#51 |
Re: Tommys66 Build
Here is the only pic of the cross member i currently have. I will try to get a close up later. I believe the cross member is possibly out of a 67-72 but not sure. It was already in the truck when I started. I made the spacer from a piece of 1" flat steel, using the stock trans mount as a template.
I love the smell of lead paint! |
#52 |
Re: Tommys66 Build
pic
#53 |
Re: Tommys66 Build
I was scuffing the new rockers I installed to prime and noticed there was surface rust underneath the reproduction sealer! Is this normal? I am gonna go ahead and strip to bare metal then prime to be safe, but wtf?
#54 |
Re: Tommys66 Build
I've seen the same thing. The e-coat lifts a little and rusts underneath. I won't paint over that crap anyway. You're better off starting with fresh metal.
http://67-72chevytrucks.com/vboard/s...54#post3194654 |
#55 |
Re: Tommys66 Build
yeah, that pic was from the drivers side, so I guess I will strip both sides and prime fresh.
#56 |
Re: Tommys66 Build
Filled a few more holes in the firewall, blocked and primed. Stripped rockers, got cab corners finished and primed also.
#57 |
Re: Tommys66 Build
I think I said I used 1" plate to make the spacer, but I used 3/4" with 1/8" piece of rubber.
#58 |
Daring to be Different
Re: Tommys66 Build
Subscribed. Now I have to read it all and catch up.
Dennis ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] ![]() I AM WE TODD IT, I AM SOFA KING WE TODD IT |
#59 |
Re: Tommys66 Build
Tommy,
Lookin through your build and here i s see you have the saddles mounted or sitting on the trailing arms and not welded to the axle tube...It this just for the fitting process or are you leaving it like that...im changing diffs on my truck and was planning on welding saddles and track bar mount to the new rear end...let me me know what you did how you did it and pics if you could. You can PM me or post it on here.. Jory ![]() |
#60 |
Re: Tommys66 Build
![]() ![]() Here is what im asking about... Jory ![]() |
#61 |
Sunburst C10!!!
Re: Tommys66 Build
cool build
Gage 1967 C10 Shortbed Stepside |
#62 |
Member of the longbed union.
Re: Tommys66 Build
Looks good Tommy, Do you think you'll have any problem with the spacer on the trans. I have to raise mine up like over 1"
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#63 | |
Re: Tommys66 Build
#64 |
Re: Tommys66 Build
#65 |
Re: Tommys66 Build
Shouldn't be a problem, The transmission sits on the spacer with the same surface area as it would have on the crossmember. In my opinion, it should be fine.
#66 |
Sunburst C10!!!
Re: Tommys66 Build
#67 |
![]() Join Date: Jul 2009
Re: Tommys66 Build
You're project's looking good! I used the same motor/trans/diff combo in my '66. I noticed you said that you made a spacer for the trans crossmember to level the transmission. One thing you may want to keep in mind is that whatever you set your pinion angle at you need to do likewise with the motor so that the trans tailshaft and the pinion yoke are both on the same plane. If you don't you may run into problems with u-joint vibration. If you set the pinion angle at + 3 degrees then the trans needs to be set at - 3 degrees.
#68 |
Re: Tommys66 Build
got the axle seats welded on along with the track bar mount I had made. For the rear shocks, I used CPP rear shock mount kit. It relocates the rear shocks for lowered trucks to correct the angle for better performance. As for the track bar, I purchased it at performance online, and had a mount fabbed up to weld to the rearend.
#69 |
Re: Tommys66 Build
test fitted the cab on the frame today. The motor clears good, but the tailhousing on the transmission is about 1/2" from the cab floor. How much room is sufficient?
I love the smell of lead paint! Last edited by tommys66; 12-01-2009 at 09:04 PM. |
#70 |
Re: Tommys66 Build
It shouldn't move much unless you have a broken transmission mount.
#71 |
Re: Tommys66 Build
Used a spray on truck bed liner to coat the underneath of the cab. I went with Raptor liner. Its a urethane base coating that comes in a kit with 4 seperate 1 liter bottles you can mix as needed. I used 2 bottles which gave me two good coats.
#72 |
Re: Tommys66 Build
Looks like some nice stuff.
#73 |
Re: Tommys66 Build
I got a trans cooler the other day. Here is where I plan to mount it...
#74 |
Sunburst C10!!!
Re: Tommys66 Build
looks awesome
#75 |
Re: Tommys66 Build
Nice design on the trans cooler. Do you have a pic of the whole unit? Are there any specs on how it compares to the ones you put in front of the radiator?
