch is offline   Reply With Quote
Old 09-06-2008, 08:54 PM   #60
biggreenhutch
heres my pics
Old 09-07-2008, 11:20 AM   #61
87Lowrider
87Lowrider's Avatar
ya know, i guess I knew that could happen. It just never occured to me to take the precaution for the radiator. I'm glad I asked that question.
I'm gonna get this cooling system going and I'll be ready for a road trip somewhere!
biggreenhutch - nice truck!!
Thanks for the article.
UPDATE: 9/8/08 Here's the finished product with the Flex-a-Lite dual fan kit.
Old 09-21-2008, 05:35 PM   #62
87Lowrider
87Lowrider's Avatar
I replaced my valve covers today with the tall ones since I had spacers on the heads and the short ones... Looks much better. I also installed Comp Cams Full Roller Rockers because the stamped rockers were not allowing proper oil flow according to the mechanic who has been helping me through some of the issues.
I also got my flex-a-lite electric fans working good today after relocating the sending unit to the front of the intake and blocking off the hose to the water pump.
Old 10-06-2008, 08:35 PM   #63
Cyclone44
Step Brother
Cyclone44's Avatar
Kenny that is a nice truck.....You do awsome work....
Cyclone44 is offline   Reply With Quote
Old 10-06-2008, 10:07 PM   #64
87Lowrider
87Lowrider's Avatar
Thank You! - By the way, engine runs between 175 and 195 degrees.
Old 11-13-2008, 12:43 AM   #65
jobberone
great looking truck and love the extra work and touches. nice job. Can't believe how close our basic setup is.
jobberone is offline   Reply With Quote
Old 11-13-2008, 05:06 AM   #66
grinch4om
dang its hot
grinch4om's Avatar
far out! I guess I'm not the only crazy Kentuckian with a rat short box...
grinch4om is offline   Reply With Quote
Old 11-13-2008, 10:09 AM   #67
87Lowrider
87Lowrider's Avatar
guess not... we gotta stick together too... I still want to get a Kentucky group together somewhere.... We can't continue to let TX dominate the badazz truck scene... I can only hope that I'll have one too!
Yea.. it's pretty common. How bout a pic? You got a thread started anywhere?
WOW! - I JUST NOTICED, 500 POSTS... IS THERE SOME AWARD FOR THAT??
Ken
Old 11-13-2008, 10:58 AM   #68
Cherub
Cherub's Avatar
Nice truck.
Cherub is offline   Reply With Quote
Old 11-13-2008, 05:04 PM   #69
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Truck looks great man. I like the way it turned out. Keep up the good work bud!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 11-13-2008, 09:33 PM   #70
87Lowrider
87Lowrider's Avatar
Thanks again!!
I'm ready for a spring rod run... any takers???
Kenny
Old 12-29-2008, 10:12 PM   #71
87Lowrider
87Lowrider's Avatar
Here's a short vid of the truck idling. I shot it this morning while I was warming it up before work. I use it to deliver computers!!
Kenny
Old 12-30-2008, 09:46 PM   #72
Str8Ugly
did u use the stock 350 mounts? what im talking about are the ones that bolt to the frame and the engine cross member where the motor bushings bolt to. i have a 454 in my dually and im looking to put a 350 in it.. can i do this buy just buying the rubber mount?
Str8Ugly is offline   Reply With Quote
Old 12-30-2008, 10:15 PM   #73
87Lowrider
87Lowrider's Avatar
yes.
I bought new 454 mounts for the frame.. and the cups on the engin fit perfectly on them.. so, the sbc and bbc mounts are the same size.
Kenny
Old 12-31-2008, 12:08 PM   #74
PickWick
circled places are what im talking about.. did u have to buy new them(mine are already off) or did u just have to buy new rubber mounts and mounts on the engine
PickWick is offline   Reply With Quote
Old 12-31-2008, 02:10 PM   #75
87Lowrider
87Lowrider's Avatar
Sorry, I mis-understood you... I used the ones that were already on the '87 and just bolted new mounts on to them. The cups bolted to the engine slid down over them perfectly.
Kenny
