#51 |
![]() Join Date: May 2010
Re: Pics of plug wire routing with hei and ram horns
I figured I'd add pictures to this old thread to show how (except for a couple wire separators that I added) the wires were routed by GM. The wires are the aforementioned '77 Corvette wires. In the first picture, you can see the original clip below the manifold dump which is there to keep the wires from contacting the manifold. The clip is available from LMC and probably other vendors.
#52 |
Old member
Here is mine in the ramp truck!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
