Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-04-2008, 01:01 PM   #51
drag_72
Ready to go fast!!
drag_72's Avatar
Re: Well guys I can finally say I am Pro Street
yah we just have 3.73's we havent got the cal tracs on but with all stock suspension i mean STOCK no upgraded susupension it went 11.18 at 123 mph spinnin on 6 year old MT 28 x 10 and that was with this junk a$$ magneto.. NEVER EVER again will we run one of those! we have MSD back on it and i gaurantee we pick up a couple mph
454 block .30 forged aluminum pistons
steel crank
valve job
Holley Strip Dominator intake
1030cfm holley carb, 250 plate shot
roller rockers Erson Solid cam split duration 307/310.
.575/.595 lift
milodon oil pan
fab. aluminum valve covers
4 bolt main splayed anodized caps
all studded
drag_72 is offline   Reply With Quote
Old 12-31-2008, 07:13 PM   #52
Garagedude
Garagedude's Avatar
Well guys I haven't really posted anything in probably a month or two, but I have made some progress, I took my front end completely apart cleaned everything and painted it, I just finished getting the disk brake stuff done what a pain it was to convert the truck to a 5x4 3/4 lug pattern, So all I have left to do to finish the brakes is order a master cylinder and proportioning valve and run some new line. I just finished taking the stock gas tank out and putting the new aluminum fuel cell and pump in, So I am getting ready to order all my braided line and AN fittings, hopefully within the next month to at least drive it around the block and light those 18.5 up a little. Getting excited now. I will have to post some pics.
Garagedude is offline   Reply With Quote
Old 01-09-2009, 05:56 PM   #53
Garagedude
Garagedude's Avatar
Here is some recent pictures. Figured I would throw in a picture of the board I have in the garage that I keep track of stuff with its a great thing to have in the garage. The first picture I don't have the new tires on yet and I lowered it more.
Old 01-09-2009, 05:59 PM   #54
Garagedude
Garagedude's Avatar
Here is another pic of the board
Old 01-09-2009, 08:14 PM   #55
djracer
djracer's Avatar
It looks sweet with all that meat under the rear!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-10-2009, 09:58 AM   #56
Garagedude
Garagedude's Avatar
Thanks DJ, I can't wait to see what its going to look like with greg weld stars on the back, if they ever come back in stock.
Old 01-16-2009, 03:18 AM   #57
ProStreet71
hey guys. im new to the forum. looks like a pretty good site.
I just recently tubbed my 71. I took my existing rearend and narrowed it 6 in. and installed Moser axles. Im running 15x14 Weld DragLites with 7 1/2 backspacing. Had to cut the springs out and run coil overs due to the tires hitting the original coil springs. Much better setup anyway. I have the 29x18.5 Hoosiers and they fit perfect. It was my first time to tackle anything like this and was nervous about doin it. I measured everything a hundred times. lol But it turned out great! These trucks are the easiest thing you will ever try to tub. I've only drove it twice so far and only at the track and tore the center section out of the rearend both times. Ouch! If i knew how to post pics I would put some on here.
ProStreet71 is offline   Reply With Quote
Old 01-16-2009, 07:53 AM   #58
70c10
67-72 Addict!
70c10's Avatar
Garagedude- Sweet truck! Can you give us the details on your blower pulley setup?. Is this the same one that is sold on ebay?. I love the look of that and have thought about getting that for mine!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 01-16-2009, 02:25 PM   #59
Garagedude
Garagedude's Avatar
PROSTREET71 welcome to the board sounds like a cool project.
70C10 Jegs actually sells that kit, I have never seen it in the catalog, but if you go on the website search Alternator Drive Kit it should come up. I liked it because its different I have never seen anyone at a car show around here that has it.
Old 01-16-2009, 07:12 PM   #60
70c10
67-72 Addict!
70c10's Avatar
Garagedude- I just went on Jegs site and found a kit: http://www.jegs.com/i/Procomp+Electr...C2252/10002/-1 for the long water pump but it doesn't come with the pulley for power steering. How did you handle that or do you not have power steering on your truck???
Jim
Old 01-17-2009, 07:03 PM   #61
Garagedude
Garagedude's Avatar
I am not running power steering but there is a V grove cut in my pulley crank pulley and you could probably use it to run power steering but you would have to make custom brackets to mount it and it would probably be a real pain
Old 01-18-2009, 02:37 PM   #62
70c10
67-72 Addict!
70c10's Avatar
Thanks. This guy puts together really nice kits:http://cgi.ebay.com/ebaymotors/Hi-Pe...9105QQtcZphoto
Jim
Old 01-22-2009, 03:38 PM   #63
Garagedude
Garagedude's Avatar
70C10 that is a really sweet kit, wish I would have saw that one when I bought mine.
